Old Thu 07 January 2010, 03:52
Inspiring this lithophan.
Another trick thing I’ll want to make when I’m up & moviing axis
Web site look good, keep on tweaking it, nice marketing tool !
Good luck. Amicalement, Robert
Old Thu 07 January 2010, 15:52
Rad Racer
Just call me: Wayne #25
Minnesota
Thanks everyone, I appreciate all the kind comments and feedback on the webpage.
Old Fri 08 January 2010, 01:21
Wayne, when you use your indexer, is the X-axis stationary? Once in position in the centre of the workpiece, does it ever have to move?... Just thinking for the time I do indexing I can make use of one of the X-axis Gecko's...will be some plug and play system.
Old Fri 08 January 2010, 09:16
Rad Racer
Minnesota
Kobus,
Yes, once the X is in position, it does not move until all the A-axis work is complete. See no reason why the plug-n-play method won't work.
Be careful when you hot switch your motors, not sure how well the Gecko's tolerate this.
Old Fri 08 January 2010, 09:41
aniljangra
Just call me: Anil #44
Delhi
Don't know how tough Gecko are but switching in inductive load like that is BAD for the driver (though motor is stationary, the chopping/switching current is flowing through coils)
Old Fri 08 January 2010, 10:51
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Wayne, the site looks very good on Firefox, not problems noted. Your product is also very impressive. Can I send you a photo for carving?
Joe
Old Fri 08 January 2010, 11:47
Thanks Wayne I thought that would be the case. Therefore my thought is to bring my X-axis in position while power is off. Lock the gantry in place. Undo the one X-Axis Stepper, connect it to the indexer...configure Mach-3 and do my indexing work. I know it sounds like extra work, but if I can save on another Stepper and Gecko to try indexing so be it. If I find it works for me, I might consider another stepper and driver at a later stage
Old Fri 08 January 2010, 14:43
Rad Racer
Minnesota
Kobus,
You may want to shop EBay for another step driver. I have purchased\used the Centent brand on my other mills with good success. I believe Centent's were designed by Marius (Gecko creator) in a previous life.
Look for a CN0142 or CN0162 unit. The primary difference is the max voltage. see www.centent.com for details.
I have never paid more than $50 USD for a controller. Not sure about shipping....it may not be practical for you.
Wayne
Old Sat 09 January 2010, 10:17
Wayne,
I believe Centent is now designed / operated by Mariss' brother. I remember Mariss speaking of Centent on some of his old posts.
Old Sat 30 January 2010, 17:04
Rad Racer
Minnesota
Charging power supply boxes
I designed these boxes around some surplus power supplies that I found. These are industrial switching supplies that will work perfect for charging the Li-Po batteries we use in our RC airplanes. I decided to built boxes for all (5) of the powersupplies....thinking my RC buddies will want one of their own
The tab and slot design makes the boxes self-aligning....and really easy to assembly The first two boxes were cut one at a time to test the G-code, the parts of the last three boxes were nested, so they could be cut in one operation.
Old Sat 30 January 2010, 19:19
Regnar
Just call me: Russell #69
Mobile, Alabama
Very nice, I like the fan cover I might steal it for some of
my future projects!
Old Sat 30 January 2010, 19:48
Awesome! No nails! love the fan cover too!
Old Sat 30 January 2010, 20:05
Nicely done Wayne.
Old Sun 31 January 2010, 05:56
Rad Racer
Minnesota
Ken, I really like designing with tabs. They allow you to assemble the whole project, make sure it is square, then hit each joint with CA glue (or other) to make it permanent. No nails
Glad you like the fan cover. Although it looks cool, it isn't very strong, so I changed the design on the remaining boxes so I could use a traditional wire fan cover.
Old Sun 31 January 2010, 12:04
Claudiu
Just call me: Claus #43
Arad
Great boxes, I like the tab design. I'm working on wine boxes with those tabs...
