Old Thu 18 December 2008, 07:42
isladelobos
Just call me: Ros
Canary Islands
Spain
Lightbulb Dreaming a future mechmate
Dreaming a little
bored at the office
This router for wood, metal, foam, etc...
Old Fri 19 December 2008, 04:51
Ross,
Interesting design what are you planning to cut with it - Foam?
Old Fri 19 December 2008, 06:21
isladelobos
Just call me: Ros
Canary Islands
Spain
I think it is possible for all purposes,
adding different tables with wheel
or rotary tables with a more axis
Depending on the hardness of the court, adjusting the distance between the table and Z
Old Fri 19 December 2008, 07:11
Am I missing something? I can't find the 6th axis.
Old Fri 19 December 2008, 07:34
isladelobos
Just call me: Ros
Canary Islands
Spain
Yes Greg.
The X are two motors and two drivers but is a axis movement.
5 Axis but for the software are 6
Old Fri 19 December 2008, 21:37
Very interesting. ... Looks like one where you could 'roll a table' into place, and roll it out and another in.
Now if it was 12' wide and I hung the X axis from the ceiling, I could use my whole garage as a CNC shop! ... Gotta stop day dreaming. ... To much caffine!
Old Sat 20 December 2008, 05:34
Ros,
instead of making the Z-Axis so long I would suggest making a lift-table instead and keep the Z-Axis short. This would make the system a lot more stable.
The Lift table doesn't have to be so precise in hight as long as you make some mechanism to auto find hight. See this post for a sample on how that could work: http://www.cnczone.com/forums/showthread.php?t=56079
Ries
