Old Thu 27 April 2017, 21:41
IamDave
Just call me: Davey
Ball Ground, GA
Nice I picked up a few ideas watching you. Thanks.
Old Tue 02 May 2017, 17:42
Borko
Just call me: Techstarve
Veles
Macedonia
We are here to share the information and possibilities. I'm glad to hear you find something useful Davey.
Borko
Old Tue 11 July 2017, 13:46
Borko
Veles
Macedonia
X-rails alignment
For rails alignment I decided to use piano wire method.
I couldn't find wire in local stores, so E-bay offers great stuff.
This is the link:
http://www.ebay.com/itm/304-Stainles...GZJ9AHl1Thx9Bw
and is quite inexpensive.
It's 0.4mm SS304 hard steel wire.
I hope it will be of help for other builders.
Old Tue 11 July 2017, 14:14
Borko
Veles
Macedonia
X-rails alignment
I didn't want to drill or tap in main beams for wire supports so came out with this solution. Additional welded metal strips to maintain in place 45 degree strip.
To fix the supports clamps are used.
M6 screws in height adjustable milled channel.
The counterweight is 13-14 kg according to Sag-wire chart.
Old Sat 15 July 2017, 09:56
dbinokc
Just call me: DB #118
Oklahoma
Is there a reason to prefer wire over fishing line when doing alignment?
Old Sat 15 July 2017, 10:35
Yeah, someone else has already figured the sag measurements for that gauge.
Old Mon 17 July 2017, 19:31
fishing line tends to get stretched and thin in the middle throwing off the datum.
Machine now cutting!....Seahorses! - Skopje,Macedonia Pajka MechMates already cutting 99 Wed 17 August 2016 14:41
DIY drives from pminmo, Cutting Video, #59 - Bitola, Macedonia gorantec MechMates already cutting 61 Sat 19 October 2013 04:13
rack and pinion in Macedonia casi Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 10 Sat 03 September 2011 14:00
Need help with rack dimensions :( - Bitola, Macedonia gorantec Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 4 Fri 10 April 2009 08:19
