Old Sat 22 August 2009, 16:03
Daniel T
Just call me: Daniel
San Francisco
Cutting Stainless Steel
Hi, I need to cut some stainless steel, it is really thin (0.5 mm) but im having trouble with the bits.
I have the manufacturers recomended bit but the problem is that the cutting length is about 11 meters so the bit gets really hot even with a mister at full power, and the bit only lasts 1 or maybe 2 of the 11 meter pieces and its getting really expensive...
any suggestions to how to fix this?
thank you very much
Old Sat 22 August 2009, 19:39
What part of the MM are you making from Stainless? Normally cold or hot rolled is used.
Old Sat 22 August 2009, 23:26
Daniel, do you have a MechMate? This forum is for MM builders and the MM is not designed for cutting stainless steel.
Possible way to get recycled steel? bosox79 10. Base Table 8 Thu 05 February 2009 05:19
Steel sizes Gerald_D Golden Resources 2 Fri 05 December 2008 12:25
Pre-finished steel rails from Standard Steel Specialty dmoore Rails & Rollers 0 Thu 01 May 2008 16:28
Steel Channel Labeling (US) Marc Shlaes 10. Base Table 4 Tue 24 July 2007 13:41
Aluminum vs. Steel Gerald D 10. Base Table 0 Wed 18 July 2007 00:52
