Old Sun 15 December 2013, 07:27
That looks wicked cool, Chris!!
Care to elaborate on the mathematically driven pattern??
I'm intrigued.
Old Sun 15 December 2013, 12:16
litemover
Just call me: Chris
Auckland
New Zealand
Thank you Darren.
It's a mesh triangulation algorithm driven by a pseudo-random point spread across a rectangle. Each seed point is the center of a cell. The spread can be as random as one wants, but the algorithm will always generate and even out the cells in such a way as to look connective to one another. I simply offset each cell with a radius at the corners to give it negative space to cut. Then fillet radius on the edges.
The great thing is, the structure is parametric, so once the programming is finished, I can change the density, randomness, size, fillet radius, and offset border size of the pattern by adjusting those variables in real time.
The algorithm is called Voronoi, named after Georgy Feodosevich Voronoy, a Ukrainian Mathematician who studied at Saint Petersburg University, who interestingly was a student of Andrey Markov.
Old Sun 15 December 2013, 12:55
F.A.B
Just call me: Mich #116
Qld
Well I hope I am not the only that has no idea what you were just explaining. Way over my head. But the end product is very cool!
Old Mon 16 December 2013, 07:58
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
its look very nice. the rounded edges and paint made it look very well finished. By the way I'm using the same Voronoi algorithm to produce custom stippler portraits with good success, it's is a big hit at my art gallery.
Old Mon 16 December 2013, 16:40
Alright where do you find this algorithm? and how do you use it? I'd like to play...
Old Tue 17 December 2013, 07:35
parrulho
willemstad
Tom, I'm using it the old way with a command line but there are new frontends that make it easy. Take a look at the link: http://www.evilmadscientist.com/2012...in-processing/
Old Tue 17 December 2013, 17:31
Thanks Paulo, I'll take a good look at it when I've got a break, thanks again.
Old Tue 24 December 2013, 03:13
litemover
Just call me: Chris
Auckland
New Zealand
Hey,
Anothor project i designed and fabricated on the mechmate. Had a bit of a scare over the past few days. My power supply must have spiked or something taking out my ESS. Lukily had a spare chinese breakout board that I bought for $12 off ebay, saved the day.
All cutting well again. Smoothstepper support, simply outstanding! Greg called me on a Sat and Sun night to help sort it all out and helped me to hook up the other board. What an amazing company, Warp9td. New Board coming tomorrow.
Chris
This is Sean, one of my guys.
screenshot software
Old Tue 24 December 2013, 07:19
Wow!! Cool stuff!
Old Tue 24 December 2013, 17:09
Looks like something you'd see on a tv game show or tech type tv program
Old Wed 25 December 2013, 21:36
litemover
Just call me: Chris
Auckland
New Zealand
Thanks, it is going to be a news background.
I'm cutting an acrylic desk and was going to put a bevel on it. The acrylic is 3/4" thick, the bevel is going to be 30 degrees. Hopefully, I can cut the bevel in a few passes ok without chipping.
I just cut these cool headers out of foam core. They turned out nice. The Mechmate ESS is working well again after Greg sent out a replacement board.
I'd always recommend having on hand a spare cheap Chinese BOB. They only cost about $20 off ebay but are susceptible to noise.
Cheers,
Chris
how to print screen on pc
Old Sat 28 December 2013, 02:28
litemover
Just call me: Chris
Auckland
New Zealand
Just squared up my gantry to near perfection. I had no idea that 1 .005" shim could make sure a huge difference. 1/16" of an in, unbelievable.
Big thanks to Greg from Warp9td for all the help he gave me over Christmas while my smooth stepper blew up. He walked me through every possible fix, then helped me hook up a temporary one. I'm eternally grateful for the smooth steppers support. It is unmatched.
Old Tue 14 January 2014, 16:32
litemover
Just call me: Chris
Auckland
New Zealand
Hey Guys,
Just purchased an RS-485 adaptor for hooking up my VFD to modbus and it only has 2 outputs on it. B- and A+ for RS485. How do I get this into Modbus? My VFD has R+T+ R- T- on it. Is that Full duplex RS422?
Any info on the pinout for Modbus using 2 pins would be greatly appreciated.
