Old Wed 06 November 2013, 07:18
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Cool
Some brass hooks on the keys would be a great. My wife just walked in and ask me where her keys are. Are you cutting down neighbors tree for wood?
Old Fri 08 November 2013, 04:52
What a piece of kit this machine has turned out to be.
Got the bugs out of the system.
10 hour shift today, faultless.
Only stopped for load/ unload & tool-change.
Only problem was with the router, new brushes tomorrow.
Should have built one years ago.
Old Fri 08 November 2013, 04:57
I love the idea of a "Meet the Beast Party". I wish you many great successes!
Old Tue 19 November 2013, 22:58
Simple 4th Axis
I wanted some 20mm dowels.
Back home I would have bought a broom handel.
Here broom handles are made fron bamboo.
I have not got a lathe (Next project).
I made a simple 4th axis.
The motor needs gearing as it lost some steps.
It did the job, got me out of a hole.
Old Tue 19 November 2013, 23:01
racedirector
Just call me: Bruce #122
New South Wales
They say need is the big creator of ideas, very impressive adaptation Al!
Old Wed 20 November 2013, 06:23
Great Job. I've thought that using two 4:1 gear reduction plate sets, one driving the other, would work well for reduction.
Old Wed 20 November 2013, 17:54
I wonder if I could cut my own gears (Wood or Plastic)
For the reduction.
Got the machine, just need the time and materials.
Old Sat 30 November 2013, 01:36
Buddha
A local woodcarver gave me a piece of a root from a tree.
He asked could I put it through my saw and make some Buddha's.
A very heavy and dense wood it was.
So today I did the routing.
33 in strip form and 3 specials.
Old Sat 30 November 2013, 04:17
I really like the wood, not in to Buddha, but cool none-the-less.
Old Sat 30 November 2013, 05:57
That looks cool. How tough was that wood on the bits?
Old Sat 30 November 2013, 17:11
What type of wood is that Al?
Old Sat 30 November 2013, 21:07
Sorry, but I do not know what it is.
Not being a native of this neck of the woods it is very hard to find out what something is, where it came from or what it is worth.
The guy might not know himself.
There might be a local name, it might be what the monk calls it.
It smoked a bit on some cuts. I had the router on bottom speed.
Feed 500mm/min.
It also left a resin type deposit on the bit.
It files like cast iron.
Smells nice.
Thats about it.
Parts delivered, customer happy.
Old Sat 30 November 2013, 23:13
Looks like Siang-Malam.
Old Tue 03 December 2013, 02:38
Milling steel
I ordered some profiled plates last week for a machine I an building.
No, it is not another MechMate.
After a week of waiting they were ready.
The 42mm holes in the plates were 40mm.
Off to see my mate Mechmate.
16mm two flute router bit, router on bottom speed.
Lots of sparks and noise.
5 plates, 2 holes in each.
Job done.
Cutter to go to the grinder tomorrow.
Old Tue 03 December 2013, 06:47
Nice job.
Careful with your plunging rate, those spindle bearing are expensive.
Old Sat 07 December 2013, 02:24
silverdog
Just call me: Sergio #70
Rome
Italy
Somewere somebody told that you can't use microstepping for the rotary 4th axis because it will not give a precise 360° ..... so you absolutely need reduction and more than the usual 4:1 .... I have no experience nor I am shure this is true. Anybody can confirm ?
Old Sat 07 December 2013, 04:13
I would not know if that is totally accurate. Whether it is 200/r or 2000/r, it is still 1 revolution. Granted a servo with feedback would be optimal. You can dial the stepper in really close using your step calculator and spinning multiple revolutions using an indicated plate and long indicator arm (24" or more). I would think the problem would be more from the limited amount of torque that caused the loss of steps while turning against the cutter. Too many dynamic forces at work. The lowest reduction I have ever read about with a 4th Axis is 3.6:1. But as Sergio stated, that is definitely worth looking into to verify. You will have backlash with any reduction setup unless it is a Zero Backlash reducer like a harmonic drive.
Old Sat 07 December 2013, 05:45
Very probably you will not get a precise 360 Degrees.
Very probably you will not get a precise 0.001 mm or 0.0001"
As I am working in wood which will change size with humidity and temperature I will not worry about that.
