Old Mon 29 March 2010, 04:29
Lex,
Congratulations and welcome to the club.
Old Mon 29 March 2010, 07:06
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Thanks Nils.
Old Wed 31 March 2010, 10:56
Johan what did your machine cost you to complete?
Old Wed 31 March 2010, 23:21
Lex
That reminds me. I will have to add up all my invoices over the weekend. A good guess would be be just over R30 000. Will post the exact figure next week.
Old Fri 02 April 2010, 08:47
Rad Racer
Just call me: Wayne #25
Minnesota
Good work #56, excellent build.
Old Thu 15 April 2010, 15:23
LIBBIT
Just call me: John
Mt Roskill, Auckland
New Zealand
Hey Johan,
Will u be so kind as to send me an e-mail to [email protected] (work) or [email protected] (private) so we can be in direct contact. I'm gonna try and get the wiring done this weekend well as fas as i can with out the motors and drives.
Thank you, John.
Old Sun 25 April 2010, 10:38
Lex
I am still test driving and it is dust every where!
My first priority is to get the door hanged between the Blue machine and the rest of the Garage.
Old Sun 25 April 2010, 10:47
Lekker !!!!!!!!!!!!!!!!!!!!!!!!!
Old Sun 25 April 2010, 11:06
I will send you some wood then you don`t have an excuse to take the doors of your house of to practice on.
Old Sun 25 April 2010, 11:10
Lex
Dankie Hennie.
I don't need any extra doors but a dust extractor will be welcome!
Old Sun 25 April 2010, 11:18
And a broom
Old Mon 26 April 2010, 02:46
Moffie MM in KwaZulu...can only cut HOLLOW DOORS ...
Old Mon 26 April 2010, 03:58
Lex
Watch it.
Old Mon 26 April 2010, 04:39
He has a router that is working
Old Mon 26 April 2010, 06:36
Ok ok kick a man when is is down. I phoned the agents today they say.....WHAT !!! a model 3608B Makita...some oke back then used one of those to build a BIG BIG SHIP
Looks like I will have to cut my 1200W Bosch a bit and make a new bracket to get going again.
Old Mon 26 April 2010, 06:45
Kobus, don't you just need new brushes?
Old Mon 26 April 2010, 07:05
My mistake...I heard the brushes making a funny noise about 90% through a job...thought if I stop now, I have to start all over again..... lets see if it will finish the cut... next minute it just died. Open it up and saw to my horror that it hooked on one of the small copper strips and ripped it out of the armature....stupid !!
Old Mon 26 April 2010, 07:47
Rutherfords are the Makita importers - they may have a spare armature.
Old Mon 26 April 2010, 07:59
Gerald, see post #225. Maybe we should move off Johan's page
Old Wed 28 April 2010, 00:10
Lex
Hennie,
I left the doors alone now. Now I am playing around with off cuts in the garage.
Hooks for the wife's spoons in the kitchen.
Also cut a piece of plastic Forex as a sample for a potential client.
Old Wed 28 April 2010, 00:25
Did you use PECK drilling for the cuphooks ?
Lex
I am having two small problems with the machine.
The motors are getting hot after about 40 minutes of cutting. Could only hold my hand on them for 3 seconds. I will have to change the resistors.
The second thing is the gear that slips on the z-axis. This only happens when I do small cuts like in a spiral down or when I tap a millimeter step at a time. It seems to be when there is not a full teeth on the gear, like between two teeth. The gas shock just push it up for about 2mm. I am still thinking how to solve this one!
Old Wed 28 April 2010, 00:26
Lex
Yes Kobus. I was pleasantly surpirsed how wel it work. I draw a small circle. Is this the right way to do it? I couldn't do a dot.
Old Wed 28 April 2010, 00:44
Johan, to check your motor heating, from this thread I can see:
Stepper motors: Motion king 34HS 9801
Drivers: Gecko G203 V
How many volts DC are you supplying to the Gecko's?
How are the motor wire colours connected to the Gecko's?
How much is the measured resistance of the resistors that you have on the Gecko's?
Old Wed 28 April 2010, 01:08
Lex
Gerald the transformer is rated 300VA on primery and 42V on the secondary that supply the PSU board bought from Greg, Edenvale.
Motor wiring are A+ to motor red, A- to motor Yellow. Second coil are B+ to motor white and B- to motor orange.
Resistors are 100K, 0,25W. I haven't confirm this by measuring.
Old Wed 28 April 2010, 04:47
The circle thing is the way to do peck drilling in V-Carve pro, I also thought a DOT must be drawn, but when I did the dibbler the other day, I drilled all the holes based on circles.
I think 100k is way TOO much. Try 47k, but I still think the 42V is our problem.
Old Wed 28 April 2010, 04:57
From a quick look, the transformer voltage is okay, but your resistor is allowing too much current for a 4amp motor. The resistor should theoretically be 63kiloOhm and I would try 68kiloOhm which is the common one.
Old Wed 28 April 2010, 04:59
Sorry Kobus, didn't see you slipping in there - I was looking up some things while you posted.
Old Wed 28 April 2010, 05:22
No problem, remember I ran 68k as well and my motors were pretty hot with the 42V. I now run 47k, ....they are still hottish, but I lost some Torque.
Old Wed 28 April 2010, 05:50
Lex
Ok, so I can try a 47k because it looks like you are running on the same voltage as me. I don't think they will be to expensive, so I will buy some 68k's as well.
Kobus by 'hottish', do you mean between frying an egg and the "tong tippie toets". Sounds like the S.A. quantity system. If you need between 4 and 10 you ask for a couple!
It has made the first cuts - Caussens, France Pierre GRAND MechMates already cutting 97 Tue 15 December 2009 10:26
need a few parts cuts on a router. DXF files ready CapitalClassic Miscellaneous / General / Whatever / Catchall 1 Wed 28 October 2009 17:56
Machine cuts out after cutting for a while - Loose wire on E-stop circuit Hugo Carradini Troubleshooting 8 Mon 31 March 2008 12:18
