Old Sun 18 February 2007, 09:29
Brian_B
Will bevel (angled) gears be better?
Hi Gerald,
Has anyone given any thought to using helical rack and pinions? Supposedly less likely to skip a tooth and with better/more efficient power transmission. According to this company:
http://www.atlantadrives.com/racks.htm
they are no more expensive than normal straight racks (though I don't know, yet, what their "normal" pricing is!).
The main disadvantage is that they can be tricky to align and set up.
Brian
Old Sun 18 February 2007, 22:29
Brian, we are not in the habit of skipping teeth with the straight rack, so we don't need improvements in that area. The springloaded pinion will have a smoother ride on a helical rack compared to a straight one.
But a helical rack introduces side forces, or an axial force on the pinion shaft. Most stepper motors have a lot of axial freeplay (temperature dependent) which will translate to backlash with a helical gear train. The oriental motor gearboxes also don't want axial forces on their shafts.
