Old Sat 19 March 2016, 10:12
Kornerking
Just call me: Pete #127
Big Falls, Mn
Originally Posted by danilom View Post
Great work Pete and if I may jump in, you acceleration looks too small. Something in a range of 200mm/sec or in inches 8-10 ips. Also if that end mill is in range of 6mm or 1/4" you can do plywood easy in just 2 passes. This accel might be needed for this beast Biesse 335 retrofit I done recently but he Mechmate is much lighter and can be much more maneuverable . Try bumping that accel to 20 or more (600mm/sec) and you may get away with cv on outer corners, that will improve your cut time significantly.
Thanks for the advice Danilom. A lot to learn.
Question? What is the CV you speak of?
Old Sat 19 March 2016, 11:56
constant velocity
Old Sun 20 March 2016, 16:16
Kornerking
Big Falls, Mn
Thanks Tom. I checked out what it meant on Mach 3.
So much to learn yet.
Old Fri 25 March 2016, 10:21
Kornerking
Big Falls, Mn
George is ready for a #
Logos are now installed.
He sure looks pretty.
Old Fri 25 March 2016, 10:37
hflwaterski
Just call me: Herb #126
Genesee, WI
Nice going Pete and Tony! Looks terrific and very official! It's diploma time!
Old Fri 25 March 2016, 13:41
Kornerking
Big Falls, Mn
Vacuum manifold and filter
We got our vacuum system set up. Built a filter box using a small filter sandwiched into a box.
Boy does it suck down.
Old Fri 25 March 2016, 14:00
Nice job, Pete.
Ready for a new build thread title yet? Something like " Thank you Darren for hounding me to get off my duff and get this thing done."
Old Fri 25 March 2016, 14:01
We could shorten it to "Thank you Darren!!" if you'd like.
Old Fri 25 March 2016, 14:52
Kornerking
Big Falls, Mn
Did the first full sample set of the dovetail on a 45 deg corner. George is amazing.
https://www.youtube.com/watch?v=a36Nj3SR9cU
Old Fri 25 March 2016, 14:54
Kornerking
Big Falls, Mn
Originally Posted by darren salyer View Post
Nice job, Pete.
Works for me.
Old Fri 25 March 2016, 15:23
Nice Drawers! I did a few boxes today, not as impressive though. What vacuum motor or pump did you end up with? I really need to "get off my duff" and get a vacuum system together.
Old Fri 25 March 2016, 15:42
Kornerking
Big Falls, Mn
I bought the Amtek Lamb motors. https://www.grainger.com/product/AME...Code=P2IDP2PCP. I ended up buying them from a company in Texas for around $330 each. I have 2 hooked up to the MM and a 3rd one for my loader. I need to wire them to separate circuits though as the draw 14 amps.
On 5/8 ply , one motor holds well but on 1/4" I need the second motor kicked in.
Old Fri 25 March 2016, 16:20
A little MM etiquette....
http://mechmate.com/forums/showthread.php?t=816
Old Fri 25 March 2016, 16:22
Pete, do you have the motors seperated with some sort of one way check valve, where the first motor isnt drawing through the second when its off?
Old Fri 25 March 2016, 16:26
Kornerking
Big Falls, Mn
Yes.
Old Fri 25 March 2016, 16:28
Kornerking
Big Falls, Mn
Sorry.
Old Fri 25 March 2016, 16:31
Somehow Pete, I thought for sure you would quote me....
BTW, I'm proud of what you've done there. As time goes on, you'll find more and more uses.
It's impressive that someone who remembers the invention of the telephone has embraced technology as much as you have.
Happy Easter.
Old Fri 25 March 2016, 16:45
Kornerking
Big Falls, Mn
It was the invention of dirt that really excited me.
Old Fri 25 March 2016, 18:55
Someone will pop in and make it official but let me be the first to offer congrats to #127 from #101.
Old Fri 25 March 2016, 19:22
Kornerking
Big Falls, Mn
Thanks Darren. Your persistence paid off for me and Tony. Once we got on it it went fast.
Monday, George, starts his first full day of work. We have spent the last few days moving equipment to the warehouse. Great feeling. The shop is almost wide open.
Old Sat 26 March 2016, 10:12
Kornerking
Big Falls, Mn
Help!!!!
Cutting out parts and I notice at the end of every run, about an inch long the machine suddenly makes a sideways dive. It does this even in the grooves.
Suggestions as to what I should be looking for to correct this?
Old Sat 26 March 2016, 14:59
Make sure your toolpaths are closed. If it does it every part, regardless of position, its software related, most likely.
Old Sat 26 March 2016, 15:35
Kornerking
Big Falls, Mn
It does it every cut.
So I need to debug cut2d then?
Old Sat 26 March 2016, 15:52
Debug? No. Make sure all your vectors are drawn correctly with no overlaps or open vectors.
Old Sat 26 March 2016, 15:53
These stupid machines do what you tell em to do, not what they are supposed to do.
Old Sat 26 March 2016, 15:55
Export your drawing as a .dxf, send it to me and I'll take a look.
Old Sat 26 March 2016, 16:08
Kornerking
Big Falls, Mn
Thanks Darren. Will do.
Old Sat 26 March 2016, 16:14
Kornerking
Big Falls, Mn
Dummy moment. I can save it as a crv. How do I convert it to dxf.
Sheez this is tough on us old guys.
Old Sat 26 March 2016, 16:35
File-export-selected vectors to .dxf
Old Sat 26 March 2016, 16:44
islaww
Just call me: Gary C
UP of Michigan
Pete...
There are 2 things that usually cause the issues you show.
1) Slack somewhere in the machines motion mechanics
2) Accel/decel/feed rates too high
Have you measured the parts for accuracy? Sometimes what looks like the error turns out to be the accurate dimension.
Take some scrap and cut some inside and outside circles of the same size (<6") and measure them to compare. Do one set climb and one set conventional, post results.
Back Doing Some Arcade Fun #19 - Smith's Falls, Ontario, Canada bradyaero MechMates already cutting 146 Tue 27 January 2015 09:41
'Clean' Vectors - free project plans for the woodworker Kobus_Joubert Golden Resources 6 Thu 13 August 2009 06:34
It's all Darren's fault!! - Big Falls, Mn Construction started, but not cutting yet 0 Wed 31 December 1969 19:00
