Old Thu 23 February 2017, 19:10
timberlinemd
Just call me: Steve #66
Arizona
I used slide valves for the four zones and added pneumatic cylinders to control 'open/close'..
Old Thu 23 February 2017, 19:22
timberlinemd
Arizona
Loaded my spoil board (Trupan) and turned the thing on. 5" hg with the loose spoil board. Held real well for a skim cut (.020).
Removed the spoil board and applied melamine glue to the plenem. Flipped the spoil board and turned on the vacuum to hold down the spoil board while the glue dried.
Added a 1/4" sheet of 1 sided melamine to stop leakage through the top of the spoil board. I hadn't yet cut the top surface of the spoil board and still had to stop the vacuum long enough to position the 1/4" sheet cause it sucked down hard and fast. 8" hg. Sweet!
Old Fri 24 February 2017, 07:33
Kornerking
Just call me: Pete #127
Big Falls, Mn
Oh.......
I like the pneumatic open and close.
Nice to be sucky.
Couple of questions.
Are all vacuum motors running at the same time?
What did you use for a dust filter?
Old Fri 24 February 2017, 10:36
timberlinemd
Arizona
Four motors (Amtek 117123) are paired. I plan using one pair (primary) to hold material until I get to the onion skin cut. I will then use the other pair (secondary) if needed as I will no doubt loose vacuum.
The white piping in the pics contain a filter (STP SA9053) that i obtained from the auto parts house. Many people feel that the spoil board acts as a filter, which it does, but I went ahead and added the above anyway.
Old Fri 24 February 2017, 13:13
Kornerking
Big Falls, Mn
I use a filter in mine.About every 3-4 months I need to clean it out or replace. Simple 10 minutes of insurance.
Old Fri 24 February 2017, 13:15
Kornerking
Big Falls, Mn
Are yours wired to come on automatic?
I'm thinking about doing that.
Old Sat 25 February 2017, 05:03
Great looking vac system
Old Sat 25 February 2017, 05:14
Wow, I really like your design, cool concept
Old Sat 25 February 2017, 18:28
timberlinemd
Arizona
Manual only. Gary Campbell, who is the original designer of the 'Blackbox Vac' started out with a automatic system, but soon found that trying to keep the motors running correctly, especially after cutting into the spoil board became too much of a 'moving target'.
For more info go here...
http://www.talkshopbot.com/forum/sho...Box-Vac-Source
Old Sat 25 February 2017, 18:30
timberlinemd
Arizona
Big thanks to Gary Campbell for the vac and plenum ideas!
Old Sat 25 February 2017, 21:41
I was commenting more on the pneumatics/vac package you had put together, good job
Awesome cut ready DXF files custom dxf file Dxf Library 1 Thu 21 February 2019 19:09
My awesome acrylic dust shoe design st_indigo 55. Dust Management 4 Thu 27 April 2017 22:03
Let the games begin in Arizona City, AZ! timberlinemd Introduce yourself and start planning 3 Thu 11 March 2010 09:30
New to forums, Phoenix Arizona curtis1dean Introduce yourself and start planning 4 Thu 18 February 2010 10:20
MechMate in Arizona Kevin Construction started, but not cutting yet 7 Sat 22 December 2007 10:52
