Old Sat 28 November 2009, 05:15
linus1
Just call me: Linus
naki
New Zealand
Belt reduction box build T5 16 to 60
Hi all ...
Herewith some pics of my reduction box build.
I'm using 10mm polycarb (it was lying around in my workshop) and trying to create as much of it with the mechmate as possible.
Old Sat 28 November 2009, 08:14
Nice... and big!
Old Sat 24 July 2010, 17:18
albertoslayer
Just call me: albertoslayer
san blas
Mexico
hii
Nice... and big!
Hi, I´m Alberto and I need to do a Belt Reduction for my mechmate, could you tell me where did you buy these pieces??.. thank you
Kind Regards
Old Sun 25 July 2010, 08:26
linus1
Just call me: Linus
naki
New Zealand
I made the polycarb pieces on the MEchmate (some 10mm stock) ... the bearing housings were a pretty good squeeze fit and then I secured them with loctite...
The standoffs I got from the local hardware store (6mm metric threaded, 30mm long hex bars)
The countersink work I performed on my drill press ...
So far (6 months or so) the gearboxes are working beautifully ...
One thing I did extra, is I drilled holes above the base plate fasteners to be able to access the nuts through the gearbox housing.... makes things quicker ...
Pulleys: http://www.cncdirect.co.za/ - extremely good service form Greg.
belts: http://www.cobrel.co.za/
Linus
Reduction Drive by belt - a collection of various designs and how to build your own. Mike Richards Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 449 Sat 09 March 2019 17:32
Added belt transmissions #16 - Demotte, IN myozman MechMates already cutting 62 Tue 12 January 2010 04:46
