Old Wed 10 February 2010, 20:11
djharris
Just call me: Dave
Guelph, ON
Motiontek, Canada
Has anyone purchased from Motiontek in Canada? (www.motiontek.ca) They offer both servo and stepper motor kits, which is better value?
Dave
Old Wed 10 February 2010, 21:17
Dave the Mechmate uses stepper motors. I do not think anyone has adapted servo motors to the MM chassis. You can also order Oriental Motor steppers through TRI-R Power Products supplies Oriental Motor worldwide from Canada
Old Thu 11 February 2010, 06:40
Dave,
Maris from geckdrive gave some solid advice on servo vs stepper, the short answer is that for our application and size of machine we should use steppers.
I didn't buy from motiontec.ca though, but I am sure if you buy steppers within the needed spec for the MM you will be fine. if you are not up to the electronics and finding it out, I would advice to use a proved combination of PMDX, Gecko and oriental/motionking steppers.
Ries
Working with CAM Software - Shawinigan, Canada m_leblanc Introduce yourself and start planning 28 Sun 21 March 2010 23:53
Considering s trip to Canada for your holidays ? Robert M Miscellaneous / General / Whatever / Catchall 6 Wed 23 December 2009 09:19
Hello from Canada - Winnipeg, Manitoba edwardo Introduce yourself and start planning 18 Mon 13 April 2009 08:00
hope this post is right - Walford, Canada larry Construction started, but not cutting yet 10 Fri 23 May 2008 20:11
