Old Mon 04 November 2013, 10:05
Need a shot of the machine with logos.
Old Mon 04 November 2013, 21:16
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Time for Metalhead
Send message to Mike Ray aka Metalhead
Old Tue 05 November 2013, 20:19
Zouave
Just call me: Eric #115
Sacramento, CA
Up and Running
Well, I should post this before everything gets messy! Because its about to. I have to true up the Z-axis a little still, but we're getting close. As soon as I'm done with the current project (which doesn't need the Z to be perfect) I'm going to go through and adjust the rollers a little bit. I'm only a couple thousandths off currently. Shouldn't be too much of an ordeal to get it right. :-)
File Type: jpg 965727_10151765035379436_1267752887_o.jpg (60.2 KB, 826 views)
Old Wed 06 November 2013, 13:21
I see you made a little more robust cable chain attachment on the y carriage.
Was that to get your chain - in - plane or did you need an alternate hole pattern?
Old Wed 06 November 2013, 15:11
Zouave
Sacramento, CA
I didn't like how sharp the bends were coming out of the cable chain, just attaching to the pre-drilled holes. I need to cut out a couple of links on the chain, unfortunately, because I increased the length of the cable chain with the bracket. It also had the added benefit of bringing it more in-plane, and making that corner a little easier for the cables to go around.
Old Wed 06 November 2013, 17:34
Zouave
Sacramento, CA
Well, in running today, I'm a little concerned about my motors. They are definitely warm to the touch. I'm using MotionKing 34HS9801s, specs are here.
I'm going to adjust them tomorrow at the trim pot off my Gecko 203V's, as they screech a little while I'm running at speed. I tuned them before, but I think I was moving absurdly slowly compared to how they're running now, so that may be part of the issue, I think? Would that be something that would generate excess heat? They aren't hot enough to burn my hand, but they're certainly uncomfortable to leave my hand on.
Thoughts anyone? They'd been on (though just holding position for a fair amount of the time) for about 4 hours when I noticed it, but had noted the heat they were generating before that as well.
Also, had my first 'accident'. I misunderstood how helices were programmed, and managed to plunge my bit directly into the work, instead of a nice helical progression downward. Any G-code Gurus want to explain how the P descriptor works in a G2/G3 command? I assumed that, based off what I read, it set the number of rotations to reach the final depth, but that is apparently NOT the case.
Bit survived, my toes and fingers survived, machine survived, but it lifted the piece out of the clamp as it retracted when I hit the E-stop. Lesson learned: side clamping is insufficient, clamp downward as well. That and use downcut, not upcut spirals.
Old Wed 06 November 2013, 19:24
Mrayhursh
Riverview, Florida
Lathe Crash
sorta did the same thing today with my lathe. Had the feed rate set to high and crashed a tungsten carbide bit into steel part. crack!!! Trash bit and part.
Old Fri 08 November 2013, 16:45
Zouave
Sacramento, CA
Ouch! You have a Mechmate Lathe, or another kind?
Old Fri 08 November 2013, 20:52
Mrayhursh
Riverview, Florida
Grizzly
Sorry, I have a Grizzly G4003g lathe and a Grizzly G1007 Mill. Both are fun to play on. I am trying to learn how to cut threads with it. The general stuff I learned after I came out of trade school. I worked for a Fortune 500 company in one of their proto-typing labs.
Old Sat 09 November 2013, 09:00
Zouave
Sacramento, CA
Very nice. How do you like that mill? I did a lot of manual machining in high school and first few years in college (but that was 10+ years ago), but the CNC world is a lot newer to me. Loving it, though. This MechMate is amazing. Finished a project yesterday in 2 days work that, previously, would have been about 60 hours. Got it down to 16 on the machine, with about 6-8 spent on the computer. And that's with a couple of more spectacular screwups too. :-P
I picked up a metal lathe on Craigslist last year that I'm just now getting around to tuning up. It needs it pretty badly, but I'm optimistic I'll get it pretty well dialed in by the time I'm done with it. Its an old Clausing 12x36 bench-top model. Next thing to get is a proper tool-holder. The old ones just aren't as stable as I'm looking for. Think I'm going to get a knockoff Aloris, the wedge type...
