Old Mon 14 February 2011, 11:50
camilleg
Just call me: Camille
Urbana, Illinois
Brilliant clampology for the traveling drill press!
"Drew blood" -- did the dry-eraser still work, or was bleach needed?
Old Mon 14 February 2011, 14:22
melissa
Just call me: Melissa #83
Brighton (Ontario)
Hmph, I knew it was going too smoothly.
I just finished drilling the holes in the X rails to 1/2".
Next step is drilling the proxy target holes. As luck would have it, with my bolt spacing, they'll intersect the second-last bolt at each end . They need to be symmetrical to work properly at both ends... so what to do???
Move the second-last bolt an inch or two out of the way, and re-drill the rails and beams to match? Any suggestions?
Old Mon 14 February 2011, 14:29
camilleg
Urbana, Illinois
Move the second-last bolt an inch or two out of the way, and re-drill the rails and beams to match, as you say.
It might feel like backtracking, but anything more elaborate risks even greater backtracking if that goes awry.
Old Tue 15 March 2011, 15:59
camilleg
Urbana, Illinois
For anyone who's curious, so much progress has been made in the past month that Melissa hasn't had time to post anything about it. As of a few minutes ago, I believe the table is entirely degreased, washed, and now drying before paint goes on (tricky, in that unheated aircraft hangar in what still is winter in the Great White North).
Old Thu 17 March 2011, 00:41
melissa
Brighton (Ontario)
Here's what I came up with for the hole interference on the X rails. I had some 1/2" steel rod on hand, so I cut off four pieces, pressed them in with the hydraulic press, tack welded the back side, and then ground the top face flush. After painting, you won't see them anymore .
Also a photo of the stop blocks welded in place on the X rails.
Old Thu 17 March 2011, 00:49
melissa
Brighton (Ontario)
The cross bearers were cut from surplus steel, formerly used for pallet racking. I tried cutting the angle on my 14" dry-cut saw, but it didn't work very well. The alternative was my steelmax saw, but I didn't want to set up the angle 15 times. Instead, I clamped five channels together, and did one long cut.
With them cut to length, I opted to mark and punch the holes for the spoilboard bolts, rather than using a jig. I clamped them in sets of 8, and marked both sides before unclamping (I drilled holes top and bottom, so I can drill through the channel straight into the spoilboard).
Old Thu 17 March 2011, 00:56
melissa
Brighton (Ontario)
Something that had to be done before installing the cross bearers: installing hanger bolts in the ceiling for the dust collection hose! With an 11-foot ceiling, ladders are scary at best.
I moved my scaffold into the open space of the mechmate, to be able to drill the holes and install the bolts. The scaffold is 2.5' wide x 6' long, and was able to spin around inside half of the table .
The second photo is part of the fastener collection for the mechmate. The other side of my storage unit is various bulk screws and bolts, but this side is all carefully selected for the mechmate.
Old Thu 17 March 2011, 01:03
melissa
Brighton (Ontario)
How to paint in Canada during winter: build a tent inside the workshop . The inside volume of the tent is about 1700 cubic feet, as compared to the workshop's volume of 17000 cubic feet! Much easier to keep warm.
The main support of the tent is the gantry crane, with various bits of 2x4 lumber clamped and bolted together.
The last photo shows before and after degreasing the main beams. If the water is beading like that, then the paint will certainly bead too .
Old Thu 17 March 2011, 01:07
melissa
Brighton (Ontario)
Table and Y-car primed!
Finally, on to paint! It took 8 hours today to prime the Y-car and main table (sans cross-bearers). It's a surprising amount of area to cover.
Next is painting the cross bearers and X-rails, and then the cross bearers get welded in place. Progress!
Old Thu 17 March 2011, 09:45
camilleg
Urbana, Illinois
1, Woohoo! That's a milesto-, um, kilometerstone.
2, That tent is rather more elaborate than anything we ever made from sofa cushions and bedsheets.
Old Tue 22 March 2011, 12:42
melissa
Brighton (Ontario)
More painting progress: cross bearers and rails primed and painted.
