Old Mon 09 November 2009, 04:33
salewis
Just call me: Stan #67
Littleton, NC
Contactor for 115V...
I begin by saying that I'm nervous running 115vac out to the EPO switches that I am planning (one on gantry, one on table, probably one on control box) which is what the TECO CU-16-F6 from factorymation.com wants for the coil voltage..
What are the options (other than two-wire with braid for the 115vac)? Pros and cons?
Old Mon 09 November 2009, 21:01
I had the same concerns about running 115 volts out to the table unnecessarily. So, I used 12 volts for the E-Stop circuit. works fine and no need to run 115 volts to the table except for the router.
Old Tue 10 November 2009, 04:25
salewis
Littleton, NC
so then you have a 12V contactor then in the EPO (emergency power off) circuit?
I use EPO terminology rather than E-Stop to help remind myself that this is different than Mach3 E-Stop.
Stan
Old Tue 10 November 2009, 06:33
Stan,
Yes.
My design is described in this post including a schematic.
Basics of connecting E-stop Contactor & (Door) Isolator switch lunaj76 70. Control Systems 35 Sat 30 June 2012 10:02
Contactor does nothing when powered? - Correct terminals for coil Doug_Ford Troubleshooting 11 Sun 11 November 2007 18:23
Selflatching relay/contactor Mike Richards 70. Control Systems 0 Sun 25 February 2007 15:20