Old Wed 03 February 2010, 18:18
Rad Racer
Minnesota
Wow, those will be some classy wine boxes. My wife likes wine in a box.....but the box is usually cardboard.
Old Tue 23 February 2010, 08:02
Rad Racer
Minnesota
My latest project. It's a foldable flightstand or table to be used at the RC flying field. Saves you from working on your knees.
The design is based on a picture I found on the internet. The entire project was designed in 2D, then modeled in 3D so I could determine how the assembly would foldup and check for proper clearances, before cutting any material. I find this technic not only saves time, but it saves a lot money because I do not need to makes parts over because of design mistakes
The material is baltic birch plywood. This is a high quality plywood, often used to build cabinets or furniture.
This project was cut in two operations. The first op used a 1/8" endmill to cut the pockets, grooves and holes...the second op used a 1/4' to cut out all the parts.
Old Tue 23 February 2010, 08:13
Awesome! Having a few of these in the workshop would really come in handy too...
Old Tue 23 February 2010, 08:54
What are you drawing these plans in?
Old Tue 23 February 2010, 08:56
Wayne, that looks awesome!
Old Tue 23 February 2010, 14:33
Travish
Just call me: Travis #75
Wa
I wanted to ask the same thing. What program are you using to do the tabs/slot, and nesting in?
Travis
Old Tue 23 February 2010, 15:59
Rad Racer
Minnesota
I primarily use MasterCam for the flat work.
I have tried the auto nesting function, but still prefer to manual place parts on the panel.....you have better control of the machining operations.
Old Wed 24 February 2010, 04:49
Nice little table Wayne, surly the envy of other RC fellows !
I Like....
Old Wed 24 February 2010, 17:52
Drad98_98
Just call me: Dave #52
Fort Ripley, MN
Cool tables Wayne, I might need to steal your dxfs, I posted some new pics of mine tonight, check it out. Still on for March 6th for the tuning and first cutting session!
Old Sun 28 February 2010, 14:35
chef des jeunes
Just call me: chef des jeunes
Yaounde
Cameroon
Get in touch
Hi Wayne,
You have build a great machine.
I have no experience with CNC machine but I would like to build one. I 'm in Minnesota(Saint Paul) and would like to visit you and have a discussion if that's ok.
Old Mon 01 March 2010, 11:48
Rad Racer
Minnesota
Sure, I would be happy to talk with you, perhaps we can grab some lunch.
Are you just visiting Minnesota? If so, what are your travel dates?
Old Tue 02 March 2010, 06:50
chef des jeunes
Yaounde
Cameroon
Call me: Gaston
I'm not visiting. I leave here with my family. Having lunch will be a great idea. I'll give you a call(I got your number from your website).
Old Fri 02 April 2010, 08:35
Rad Racer
Minnesota
Latest Mechmate project.
Been busy with my MechMate, thought I would post my latest project.
This is an autogyro I am building from plans. The first thing I did was to translate the paper plan into CAD....is was a very manual process that requires all lot of measuring and guessing The tabs were added to the original design to make it easier to assemble.
The blades were also cut on the MM, took awhile to figure out exactly how to develop a cut file...it worked in the end.
enjoy,
Wayne
Old Fri 02 April 2010, 08:37
Rad Racer
Minnesota
Finished Autogyro
Here's a picture of the finished model.
Old Fri 02 April 2010, 09:26
Very cool! It's great when you can combine two interests.
Thanks for sharing your work...keep it coming!
Wayne's Custom Pendant Rad Racer Human Interface Devices (HID's) 17 Tue 14 December 2010 19:15
Hello from Minnesota! Rook3 Introduce yourself and start planning 13 Mon 17 May 2010 22:52
7 core cable to junction boxes riesvantwisk 60. Wiring & Cable Management 12 Sat 14 November 2009 09:08
Keyboard/pendant solution Art Human Interface Devices (HID's) 7 Fri 19 June 2009 06:41
Gantry & Car Control Boxes, switch info ? kanankeban 70. Control Systems 0 Sat 21 February 2009 11:01
