Old Tue 03 December 2013, 21:58
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Still no communication between VFD and computer using RS232 converter. I'll attach crops from user manual, maybe anyone can see something wrong with my connection?
I'm connecting:
RDA and SDA, together on D+/A(Tx+)
RDB and SDB, together on D-/B (Tx-)
Old Fri 06 December 2013, 10:02
I don't know which machine controller software you are using. This only pertains to Mach3.
I know Mach can be frustrating to make it talk to the VFD. Some VFD manufacturers, the setting has to be made and a required power down for the setting to accept. Once you have the correct settings in Mach and your VFD it works wonderful. But you will have a little stress as there is not a good manual to read to make it plug-n-play.
According to your images, what you have stated is correct. I had a little trouble with the distance of the computer to the VFD and had to get a shielded serial cable and mounted the 485 converter near the VFD. Now don't just jump and say that is my problem. Many people have these just plugged into the back of their computer and it works fine. Post a question on Machsupport and CNCZone also. There are more people there that are users of Mach3 and some will have the same frequency inverter you do. If anything, it is a larger knowledge base to pull information from.
I hope this is helpful to you.
Old Fri 06 December 2013, 10:30
I posted this screen as it is critical for right setup, this is if you use old serial modbus plugin from mach3
check the parameters as stated from pages 183, 187 and 200 , speed parity stop bit etc.
also my vfd wont update parameters faster than 10Hz, something to do with line busy or whatever.
You can test line settings from Test ModBus button, bear in mind that if the parameters are values 1-xxx and registers start from 0-xxx sometimes.
Old Fri 06 December 2013, 11:37
parrulho
willemstad
Thank you very much Pete, I'll sort this out when I have some spare time. I did not try it with Mach, just want to communicate with FR-Configurator that is a tool from Mitsubishi, VFD Manufacturer, to setup the parameters of the Inverter. or, better yet, to buy a PCI RS-485 board.
Old Fri 06 December 2013, 11:40
parrulho
willemstad
Thank you Danilo, Just see your post now...
Old Fri 06 December 2013, 12:11
parrulho
willemstad
Maybe it's better to try communication from Mach, using test modbus...
These "speed, parity, stop bit" must match VFD and Software (Mach or FR-Configurator) and about rs-232 serial port on computer? also these settings needs to match or is not important?
Old Mon 16 December 2013, 08:45
parrulho
willemstad
During cuts my machine get paused without reason. I have a 5m parallel cable to have the computer on other side of the table. it was working very well with a router but since I changed to spindle it started. not a big deal as I only need to press a button to continue. Then, I put the computer next the controller and VFD with a small parallel cable but it got worst. I couldn't start the machine with spindle running, it said a "stop button is pressed"... Moved the computer to other side, again, with big cable for now.
I'm cutting small files, mainly art works for a gallery. Everyone is impressed with the art that comes out of my machine. Very happy, biggest success is the custom stippler portraits, I think it will pay my machine
still no signal of communication between VFD and computer through rs-232 adapter.
I wish a good holiday season for all community.
Old Mon 16 December 2013, 13:25
Try setting the Debounce in Options to something between 200-1000 it should solve the problem, I also don't hook up buttons directly to the Breakout board but trough the 24V relays its much more immune to the noise
Old Mon 16 December 2013, 20:56
parrulho
willemstad
thanks, I'll do it.
Old Tue 17 December 2013, 21:07
hevertg
Just call me: Hevert
maracaibo
Venezuela
Paulo that's good to know you're doing well, merry christmas friend, wanted to help but I still have no experience, until you put in function the me to think that in the mid 2014's I'll have running, greetings friend and you go well. and thanks for the help you have given me.
Paulo que bueno saber que te va bien, feliz navidad amigo, quisiera ayudarte pero todavia no tengo experiencia, hasta que no ponga en funcion la mi a, creo que a mediados del 2014 la tendre funcionando, saludos amigo y que te vaya muy bien. y gracias por la ayuda que me has dado.
Old Fri 28 February 2014, 13:21
parrulho
willemstad
Hi all,
Just to say hello. With small problems to solve on my machine (noise), the true is that I did nothing to solve it but I'll do one of these days... I'm using the machine almost every day, turning on the VFD manually, and pause button disabled... Machine is going strong. Got a good deal on Enroute V5 CAM program, that's a good piece of software! These Rapid Textures are promising. A portrait almost out of the box:
Old Fri 28 February 2014, 14:43
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Super nice job!
I run Aspire 4 and Easycab Pro kitchen,
looking forward to trying that out for myself.
Love the dustfoot custom pipe!
Tim
Old Fri 28 February 2014, 14:52
...is that plumbing drain pipe as a dust pickup? Love it!
Old Sat 01 March 2014, 08:15
Andrew_standen
Just call me: Andrew #109
Dorset
Hi Paulo. I like the portraits, what material are you using?