Old Sat 09 November 2013, 11:36
Mrayhursh
Riverview, Florida
Grizzly G1007
I really like the Mill. Someday I would like to convert it to CNC
Old Sun 10 November 2013, 16:36
timberlinemd
Just call me: Steve #66
Arizona
Did Mike ever give you a number?
Old Sun 10 November 2013, 17:43
Zouave
Sacramento, CA
Not yet.
Old Wed 20 November 2013, 22:03
timberlinemd
Arizona
Mike give him a number!
Old Wed 20 November 2013, 22:24
Mrayhursh
Riverview, Florida
Ok
Please send Michael Ray aka Metalhead a private message.
I am Michael Ray Hursh aka Hurshey
By the way you were mentionimg that you wanted to get an Aloris post. Do it. I love mine. I just added two more tool holders. I bought right and left cutting tools with tungsten carbide inserts. I also bought the knurling tools. I have modified a couple of tools. It improved their functionality and safety. Best of luck.
Old Sun 08 December 2013, 06:29
Wow - I cant believe I have not given this machine a number !!
You get #115
Sorry for the delay on this one !!!
Congrats !!!
Old Sun 08 December 2013, 18:50
Updated Builder's Log
Eric,
Congratulations on completing you MechMate, Serial #115.
Here's your Builder's Log entry.
Please let me know the "cutting dimensions" of you MechMate for the Builder's Log. I see the mention of 9' X 5' and 10' X 5', but I notice your comments about these being the overall dimensions, rather than the cutting dimensions.
Old Mon 09 December 2013, 06:02
Well done #115.
I am glad that someone else has taken the baton.
Long may this relay run.
Old Mon 09 December 2013, 10:56
Zouave
Sacramento, CA
Thank you! I don't suppose anyone has a font set for the MechMate logo, as I want to design up a few more decals and add a serial number to the mix on the control box?
Next up: Dust collection foot, because Holy Dust Everywhere, Batman!
Old Mon 09 December 2013, 12:25
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Congratulations on your now numbered machine, she looks good.
You can find the logo in dxf format together with laser cut parts designs.
Old Mon 09 December 2013, 18:40
Logos
These should do you.
The # and number I drew and printed on to paper.
I cut them out of spare material from the MM logos from the print shop.
I cut them out using a straight edge and a razor blade.
Hope this helps you.
Old Tue 10 December 2013, 13:44
timberlinemd
Arizona
Mike, A.K.A. Rip Van Winkle, nice!
Congrats on a number!
Old Tue 10 December 2013, 14:38
Zouave
Sacramento, CA
Thanks! By the way, cutting area is 5'x8'. I'd originally planned on doing a 5x10 with 2' of that dedicated for a 4th axis on the end, but I'm just going to build a small purpose-built rotary MechMate. So I scaled down to 5x8 cutting area as my base machine. :-)
Old Wed 11 December 2013, 07:04
Thanks for the dimensions, Eric. I've updated the Builder's Log, here.
Old Fri 13 December 2013, 07:11
Andrew_standen
Just call me: Andrew #109
Dorset
Congratulations on your build number.
Nice looking machine.
Old Sat 14 December 2013, 10:48
Great Job Eric.
Old Sun 15 December 2013, 19:26
Congrats on a fine build!
Old Sun 15 December 2013, 20:29
sierra347
Just call me: Armando #110
Montgomery, IL
Congratulations on 115 Eric!
Old Wed 25 December 2013, 22:05
Zouave
Sacramento, CA
Thanks everyone! Been a busy month with lots of sawdust made, but I ran into some issues very abruptly yesterday. Plunged a bit when it wasn't spinning, caught it and stopped the program running. But now I'm suddenly getting odd movement on two motors. On the Z-axis, I'm getting intermittent loss of power, and some odd grinding noises. On one end of the gantry, I'm also getting odd grinding sounds, periodically unpowered motor, and very unpredictable motion, almost like it is getting random signals. I thought it might be electrical noise, but with the loss of holding power on one end of the gantry, I really doubt that. Thoughts? I've gone through and checked my wiring, it appears to be in good condition, but I'm going to take a multimeter down there tomorrow and see if I can't sort it out better. Anyone have something similar happen and know what the deal is?
Old Wed 25 December 2013, 23:51
Have you checked that the gantry and Y-car is still well seated on the rails, I have had a few occasions where after a crash or stall that the wheels are not seated properly.
