Old Wed 24 December 2008, 18:50
Yuri,
Best wishes for you and your father.
Old Thu 25 December 2008, 06:10
YRD
Just call me: Yuri #17
Brasilia - DF
Brazil
Gerald, Nils, Heath and all other MM builders.
Thank you for your consideration.
Thank you for this Project, which helps control my demons.
MM again, as it is for this that we are here.
Old Sat 27 December 2008, 19:11
We are praying for your father and your family. ...
You have done well on your project, but family comes first! We will be here when you return.
Old Sun 28 December 2008, 15:12
YRD
Brasilia - DF
Brazil
Suggest you cut 9mm off the plate, then get it all nice and parallel, mount the rails, and then measure for the bearing space again.
This post was taking my sleep.
I cut straight, parallel and beautiful?
Gerald, I have two left hands.
After thinking a bit, I have found the solution to cut a plate.
Fixed the plate to a angler. A angle table and fixed the cut. I think it was good.
Maybe someone has a simpler solution.
Jack thanks for your message.
I'm doing this.
Work helps to liberate the mind.
Old Sun 28 December 2008, 19:31
YRD
Brasilia - DF
Brazil
Z-Slide
OK the cut was perfect.
Now I am with this question:
The rail has 100mm. The Z-Plate has 87mm.
But the rails do not come on board.
Is still wide.
What's the solution ?
Cut the plate or increase the distance of the holes more than 132mm ?
Old Sun 28 December 2008, 19:35
Yuri,
Your small tabs on the spider are not bent at 90 deg? What is the reason to having your holes in the Z plate offset? Or am I seeing things?
Old Sun 28 December 2008, 20:54
YRD
Brasilia - DF
Brazil
Because the company that made the bend could not do.
I am still thinking how am I going to do this.
I do not understand this part. " What is the reason to having your holes in the Z plate offset? "
Old Sun 28 December 2008, 20:57
gmessler
Just call me: Greg #15
Chicago IL
Yuri,
I read somewhere on the forum that some people had cut the tab off and welded it back on in the right position.
It looks like that is the way mine had been done.
Old Sun 28 December 2008, 20:59
gmessler
Chicago IL
Yuri,
I see what Heath is talking about. If you look at the pic of your z plate it looks like the holes are offset to one side (not centered on the plate).
Last edited by gmessler; Sun 28 December 2008 at 21:01.. Reason: wrong information
Old Sun 28 December 2008, 21:11
Yuri, 2 left hands but smart thinking!
Why do you already have the 6 rollers mounted before finishing the width of the slide? Did I give a 132mm dimension by mistake somewhere?
Also see this post. Measure the rollers against the slide as in that photo, then you can calculate the final width. (11mm different)
Old Sun 28 December 2008, 21:26
YRD
Brasilia - DF
Brazil
Heath and Greg M,
There is no optical illusion. I picked one side to cut.
I did not want to cut the two sides to have the correct angle.
132mm in 10 40 432.
Mount the V-Roller to make sure the size of the plate
This is the question. I measured as the photo and was 127.85 mm
What to do ?
Old Sun 28 December 2008, 21:32
YRD
Brasilia - DF
Brazil
Now I understand the 11mm.
The correct value is then 143mm.
Correct ?
Old Sun 28 December 2008, 23:01
The drawin gives the 132mm inside brackets as (132), which means to check it first. Also it says "approx TO SUIT SLIDE & V-ROLLERS" which also means to check it against the slide and rollers. (Americans work with 4" plate that is wider than 100mm.)
You will have to make a new slide plate because all those holes must be center on the plate (to prevent problems with the pinion gear & rack and the gas spring). When you make the new plate, you can make it to the right width to fit the rollers.
Old Mon 05 January 2009, 10:07
Nikonauts
Just call me: Nikonauts
Johore
Originally Posted by YRD View Post
Thanks Domino, more photos
License to change his project.
Y original 2350
My roller: http://www.yi-tong.com/
Purchased in Brazil for about U.S. $ 35.00
You already knew this manufacturer?
Here are several taxes . For you to be less
is that US$35 per piece or for the whole set? i assume it's 14 rollers total?
Old Mon 05 January 2009, 13:23
YRD
Brasilia - DF
Brazil
Per piece.
I am in Brazil and several charges.
US$ / R$ was different today.
Old Tue 06 January 2009, 02:27
Nikonauts
Johore
Per piece.
is that $35 per unit?
Old Tue 06 January 2009, 04:28
YRD
Brasilia - DF
Brazil
01 V-Roller - US$ 35.00
Old Fri 09 January 2009, 10:18
YRD
Brasilia - DF
Brazil
Smile
I would like to inform you that:
Yesterday, in an initial test, which reached a speed of: 1.100 mm/s.
Acceleretion: 2.000mm/s2
Step loss of 1.200mm/s (72.000mm/min or 2.834 ipm)
Unit: Smile Unipolar
EMC2
Direct Connection (without reduction, for now, right JR )
The construction continues.
Thanks Gerald for the great project .
Old Fri 09 January 2009, 11:06
Video ; video ; video ; video ; video ; video ; video !
Old Fri 09 January 2009, 11:27
YRD
Brasilia - DF
Brazil
Gerald, wait a little longer.
Present it now will make me ashamed.
The best speed in continuous use is 600mm/s (36.000mm/min) that I believe should be the default for Direct Drive (no reduction).
Not bad for big motors.
BUT, consider that the tests are empty.
Old Fri 09 January 2009, 18:17
gmessler
Chicago IL
Great Job Yuri!
Old Sun 11 January 2009, 21:31
Way to go Yuri...looks like you are spending more time on MechMate than on your motorbike at present......must be the addiction..
Old Mon 12 January 2009, 10:11
YRD
Brasilia - DF
Brazil
Lightbulb Forbes
I just received a call from Forbes ...
I am revealing a secret to you
I already have a portrait
Old Mon 12 January 2009, 10:28
Yuri, you look just like me!
Old Tue 20 January 2009, 19:40
YRD
Brasilia - DF
Brazil
Z axis
Kobus,
This is really an addiction.
I propose an option for the "Z".
Gerald perhaps to include to BBBs.
Pictures of this change, soon.
Note that the fixed rack on the rail. Seems to work.
Old Sat 24 January 2009, 18:02
YRD
Brasilia - DF
Brazil
MM Testarossa
Hi Kobus,
This picture is for BBBs
Old Sat 24 January 2009, 18:16
YRD
Brasilia - DF
Brazil
More pics
My spindle delayed.
Let's draw.
Old Sat 24 January 2009, 18:19
I like the handlebar picture! ... Congrats on a fantastic pen plotter!!
Old Sat 24 January 2009, 18:27
YRD
Brasilia - DF
Brazil
Smile Happy Birthday Father
Today is birthday of my father.
67 years. Happy Birthday Father
Old Sat 24 January 2009, 18:32
YRD
Brasilia - DF
Brazil
The feeling is of joy and sadness
I did everything to cut this date: January 24. Anniversary of my father.
But not everything depends on us...
