Closed Thread
Old Thu 07 January 2010, 15:59
windmill
Just call me: windmill
Irvine
Question on how to provide different current rate from a single power supply
Hello Gents,
In my application, I do have a couple of appliances (servos, breakout board, spindle controllers) require different current under the same 24V DC power, they are:
1): Servo drive: 24VDC with 12A
2): Control signals: 24VDC with 4A
3): Control signals for the spindle controller: 24V with 40mA
I am trying to just use on power supply to supply all the power supply since they are all 24V DC. So I made an electrical drawing diagram with circuit breakers, but I am not sure if it is correct. Please help me to verify the diagram. Thanks,
Old Thu 07 January 2010, 16:33
Windmil,
I don't know exactly what you are asking.
If you have 3 "loads" (servos, breakout board, spindle controllers) which each require 24 volt power, you simply wire each load to the 24 volt power supply. Each load will "draw" the amount of current (amps) it needs to operate. You simply have to calculate the size of the power supply to meet the "draw" of all the loads...as you have done. You should always size the power supply to be, say, 25% greater than the calculated load.
One note, you include the breakout board in the list of loads requiring 24 volts. If you are using the PMDX-122 BOB, it only requires 12 volts DC or 9 volts AC. 24 Volts would probably destroy the PMDX-122 BOB...I haven't tried it and I definitely would not recommend it.
In my case, I built a dual voltage power supply which delivers 12 Volts DC and 24 Volts DC. I use 12 Volts DC to drive the BOB and I use 24 Volts DC to drive 24 Volt coil Contactors for the Spindle, Dust Collector and Vacuum Hold-down. I also use 24 Volts for the E-Stop Circuit.
Perhaps you could expand your diagram and provide some part specifications or part numbers.
Old Thu 07 January 2010, 18:09
windmill
Irvine
jhiggins7,
Thank you for your quick reply. Here is the mean well power supply that I will choose, http://www.meanwell.com/search/se-450/default.htm
I am not really an electrician, so I would prefer buying parts off-the shelf. By the way, I am using a servo motor (Teknic Servo Motor M-2311P-LN-16K with encoder/ coupler) to drive the gantry machine. The motor's cont. current is 5A, peak is 15A. I do have 3 axis, so I figure out the current that I need is:
3*5*0.67=10.05A, So I picked that 12A meanwell power supply.
I don't know if the calculation is correct for the Teknic brushless servo motor (since this equation is for steppers, right?)
Another question that I have is the circuit breaker. Right now, I choose the circuit breaker according the the cont. current from the motor, but not from the peak current, am I right?
Windmill
Old Thu 07 January 2010, 20:03
Windmill, are you building a MechMate?
Old Fri 08 January 2010, 02:38
windmill
Irvine
Greald,
Not exactly, I am trying to build a desktop 3 axis gantry machine using servo motors.
Old Fri 08 January 2010, 03:21
Sorry, "This forum is exclusively for MechMate builders or people seriously interested in building them." <----- quote from front page.
Closed Thread
Why not use an adjustable, regulated power supply? Bob Cole 702. Power Supplies 19 Thu 25 August 2011 09:33
Transformer supply current versus Gecko output current . . . . . Mike Richards 702. Power Supplies 42 Fri 15 January 2010 04:37
The Power Supply needs only to supply 2/3 of the rated motor current Gerald D 702. Power Supplies 0 Sat 05 December 2009 20:09
making sure a power supply is correct baseball43v3r 702. Power Supplies 77 Tue 17 November 2009 11:15
Clearing confusion with the 230Vac single phase Power Supply Diagram (10 70 230) sprayhead 702. Power Supplies 3 Fri 16 January 2009 19:10
