Old Wed 22 August 2018, 20:30
Jason Marsha
Just call me: Jason
B'Town
Barbados
Wow. No lubricant?
Old Wed 22 August 2018, 22:46
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Yepp, no lubricant. On shown settings is tool lifetime somewhere between 50-100 cutting hours. I have cut over years tens of tons alu sheets so. Maybe with emulsion it is longer, but i try avoid lubricants. Too messy
Old Thu 23 August 2018, 01:42
YANLM
Just call me: Yannick #129
ST DENIS
Reunion
it's very impressive, nice job. have you a link for the one flute endmill?
Old Thu 23 August 2018, 06:54
ifffff
Parnu
Estonia
Well... They are coming from Estonian reseller with product code what does not lead nohere and here have they EcoStar trademark. Again google isnt sayng nothing.
Sometimes they have engraved Cerin on them and i quess they are 110A.050051450 http://www.cerin.it/catalogue.pdf Page 150
My quote to Cerin had answer that go and buy from your local reseller, so ... propablly they are that ones.
Old Thu 23 August 2018, 07:21
YANLM
ST DENIS
Reunion
ok thks i will take a look.
Old Tue 18 September 2018, 10:59
ifffff
Parnu
Estonia
Made some rope driven blast gates. I think they are better than regular push-pull type gates.
To prevent static electricity buildup i grounded gate. Black material is PE
Serial number for second Mechmate?
Old Wed 19 September 2018, 05:11
Sure looks like you get #130 !! Cool to see two working side by side!
Old Thu 20 September 2018, 05:45
Builder's Log Update
Congratulations on completing your 2nd MechMate. Here is the Updated Builder's Log with your 2nd MechMate entry added. Please review the entry and let me know any changes you me to make.
Old Fri 21 September 2018, 18:25
Well done #130.
Have fun.
Old Thu 25 October 2018, 12:45
ifffff
Parnu
Estonia
I have here some kind of strange problem here with my new MM.
X axis gear is totally worn and gear rack looks worse than my 9 year old #38 gear racks. A and Y axis gear/racks are looking as new. All of them are from same source. Nothing does not seem to be misaligned .... Does anyone have idea what may cause it??
Old Thu 25 October 2018, 14:32
Wooow....can't confirm & no "metal" guru.....
But....say, in my case it was a question of how "tight" or say, how strong is the spring tension "up pulling" the motor to rack ?!
Surly you have check this & fully aware of this, but, sometimes I too tend to oversee the most "obvious"...
Best of luck...
Old Thu 25 October 2018, 21:30
jask
Just call me: John
Kamloops B.C.
I would contact the original manufacturer, the alignment and count look good and that makes me think the gear was not properly hardened.
Old Thu 25 October 2018, 23:20
ifffff
Parnu
Estonia
All three axis have same spring and tensioned equally. And weared is only one gear, so reason cant be over tensioned spring.
I will ask what is answers have gear/rack seller.
Old Fri 26 October 2018, 21:42
Regnar
Just call me: Russell #69
Mobile, Alabama
If I had to guess and this is only speculation I think your gear did not go through a hardening process after it was machined. It became the weakest link and wore out first. You can run a file over it and see how much metal it removes compared to your other gears.
Old Sat 27 October 2018, 02:20
ifffff
Parnu
Estonia
Ok i will try how much it is softer. But all gears what i have used on both mechmates arent hardened. On #38 is gear lifetime 2-3 years hard work.
Old Tue 20 November 2018, 12:31
ifffff
Parnu
Estonia
I made sprocket milling video
Old Tue 20 November 2018, 14:31
nicely executed, love it Mate @_# !!
Old Tue 20 November 2018, 18:44
YANLM
ST DENIS
Reunion
very nice
well done!
Stair Beam Machine !!! #120 - Jõgeva Estonia ilmataat MechMates already cutting 48 Tue 21 June 2016 14:28
MechMates in NE or Central Florida, Jacksonville, FL Metalsmith General - MM Build 15 Mon 28 December 2015 08:18
MechMates wanted in Saudi Arabia Nicolas The Market Place 2 Tue 13 December 2011 04:13
Hi from Estonia! v2ikekresu Introduce yourself and start planning 10 Fri 26 August 2011 09:05
Completed Mechmates Album With Serial Nos. vishnu Archives 3 Sat 25 October 2008 11:53
