Old Wed 30 March 2011, 13:25
melissa
Just call me: Melissa #83
Brighton (Ontario)
I'm using 4x8 sheets across the width of the table, cut to 1900mm [74.8"].
They'll be joined with biscuits, and glued with PL Premium construction adhesive. I'm confident that the glue joint will be stronger than the MDF.
That's why so many sheets... the table is a bit more than four sheets long.
Old Wed 30 March 2011, 13:31
...staggering the joints on the top layer?
Old Wed 30 March 2011, 13:38
melissa
Brighton (Ontario)
Of course. The 4' section from 0,0 will be in the top layer, to make resurfacing easier. I expect that not all areas of the spoilboard will wear away equally quickly.
Old Wed 30 March 2011, 23:06
melissa
Brighton (Ontario)
Here's a shopcam photo of the painted MechMate.
The drop sheet has been rolled up, as I need to drill 96 holes from underneath to mount the support board. The wheels on my mechanic's creeper would not do well on the plastic.
Once all the holes are drilled, I'll roll out the drop sheet and close the tent once more, to glue the parts of the spoilboard together. The glue needs 20C to dry properly, and it's still hovering around 5C in the workshop.
Old Thu 31 March 2011, 07:43
Melissa,
Great work. It's fun as always to be here from almost the beginning and see 70+ machines built. Only one other machine equals your in size and length and it was used to cut aluminum boat hulls.
Can I ask what your intentions are to use such a large platform for cutting?
Old Thu 31 March 2011, 09:06
melissa
Brighton (Ontario)
Sean,
my intentions were to build a large machine once because I had the space available . I didn't want to find myself wishing the table was a bit longer, after the fact.
It's such a common predicament in boat ownership that it has a name: "two-foot-itis" . Wishing your boat was two feet longer.
As for cutting... right now I'm looking at stitch&glue plywood boat kits, as well as folded horn subwoofers. Beyond that, who knows. I've also got a lead at the local lumberyard. Apparently carpenters in my area are looking for someone with a CNC router. All good prospects!
BTW, I'm already happy I went wider than the "usual" 48" cutting width. Baltic Birch (which I use for speaker cabinets) comes as 5' x 5' sheets. It would be silly to have to cut them with a circular saw, just to fit them on the MechMate!
Melissa
Old Thu 31 March 2011, 13:47
...All reasons why I built my first table as a 5' x 10' table...then wished I made it for 5' x 12' sheets!
You might find yourself doing some custom work where you can dedicate one end of the table for vacuum or special duty purpose fixture work and keep the general area clear.
Thanks for the reply.
Best on the rest of the build.
Old Fri 01 April 2011, 12:36
melissa
Brighton (Ontario)
Work starts on the spoilboard:
Old Fri 01 April 2011, 12:45
Melissa, looking good, Ahhh Princess Auto, I love that store.
For you US guys, Harbor Freight is the same thing.
Old Fri 01 April 2011, 15:30
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Coming along nicely, bolting it down will be fun Keep working at it, its one heck of a machine to use!
have you seen delftship, its free and exports dxf files just your size
Tim
Old Fri 01 April 2011, 16:48
camilleg
Just call me: Camille
Urbana, Illinois
Tim, delftship sounds cool -- particularly that Melissa doesn't need to second-guess their translations to English.
Heath, them's fightin' words! Comparing The Princess to Harbor Fright is like comparing Tim Horton's to Starbucks. Don't do that if there's Canadians within earshot that you can't outrun.
(Oh yeah, Melissa, serious milestone reached there, moving from metal to wood at last.)
Old Fri 01 April 2011, 19:07
Camille,
Not comparing, just giving the closest reference I could think of. Maybe Princess should go to the US too! Although it would probably be nice to have a HF close to me just over the border.
Old Sun 03 April 2011, 22:35
melissa
Brighton (Ontario)
Did I mention the table is long?
Support board (5 pieces!) slotted for biscuits, and all holes drilled. Next up is recessing the holes with a forstner bit, and installing it permanently with glue between all sections.
Old Mon 04 April 2011, 09:23
camilleg
Urbana, Illinois
That's enough biscuit-joinery to prevent Quebec from leaving Confederation.
Old Mon 04 April 2011, 12:49
Looks like a MechMate runway !!!
Old Mon 04 April 2011, 13:09
Aircraft carrier
Old Mon 04 April 2011, 13:34
camilleg
Urbana, Illinois
OK that's 3 in a row... Melissa, when you crack a bottle of bubbly on the prow, please christen her the H.M.S. Hyperbole.