I have been trying to make some wooden books using maple faced plywood. Painted in back acrylic. Sanded then Danish oil. Must try some of your portraits. Nice work.
cheers Andrew
Old Sun 02 March 2014, 08:23
parrulho
willemstad
Here is a photo for the dust pipe I used, it's like cooper. Works very well for a small system like mine, with a ShopVac. You can turn it around, up and down without turn screws, just forcing, very handy.
Andrew, the material I use is MDF moisture resistant laminated in white. with a sharp toll it holds very fine details without chip. Feel free to PM me if you want more info. on portraits.
Old Sat 17 May 2014, 10:44
parrulho
willemstad
Testing Mechmate to cut glass: Approved.
http://youtu.be/yNYPgUQHsfY
Old Sat 17 May 2014, 11:12
Great !!
Thks for sharing
Old Sat 17 May 2014, 12:40
Never would have thought...good going
Old Sat 17 May 2014, 16:52
dbinokc
Just call me: DB #118
Oklahoma
Cool. What are you using for the scribe? How hard was it to break the curved glass free afterwards?
Old Sat 17 May 2014, 17:47
Axel1966
Just call me: Axel
Paris
France
Nice work, how did you manage the gap caused by the cutter's offset ?
Old Sat 17 May 2014, 20:33
parrulho
willemstad
https://www.unitedmfrs.com/cart/detail.cfm?item=4864
You need to remove the lock pin.
after doing extra small cuts, by hand, dividing by 2 the wast material, it was very easy to break. for tool path used was engraving 0.03 mm and foam board as backing plate.
for that job, cutting ovals for picture frames I didn't take into account the offset. Dimensions are perfect only the zero is offset, I think...
Old Sat 17 May 2014, 23:24
Nice job! Thanks for sharing.
Now we have another trick up our sleeve
Old Fri 23 May 2014, 16:14
parrulho
willemstad
Today I spent some time looking to solve the noise problem: machine gets paused, randomly, during cuts, and E-Stop on mach3 getting activated when Spindle turns on or off or changing speed. All I needed to do was to ground the negative of the 12V power supply for PMDX-122 and Proximity switch to aluminium plate. All noise went away and machine is working as it should be. I don't know for sure if it is advisable but it solved my problem. I'm not using line reactors or EMI filter on VFD.
Wire is the yellow one on center of thr photo.
Old Fri 23 May 2014, 18:08
Wow Paulo, I just came in from the shop and I'm experiencing the same exact problem, been trying to solve it all day long. I had to change out a PMDX-126 and thats when trouble started. It fixed the dead z but then the spindle was kicking the breaker that the computer was on, changed parallel ports to fix that, but still have a jitter on one of the X steppers when the spindle goes on or off. Never had this problem before, maybe additional grounding is what I need.
Old Fri 23 May 2014, 19:06
dbinokc
Oklahoma
If your 12V power supply was floating, that would definitely cause problems.
Having no ground reference is like trying to measure the height of something with one point. It takes two points to define a height.
Having a noisy ground for electrical circuits that depend on a voltage value is like trying the measure the height of a building during an earthquake. If the earth keeps jumping up and down, you can't get a good reading.
Hopefully the analogy makes sense.
Old Fri 23 May 2014, 19:46
parrulho
willemstad
yes, the 12V power supply was floating. When I was mounting the control box I remember that I wanted to keep the ground of the PMDX-122 isolated and I missed the power supply. Today when I opened the control box my eyes go direct to it and I saw the problem...
It can be the solution for Tom...
Old Sat 24 May 2014, 05:30
I must be missing something, I've looked everything over good and is grounded well. Just about everything has a common ground. ALL cable is shielded and the PS's are grounded to the control box then to earth ground, I have filters on each individual phase going out of the VFD and then another for the whole cable. I have a 24vdc ps that is not connected to anything but its grounded through the DIN bar.
I still think its the computer flipping out, I did take a lightning strike that took-out the power supply in it. I'm trying to use it but I think Its time for a new one.
Old Sat 24 May 2014, 08:27
parrulho
willemstad
Very unfortunate, Tom. It can be anything at the computer. If you have a temporary computer that you can use to run mach3 and then start to swap parts until you find the problem? It's is my approach when I'm at work in a casino with hundreds of slot machines... Good luck.
Old Sat 24 May 2014, 10:59
That's it, keep playing until you win.
Old Sat 24 May 2014, 13:22
dbinokc
Oklahoma
The computer would be a relatively easy one to try first. If that does not work, you might try looking at the filters you added. Maybe even remove them. They may have been damaged and are causing problems.
After you try that, you may want to summarize everything back on your thread before your troubleshooting notes get scattered around a bunch of other threads.
It Aint Finished Yet -The Netherlands Hans Construction started, but not cutting yet 31 Thu 27 April 2017 20:34
Planning new build in The Netherlands eddies-customs Introduce yourself and start planning 5 Sun 21 October 2012 14:39
Planning a new build in Edam - The Netherlands Polder48 Introduce yourself and start planning 9 Sun 02 August 2009 05:56
TimCooijmans his CNC - Netherlands timcooijmans Construction started, but not cutting yet 8 Thu 05 June 2008 06:19
