#121
Wooaow....that was fast
![]() Congrats....many hrs of fun to come Enjoy ![]() |
#122
Its Alive! Excellent Job Al!!!
#123
Bravo!
#124
SWEEET!!
Great job. |
#125
Thanks for the kind comments.
Just run its first proper program. 144 holes 10mm dia in the spoilboard for my clamping arrangement. 1 hour 55 minutes. ![]() |
#126
Awesome !!! Now for some logos !!!
#127
Moved
Wow !
Its moved and I have been moved. I spent the afternoon installing the T nuts. Boring but it had to be done. More to do tomorrow weather permitting. The remains of " Typhoon Wutip " are heading directly for us. I had a lucky escape this afternoon. The machine was powered down. I was using a pistol drill to finish some holes. The pinions were engaged so I was using both hands to move the gantry. The gantry stopped, without thinking I gave it another pull. It moved a bit. Then I realised something was wrong. The extension cord was wedged under a V wheel. The cable was thin so I was lucky I did not give it another pull. Next time a proper extension lead and not across the machine. Been a bit ironic if me and the machine were finished on the same day. ![]() |
#128
Spoilboard
Z slide & Router squared to the bed.
Spoilboard faced. Logos on order. Getting there. ![]() |
#129
Glad you averted the close call with the cord.
Machine is looking really good. |
#130
looks like your spindle is not 90degrees on the y x axis. that make a pattern when you face the spoil board.
there is a easy system with a wire and a drill bit to calibrate the spindle. i cant find any tutorial online. i have to make one. |
#131
There are 2 ways to set yout Z axis perpendicular to XY plane.
1) the simple way. eye balling a set square the cutting bit to the table (after it is surfaced 2) the complecated way which I won't go into as it is very well documented somewhere in this forum. |
#132
Super quick and easy way........
Cut a 24" x 24" square double or triple thickness FLAT MDF/PLY base....drill 1/2" hole in middle Chuck up router/spindle in collet - then tighten the machine world around the base and spindle. Surface the table. Do it again, this time use a L shaped scribe and feeler gauge if needed to set the pitch/yaw of the assembly. Personally, I used (2) framing squares to set the z-plumb in the y carriage in the x and y direction. Then I connected the router to the z and did it again.....The second time I did it the first way I described and saved about 3 hours. |
#133
Thank you for your concerns and comments.
I squared it using the facing cutter. Perhaps not perfect but good enough for what I want to do for now. I am very pleased with the machine and its performance. I ran a test this morning. Everything cut the right shape and size. Like a hot knife through butter. ![]() |
#134
Logos
One MechMate reporting for duty Sah !
#135
..definitely has the logo part covered!
![]() Congratulations...happy cutting |
#136
I thought I had a lot of logos.....lol.
Just kidding, machine looks great. As you gain experience, you will look at every project, no matter how simple, and think: How can I do this with the MechMate? |
#137
Jolly good!...carry on...
#138
I like the motor logos !!! You get #114 !!! Congrats !
#139
Yahoo !!!!!!!!!!!!!!!!!!!!!
A number, thank you very much. Very happy to be here. I saw the .dxf for the motor logos. Someone said about keeping dust out of the rear bearings, so I ordered a set. The blue is a bit darker than what I wanted but it might fade with the sunshine. I said in my first post that I spent 25 years on other peoples machines. Now I have one of my own. Absoutely brilliant. Thank you all. Now I had better go and do some work. ![]() |
#140
Now its time to start building cool stuff.
GREAT JOB!! (I have the same motor decals on mine.) |
#141
Happy dusting Al.
![]() Looks very nice. |
#142
Congrats! Looks great!
#143
Updated Builder's Log
Al,
Here is the Updated Builder's Log with your entry added. Congratulations on earning Serial #114 on a great machine...and FAST too! |
#144
On the Masthead
Thank you Gent"s.
Number nailed to the Mast. Thanks for updating the build log. Just a small point on the "Builders Log" The Y travel is 696mm (It could be somewhere over 700mm if I changed the hard stops) What is a "Small form factor ? I think the build hours are about average. It took me about 500 hours but I had nothing else to do all day. Now I have something to do all day every day. ![]() |
#145
First Project
Congrats on your build. Can't wait to see your first project(s).
#146
Detail
I had a play about this afternoon.
Quite impressed with the small detail on the rose (30mm dia). A bit like watching a Sumo wrestler dance in a Ballet. Well pleased. The rose is in Tamarind.(End grain) The ship in Padauk. |
#147
I love it!!! Sumo at a ballet!!! Good description!!
#148
Work in progress
I had a couple of cable drum ends(plywood) that I salvaged a couple of months back.
I saw Darren Salyers gear and thought why not. Glued some mdf offcuts to the ply. Well impressed the way my machine cut the teeth. I will have to turn it over to cut the teeth full depth as the cutter was too short. Hope to finish machine it tomorrow. |
#149
I'm jealous, everyone is making their own gears but me
#150
Don't worry Tom.
One day soon you will be heading away from the kitchen table and carving signs "Get your gear here" ![]() |
| Started making windows with the mechmate ... #70 - Rome, Italy | silverdog | MechMates already cutting | 100 | Wed 26 April 2017 22:02 |
| Lookin for Gremlins - Isarn, TH | lonestaral | Troubleshooting | 8 | Mon 02 November 2015 12:10 |
| Oh Can I ?? - Phuket Thailand | jek | Introduce yourself and start planning | 10 | Fri 24 June 2011 05:55 |
| Newbie to CNC - Chiangmai Thailand | chainarin2553 | Introduce yourself and start planning | 1 | Wed 15 June 2011 05:27 |
| Free Cad and Cam HeekCNC Windows & Linux | Regnar | CAM | 0 | Thu 16 September 2010 19:24 |