Chris
Old Wed 15 January 2014, 00:06
litemover
Just call me: Chris
Auckland
New Zealand
Ok, well I managed to get the Spindle running via Analoge, but not through mod bus. The only thing is that I can only get it to run very slow, and it won't go faster. There is no trim pot on the board...
Modbus, I think i need a different USB key, one with English instructions and programming, not Chinese.
Old Fri 28 March 2014, 18:46
litemover
Just call me: Chris
Auckland
New Zealand
What I've been making...
Hiya everyone,
Sorry I've not posted any updates for months. After building the last machine, things got kind of hectic and it was 7 days a week 12 hours a day for a couple months. Now I'm back in NZ about to embark on some NZ scenic stuff with the Auckland mechmate. So I thought I would share some pics of what I've been designing and fabricating with the OC Mechmate which is an indispensable tool to the business.
I'm constantly impressed at how well this machine cuts! These pics are for a couple studios which we designed, lit, and fabricated scenic for. Enjoy.
Talk show set, everything together.
The guys and girls at work!
Painted Screen Surround
News Set
Talk Show Different Colour
Starting Panel Cutting
Surround & Riser
Old Fri 28 March 2014, 19:42
Absolutely incredible work, Sir.
Old Fri 28 March 2014, 21:27
tnarch
Just call me: Tuan
Milwaukee WI
great job
Old Fri 28 March 2014, 22:29
sierra347
Just call me: Armando #110
Montgomery, IL
Nice
Old Sat 29 March 2014, 17:29
litemover
Just call me: Chris
Auckland
New Zealand
Thank you for the comments! Really appreciate it
Chris
Old Sun 30 March 2014, 07:16
Thank you for taking time to post pics and keep us updated.
I really appreciate that
Old Wed 02 April 2014, 06:16
Jason Marsha
Just call me: Jason
B'Town
Barbados
Great Work.
These pictures inspire those of use looking for this type of commercial work.
Jason
Old Wed 02 April 2014, 06:27
You said it Jason.
I'd love to be full time in the shop doing this sort of work.
Old Wed 02 April 2014, 06:32
Christ,
Love your work! Particularly the lattice partition.
How did you do the lattice design? By hand or some software generation?
Old Wed 02 April 2014, 06:33
Ken, I think you are over-complimenting with his new name.....lol.
He does great work, but......
Old Wed 02 April 2014, 06:38
Ooooops... that what happen when I can't take my eyes off the nice photos...
Sorry Chris...
Thanks Darren for the heads up.
BTW, anyone who can come up with such great works are god-like, to me at the least
Old Wed 02 April 2014, 07:37
We are not worthy.
Old Wed 02 April 2014, 07:55
...and that's what #5 has been doing its entire life (and number #28) in a different company.
See....it is a useful commercial machine!
Thanks for posting!
Old Thu 03 April 2014, 00:13
litemover
Just call me: Chris
Auckland
New Zealand
Hey thanks for the compliments guys. Again, really appreciate it. BTW, my name is Christian, so not too far off I'm always impressed by the potential of this machine. I would be reluctant to purchase anything below a Northwood or Felder, or ART machine in lieu of the Mechmate. And those Vextas, man they kick arse! I get such nice cuts, they look like a laser.
I'm really wanting to get a 5 axis head on next... We shall see.
Very useful machine indeed. I'm really glad I know how to build one now.
Cheers,
Chris
Old Fri 04 April 2014, 13:17
zumergido
Just call me: Fernando
BS AS
nice job.. this machine has no limits.
are you using grasshopper for the patterns?
Old Tue 22 March 2016, 17:00
Chris, what are you working on these days?
Mechmate "Junior", table and gantry welded - Portland,OR Sherman McCoy Construction started, but not cutting yet 100 Wed 21 March 2018 05:40
My new MechMate, is now "officially" cutting! #27 - Randers, Denmark mikefoged MechMates already cutting 55 Wed 07 October 2009 07:36
A new tool to build your Mechmate! (The Hexapod "spider" again) HomeMadeCnc Miscellaneous / General / Whatever / Catchall 0 Sun 18 January 2009 04:44
Creating a "manual" to describe the MechMate build process Gerald D Archives 5 Thu 05 June 2008 17:09
The MechMate "Mamba" version has been launched Gerald D Archives 8 Sun 11 November 2007 08:42