As I am not making components for Aerospace applications, that is not a worry either.
I am more than happy that I have built a machine by myself that has exceeded my expectations.
At this stage in my life I do not need to split hairs any more.
I had enough of 0.001mm tolerances during my working life.
Thank you for your comments.
I am sure that those who need a more accurate machine will pay heed.
I will get around to gearing the 4th Axis and I will post progress and results.
At the moment I am constructing a manual lathe with the option for CNC control.
Also a bandsaw build is on the horizon.
Nice to be busy.
Old Sat 07 December 2013, 06:43
It was not meant to offend.
I have mine as a double belt reduction but I would never tell you to only stop at my level. I would not want to leave someone wanting more. Tell them the best and let them make there own decision.
You are right about wood, from the time you start carving to the time you finish the wood will vary somewhat unless you are in a controlled environment that the wood was also stored there for a long, long, long time.
If you were putting this on a milling machine, I would not recommend anything under 50:1 at the lowest reduction.
Old Sat 07 December 2013, 09:16
I've not started work on my A-axis yet, but when I do, I'll surely have higher gear ratio for more torque to ensure the job piece will stay in place when its supposed to. The resolution & precision that came with it are bonus.
For non-metal work, 50:1 is too hard, 20~30:1 should be feasible using GT2 belts & pulley.
Old Sat 07 December 2013, 18:46
No offence taken.
I welcome all comments.
I am sure that a Rotary axis build is worthy topic by itself.
Worm and worm gear would give plenty of reduction.
Have to visit the scrap yards around here.
Old Sat 07 December 2013, 19:01
http://www.thingiverse.com/thing:41161
Something like this would do.
Anyone got one of them laser things ?
Old Sat 07 December 2013, 21:38
Worm gear will be cheaper to make, but I prefer working with belts, Its not about the precision or resolution, I hate seeing double lines cause by backlash. 2 stage 5:1 will easily give 25:1 Since there is only 1 motor required, 4 pulleys should be affordable.
Old Sun 08 December 2013, 07:32
I've gotta start on a 4th axis.....
Old Sun 08 December 2013, 07:48
silverdog
Rome
Italy
Me Too
Old Sun 08 December 2013, 08:28
If you go belt drive double reduction, it will increase the amount of movement as two belts will have the ability to flex. So it all depends one how you do your wrapping and your toolpath is generated. Make sure you buy good quality belts. I opted for a 16:1 combined belt reduction when I built my A. Later down the road I would like to opt for a low or zero backlash gear head but for now. Belt reduction is fine. Just wish I could finish the table mods.
The effect only has a chance to occur while rotating fast one direction and stopping to reverse direction. All depends on the surface cutting speed.
Old Sun 08 December 2013, 10:13
Sorry to continue the hijack....
I've not done much research on this, how much reduction is possible with just a single set of pullies and 1 belt?
Old Sun 08 December 2013, 10:18
silverdog
Rome
Italy
I think it's not so easy to find a big pulley ... but if you find it yes is possible
Anybody knows Harmonic Drives ? are a possible solution ?
Old Sun 08 December 2013, 10:27
Yes, but they are $$$$. You can get a harmonic drive gearhead or low backlash planetary gearhead. I have looked at it.
Old Sun 08 December 2013, 10:30
Darren,
My 7:1 reduction on my X, B and Y have a 18 tooth pulley and a 130 tooth pulley. The 130 tooth pulley is 9.125" in diameter. More feasible to use two 4:1 or 5:1 reductions.
Plus they were expensive
Started making windows with the mechmate ... #70 - Rome, Italy silverdog MechMates already cutting 100 Wed 26 April 2017 22:02
Lookin for Gremlins - Isarn, TH lonestaral Troubleshooting 8 Mon 02 November 2015 12:10
Oh Can I ?? - Phuket Thailand jek Introduce yourself and start planning 10 Fri 24 June 2011 05:55
Newbie to CNC - Chiangmai Thailand chainarin2553 Introduce yourself and start planning 1 Wed 15 June 2011 05:27
Free Cad and Cam HeekCNC Windows & Linux Regnar CAM 0 Thu 16 September 2010 19:24
