Old Thu 11 November 2010, 05:31
buuk
Just call me: Buuk
Rack length problem
Hi there,
I am new to this forum and planning to start building a MechMate in the next few months. Right now I am trying to understand the contruction from the images and looking at the parts necessary.
As my machine will be 3 meter in length (effective length about 2.4 meter needed) I was wondering if it will be a problem to connect multiple pieces of rack to obtain this length. As most suppliers only sell up to 2 meter in length for the module 1 - 15x15mm rack.
How are you people solving this.
Thanks a lot for your kind reply.
Buuk
Old Thu 11 November 2010, 08:18
Try this thread.
Welding rack sections together
There are other pictures in other peoples build threads but I cannot seem to find them at the moment.
Old Thu 11 November 2010, 08:42
Buuk,
If your really good with your setup with the adhesive tape, you don't need to weld it at all......many just put the splice piece in place while attaching to tape and leave it!
All very easy - so purchase what is affordable
Old Thu 11 November 2010, 12:23
jwt
Just call me: John
Wexford
Ireland
I've just welded up my racks today, joining a 2m to a 1m length.
Straight forward, just chamfer the ends so you get a good root weld.
I'm using linear rails so I had to drill mine every 300mm on the sides to mount it to the main beam and the weld held through that kind of abuse. (yeah I know, I should have drilled it first. )
John
Problem with parallelism between rack and rail silverdog Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 25 Mon 24 May 2010 02:59
shutdown problem paul60 Troubleshooting 13 Wed 30 December 2009 04:42
Rack is bowed - is it a problem? KenC Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 5 Mon 14 December 2009 10:54
Z slide length, dimensioning the linear system. sprayhead Archives 1 Thu 10 July 2008 06:02