Old Mon 04 April 2011, 16:37
melissa
Brighton (Ontario)
Two more photos of the table top, with bolts temporarily installed:
Old Mon 04 April 2011, 17:04
Aw, now I gotta chime in too ... Since you've got the spikes in place, how about telling us which cities are at the ends of your rail lines?
Nice looking table, BTW.
Old Mon 04 April 2011, 17:55
melissa
Brighton (Ontario)
How do you drill a recess with a forstner bit, when there's no wood left to guide the point? Answer: add some wood around the outside . Here we go.
I made six guide blocks from off-cuts of the spoilboard. Each was drilled with a forstner bit on the drill press, all the way through. Top view:
Bottom view: note the beveled edge (we'll get to that in a minute)
The guideblock is placed over the hole, and visually centered:
And then I used a brad nailer to drive two 1-1/4" 18ga brads through into the spoilboard, to hold the guideblock in place:
Old Mon 04 April 2011, 17:59
melissa
Brighton (Ontario)
I need a drill collar, but that doesn't work very well when the bit is this large! So the collar gets larger:
When the collar touches the small piece of wood, the drill is deep enough:
And what it looks like when it comes out:
Old Mon 04 April 2011, 18:06
melissa
Brighton (Ontario)
Now to remove the temporary guideblock. I use my renovator's bar (like a crowbar, but it's much nicer to the wood). This is why there's a bevel on the bottom edge -- easier to pry it up.
Here is the newly recessed hole, with the guideblock:
Checking the bolt for depth. I didn't want to press it in yet, as the boards still need to come out to be glued.
Even with six blocks, they need to be re-used 16 times, so I need to remove the brads. They're too thin to hammer out, and you can't pull on the point, so I use vise grip pliers and my renovator's bar:
Here is the removed brad:
Easy! Only 95 left to go .
Old Mon 04 April 2011, 18:14
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
I just eyeballed mine!, one heck of a job. Once you resurface your going to have to seal it all, I used water based polyurethane. Worked great
JamesJ
Kansas
Melissa, give double sided tape a try instead of the brads.
Old Mon 04 April 2011, 21:44
melissa
Brighton (Ontario)
Too late, all that drilling is done now.
Besides, I wanted something that would be strong to sideways forces, but weak vertically. The brads worked like a charm.
Old Thu 07 April 2011, 23:18
melissa
Brighton (Ontario)
Top layer of the spoilboard is ready to be glued in place.
I filled the bolt holes with "bondo" polyester filler. The top sheets will also be joined with biscuits, though I'm using regular white glue for this layer.
The biggest challenge was where to put the four sheets I needed. They had to be inside the tent to be warm, and off the table for glue application, but the tent isn't big enough for sawhorses at either end of the table...
OK, looks like we're going up instead .
Old Fri 08 April 2011, 00:24
Did you use "bondo" before tightening the screws?
My idea, after suffering some loosening with time, was to tighten the screws first and then pour in a thin resin. That resin is meant to soak into the porous MDF around the screw head, especially into cracks that may have formed while the heads bit into the wood. It makes for a "harder" bond between screw and board, over a slighty bigger area than just the screw itself.
Old Fri 08 April 2011, 09:48
melissa
Brighton (Ontario)
I used bondo after tightening the screws.
I did opt to use lockwashers, so there's some spring tension that will hopefully keep things snug. If it really becomes a problem later, I can always put on a new spoilboard. We'll see, I guess.
Old Fri 08 April 2011, 10:01
camilleg
Urbana, Illinois
It would be messy, but to really spread the load beyond the screw heads, adhere the lower half of the spoilboard to the full length of each crossbearer (or even just a one-foot bead near each bolt). Sure, it's gluing onto paint, but the bond isn't strongly stressed, and down there nobody will see how ugly it is. Wait 'til Canadia warms up and the tent comes down, and then sacrifice a tube of PL Premium to the cause.
Old Sat 09 April 2011, 16:28
melissa
Brighton (Ontario)
At last, assembly starts. The spoilboard is done, the tent is gone, and the rails are in place!
dust collector capacity gorantec 55. Dust Management 15 Thu 19 November 2009 19:24
Dust foot and custom clamps done #3 - Conway, AR Doug_Ford MechMates already cutting 195 Mon 13 October 2008 20:27
Dust collector foot Art 55. Dust Management 5 Sun 17 June 2007 13:09
