Old Wed 02 January 2013, 20:20
Thanks Ross.
I'll have a look.
Old Fri 04 January 2013, 07:12
Darren,
Congrats on your build! Because of the size of your MM did you feel it necessary to 'beef up' your frame or do you feel one can do with less beef. I just ordered steel for my frame (same size as yours) and I'm starting to think I didn't plan well enough.
Tom
Old Fri 04 January 2013, 07:29
I will say I suffer from "overkill-itis", so bear that in mind.
I wanted room to store sheet goods under the table, so I couldn't triangulate as well as some have done.
When the machine is doing some rapid moves, it is surprising how much even a heavy table moves. I'm talking reversing directions of the gantry at 150" per minute.
If I had it to do over, I wouldn't make it any lighter.
Old Tue 08 January 2013, 19:11
Gonna use this image to make an 30" pub table top using 1/2" Corian and red epoxy.
Still deciding on a base.
Old Wed 09 January 2013, 02:39
Darren,
At what speeds/# of passes are you cutting the corian and are you finding the dust an issue?
Tom
Old Wed 09 January 2013, 06:34
Hi Tom, I use an end mill cutting .125" deep in one pass at 150" per minute. I have a homemade dust foot similar to many you see documented here, and dust has only been an issue when I forget to turn the collector on.
Old Wed 09 January 2013, 09:17
less than 7 minutes later, the laces are cut.
Tom, you can see what dust is left in the pockets, pretty big chips really.
Old Wed 09 January 2013, 10:05
Nice !
What end mill are you using for this?
Old Wed 09 January 2013, 11:52
1/4" upcut spiral.
Old Wed 09 January 2013, 13:06
Couldn't get a plug for the MM forum, but a pretty good read nonetheless......
http://daily5remodel.com/index.php?a...cle&rowid=1799
Old Wed 09 January 2013, 13:44
Nice article, nice business plug !
Wishes it bring you more business.
Good luck
Old Wed 09 January 2013, 14:19
I'm hoping it brings more people here, through me, as well.
Much greatness can be achieved through many minds.
Old Wed 09 January 2013, 15:55
Nice Darren, well done.
Old Wed 09 January 2013, 18:53
Darren,
I play around with corian/solid surface too. MM definitely speeds up the process. Do you have any experience with laser scanning equipment/systems for scanning templates? or does anyone for that matter. Just wondered if it would be a wise option.
Old Fri 11 January 2013, 03:28
Great write up on your work Darren.
An inspiration to the other Mechmate builders.
Old Sun 20 January 2013, 20:06
Whipped a few name plaques up for some great niece and nephews I haven't met til this weekend.....
Old Mon 21 January 2013, 00:43
That's one way to remember the names
Old Mon 21 January 2013, 05:48
Jason Marsha
Just call me: Jason
B'Town
Barbados
I think they have a new favorite Uncle.
Old Mon 21 January 2013, 08:11
marko cro
Just call me: Marko #107
Dakovo
Croatia
If still not, this would seal the deal
Great work, an inspiration for all of us still building one
Old Thu 24 January 2013, 18:28
Figured I'd start making my own pegboard....lol
Actually its the top for a downdraft sanding station.
Old Thu 24 January 2013, 20:53
Well, I know it works. you may want more holes closer spaced.
Old Thu 24 January 2013, 21:06
Regnar
Just call me: Russell #69
Mobile, Alabama
Darren that is going to be a huge down draft table. Cant imagine the size of the blower you going to need.
Old Fri 25 January 2013, 01:17
I'm going to use 2 HF dust collector fans mounted inside.
A buddy has a similar setup and it works pretty well.
Should be (If you trust HF specs) roughly 3000 CFM.
I'll still have the RO sander hooked to a shop vac too.
We'll see.
Old Fri 25 January 2013, 01:53
Sure make life a lot easier with MM boring out hundreds of holes while you watch
Old Fri 25 January 2013, 06:21
416 holes to be exact.
I'm going to make some 2" square blocks with 1" dowels, to insert in a hole to hold work for beltsanding.
Beauty of a MM?
If I need to make a top with a greater number of smaller holes, I'm only out the cost of 1 sheet of MDF.
Old Fri 25 January 2013, 17:29
barry99705
Just call me: Barry
Xenia
Beauty of a MM?
Or just offset the pattern to put a hole in the middle of four adjacent holes. I think I'm explaining that right.. Kinda like looking down at a crap ton of dice sitting on 5.
Old Tue 05 February 2013, 19:25
Almost everyone with a CNC at some point carves The Last Supper. I'm not overly religious, but thought I'd give it a go.
When my parents moved to Kentucky a few years before my dad passed, I was given the top to our dining room table, which he had made when I was a year old. His words were "cut it up and make something if you want, if not burn it."
It was a pair of 6/4 15" wide sugar pine boards with a simple breadboard end, and had seen better days, being 40 years old at the time.
Everyday lately, when I'd walk past it leaned up against the wall, it would whisper " are you ever gonna build anything with me?"
Finally, I decided to cut it into four blanks, and machine a Last Supper carving on each blank. 1 for me and each of my three siblings.
I picked a quiet day in the shop, and agonized over cutting up something my Dad had made while I was in diapers, but I felt pretty close to him after I got started, and figured it was a pretty fitting tribute to the Old Man who gave me my love for woodworking.
WE fought like cats and dogs while he was alive, and I miss him a lot.
Old Tue 05 February 2013, 20:16
Darren, I'm sure you'll cherish it always. Very nice.
Old Wed 06 February 2013, 02:34
thanks for sharing a private situation as such.
Compelling !!
.....and nice work
Old Thu 07 February 2013, 09:45
IMMark
Just call me: Mark #119
Columbus Ohio
Very nice Daren.
Lost my dad in Nov. 05, I still think of him everyday. He was a woodworker as well (and self proclaimed tinkerer). It is where I got my start and some of my best memories are of holding the end of a long board for him when I was 5 or 6 years old.
Thanks for sharing!
Mark
University Of Missouri Saint Louis Theater ganderson Introduce yourself and start planning 8 Fri 31 October 2014 17:53
Starting my MM Build - St Louis MO USA inventek2000 Construction started, but not cutting yet 38 Sun 25 September 2011 17:51
my machine cnc marcoscnc29 Archives 1 Sat 24 April 2010 17:58
