Old Fri 08 April 2016, 12:42
hflwaterski
Just call me: Herb #126
Genesee, WI
Thanks Andrew!...and per Tom's request, here is my first sign project. I learned quite a bit about how I wouldn't do things as much as I learned about how I would. I also included a logo similar to what I started with. It was slightly different but you get the idea. It was the 5th anniversary which is represented by wood so the key and the sql letters were done in birch.
Old Fri 08 April 2016, 13:08
Nicely done !!
Customer must be very happy
Cheers, R.
Old Fri 08 April 2016, 14:02
An awesome first sign.
Well done.
Old Fri 08 April 2016, 14:25
Super nice! Great job!
Old Sat 09 April 2016, 19:32
hflwaterski
Genesee, WI
Thanks guys! I'm pretty happy with the outcome and so was the customer.
Old Tue 26 April 2016, 21:24
hflwaterski
Genesee, WI
I thought I would give you all a quick update on my next project. I'm building a kitchen island. I have a quick mock up done in SketchUp so you can see what I'm building. The cuts are going well. I did have a little issue with the dado precision due to a fairly warped piece of plywood. A vacuum table sure would come in handy for large sheets. A few well placed screws and lots of clamps helped quite a bit. Here are some photos of my progress so far.
Old Wed 27 April 2016, 03:21
Very nice Herb! Post more pics when you've completed it. Thanks for sharing.
Old Wed 27 April 2016, 06:05
Vacuum maybe better!!!....I wouldn't tell, been doing all kinda cut, including sheet cutting (+60%) without seeing a "need" for it....in 8yrs !
Don't have a vacuum, never worked with one, so can't really tell, but, I'm not near tempted, again, by my need (experience), to go buy or make one !!....I manage very well without.
Good luck.....and nice working, like tom say, share the final work !!
Old Wed 27 April 2016, 06:38
Kornerking
Just call me: Pete #127
Big Falls, Mn
Robert, how do you keep things from moving? Clamps? Screws?
I like vacumn. Lay the sheet down, flip the switch and it is ready to cut. Granted, it did cost a few bucks.
Old Wed 27 April 2016, 07:02
Managing mostly (80% of the time) with clamps...
Through careful parts nesting....and tab location....and clamps :
Here's a few examples
Part of a Solid cherry top :
Here's a drawer front :
Simple....key words = planning, nothing new!!!
Although, must admit, the more you try & play around "trying" to make it happen, the better you become
Hope this "inspires" some !!...
All the best
Old Wed 27 April 2016, 07:27
Very nice work, Robert!!
Old Wed 27 April 2016, 10:07
Kornerking
Big Falls, Mn
Robert , I can see where for your applications the clamping is the best situation.
I use full sheets cutting up to 25 items from a sheet so the vac is better for me. I guess it all depends on what a person is cutting.
Nice work by the way.
Old Wed 27 April 2016, 10:50
Thks Pete, but let's congrats each other, as you make some very nice stuff too @_# !!
There's some time I think I may have benefited of a vacuum system and I'm not saying it's no useful ( I wouldn't know really....can only assume it's benefit)...what i'm saying though, there's many ways around if one wishes to see alternatives or wait on a later date to "invest" in such a system !
On e may also make a small vacuum removable unite like some use for drag knives (like Donek and many others of this world)!!
Fun exchange-topic ....i tend to think it should me moved to another thread then taking space on Herbs....
Old Wed 27 April 2016, 14:18
Both have their places, clamping and vacuum. Most find a method and adjust their layout around it. The best way would be to use which ever is best for the job. Clamp for this job, vacuum for that one. Please keep the pictures coming. Even small projects help someone.
Thanks for sharing.
Old Wed 27 April 2016, 15:04
Kornerking
Big Falls, Mn
Sorry Herb for jacking your thread.
Interesting discussion though.
Old Mon 02 May 2016, 08:26
hflwaterski
Genesee, WI
It's a good discussion. I don't mind at all.
Another quick update. Here is a video that shows the drawers being cut out. At the end of the video, something triggered an e-stop condition. It's been happening on occasion so maybe I have a grounding issue somewhere.
Also, not sure why the Fusion 360 software doesn't pull my dado back into the part when I use the copy command. That's why you see the dado extend beyond the part. More learnin' to do I guess.
Here are a few photos of the progress after the drawers were assembled and installed. You can also see that I'm starting to fill holes in order to prep for painting on the cabinet. Doors and drawer fronts to make and then on to some trim detail. My plywood is looking like a puzzle.
Old Mon 02 May 2016, 08:28
If you are using Mach 3, what is your debounce, it may need to be increased.
Old Tue 03 May 2016, 07:18
hflwaterski
Genesee, WI
I didn't get a chance to check out my Mach 3 settings yet. I'll try to get that information tonight.
Old Tue 03 May 2016, 18:30
hflwaterski
Genesee, WI
The debounce settings are currently '0'. After a little reading on the internet, looks like trying '1000' would be a recommended first attempt. What do you think guys?
Old Wed 04 May 2016, 02:43
My debounce was at 0.
I changed it to 500.
I get an occasional error if I forget to throw a bucket of water on the earth spike.
Old Wed 04 May 2016, 04:40
hflwaterski
Genesee, WI
Thanks Al! I'll give that a try first and see how it goes.
Old Wed 04 May 2016, 06:02
Most results are achieved by empirical means.
Empirical evidence, also known as sense experience, is a collective term for the knowledge or source of knowledge acquired by means of the senses, particularly by observation and experimentation. The term comes from the Greek word for experience, ἐμπειρία (empeirķa).
That's a $50 word.
Old Wed 04 May 2016, 12:16
timberlinemd
Just call me: Steve #66
Arizona
I had the same problem. The Chinese VFD/Spindel has allot of noise. The debounce gives your electrics a chance to tell if the signal is 'real' or a 'phantom'.
I had set mine real high one time. Then when I 'homed' my machine, the home switch would engage, but the machine kept traveling and would crash into my hard stops.
Set it back some and all was fine.
Old Wed 04 May 2016, 19:09
islaww
Just call me: Gary C
UP of Michigan
Ive had good luck with debounce settings between 20 and 30. That requires 20+ "hits" a millisecond apart. You would have to have a freaky noise to outlast that.
Old Wed 04 May 2016, 19:56
I suffered through this. Here is close to the start of the posts pertaining to it. http://www.mechmate.com/forums/showt...&postcount=388
Old Sun 05 June 2016, 17:37
hflwaterski
Genesee, WI
It's been a while since I updated my progress. The photo is a little dark but you get the idea. I ran the island sides, bottom, back, drawer parts and a couple other miscellaneous pieces on the CNC which included the interior shelf holes and dados. The top is reclaimed oak barn wood about 1 1/4 thick. It's difficult to see but there are corbels under each end. Thanks for looking!
Old Sun 05 June 2016, 17:48
Yep....you're right !!....can't see much, but we can feel your joy and satisfaction...good going !!
I'll say this tho....PITAA this forum is failing to....simply not upgrading to follow the trend in allowing MUCH bigger photo files .....
OOo well
Old Sat 31 December 2016, 21:59
hflwaterski
Genesee, WI
Happy New Year to the MechMate Community!!! Be safe everyone!
Old Mon 13 February 2017, 19:21
hflwaterski
Genesee, WI
Just wanted to let anyone who is interested know that I started up a YouTube channel. I would like to mix in some demonstrations using Fusion 360 along with the MechMate. My goal is to make some fun stuff and show the process from start to finish. Part one of a bag toss game was just posted this evening. I plan on finishing the rest of the video over the next week or so. Here is the link: https://www.youtube.com/channel/UCjY...eI5CJ2YXP1k62g
I encourage everyone to subscribe to my channel. I'm also interested in your feeedback and whether you find the videos helpful and interesting. Thanks!
Old Tue 14 February 2017, 18:42
I'm also using Fusion 360 for my VMC milling so so its always nice to see someone else working in it and documenting it. So you have a sub from me.
More progress, it cuts ! #109 - Hampshire, UK Andrew_standen MechMates already cutting 75 Thu 23 July 2020 13:23
Stickers on and cutting #77 - South Australia Quadro MechMates already cutting 66 Sat 29 September 2012 08:01
It has made the first cuts - Caussens, France Pierre GRAND MechMates already cutting 97 Tue 15 December 2009 10:26