The ends of the cross bearers are unpainted, as they still need to be welded to the base table.
Old Tue 22 March 2011, 12:48
Melissa, your progress is looking great!
Old Tue 22 March 2011, 13:32
Johannescnc
Just call me: John
Hannover, DE
Germany
Admirable work and progress.
Question, over your plastic bolt bin... " keine gefingerpoken!" Looks some what familiar
Old Tue 22 March 2011, 14:14
melissa
Brighton (Ontario)
I was waiting for someone to comment on the labels . It's a reference to to the "blinkenlights" poster:
http://original.jamesthornton.com/fu...kenlights.html
ACHTUNG! Alles touristen und non-technischen peepers!
Das machine control is nicht fur gerfinger-poken und
mittengrabben. Oderwise is easy schnappen der springenwerk,
blowen fuse, und poppencorken mit spitzensparken.
Der machine is diggen by experten only. Is nicht fur
geverken by das dummkopfen. Das rubbernecken sightseenen
keepen das cotten picken hands in das pockets,
so relaxen und watchen das blinkenlights.
Come to think of it... I may engrave that and mount it above the mechmate!
Old Tue 22 March 2011, 15:17
Johannescnc
Just call me: John
Hannover, DE
Germany
Hey! cool... My wife and I looked at the link and both of us feel it is a mix of Plattdeutsch, English, Dutch and Deutsch!
She is looking at the site now and seems to be very entertained
Thanks for sharing that...
Old Thu 24 March 2011, 13:54
melissa
Brighton (Ontario)
More blue paint... gantry and table.
Old Thu 24 March 2011, 17:12
camilleg
Urbana, Illinois
No doubt the question's been asked before... so how long can a MM hold its breath?
Lookin' better and better!
Old Fri 25 March 2011, 21:06
melissa
Brighton (Ontario)
Now we're really looking like a MechMate . Cross bearers clamped in place in preparation for welding.
I used a tensioned fishing line to align the pre-drilled holes in the cross bearers.
Old Fri 25 March 2011, 21:41
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Looks great! I wish I had the size shop that you have. What kind of heat are you running in the shop besides the construction heater?
Tim
Old Fri 25 March 2011, 21:47
That table keeps looking longer and longer. Great work Melissa!
Old Fri 25 March 2011, 22:01
Hey, that's ShopBot's colour!
Old Sat 26 March 2011, 04:13
melissa
Brighton (Ontario)
Oops!
Tremclad paint didn't have a lot of choices in blue .
Old Sat 26 March 2011, 04:15
Hey, just pulling your leg - don't change it now!
Old Sun 27 March 2011, 10:55
camilleg
Urbana, Illinois
@Tim: Friction from the drill press when we're low on cutting oil.
@Gerald: Maybe we've discovered shopbot's corporate secret?
Old Mon 28 March 2011, 22:25
melissa
Brighton (Ontario)
The cross bearers are now welded in, and the ends primed:
Also started on painting the control box, even though I haven't drilled the cable and pushbutton holes yet.
Old Mon 28 March 2011, 22:28
melissa
Brighton (Ontario)
About shop heating: I'm investigating propane radiant heaters, as well as solar air heating. My shop is about 18,000 cubic feet, so solar is looking really attractive!
Old Tue 29 March 2011, 03:16
This can be pretty easy to build, I myself just collected 240 cans for this and getting ready to assemble the unit.
http://www.cansolair.com/
Is this what are you using Michael?
Old Tue 29 March 2011, 09:28
melissa
Brighton (Ontario)
Danilo,
I haven't actually installed a solar unit yet, but that's one of the models I was looking at. Right now, I'm trying to get the MechMate operational as quickly as possible .
Melissa
Old Tue 29 March 2011, 21:33
melissa
Brighton (Ontario)
Table painting complete!
I finished painting the table tonight: the ends of the cross bearers, and the outside of the main beams.
I'll post photos once I open up the tent again, so I can take a photo from more than 2 feet away .
Next up is the spoilboard. I'm glad I own a full-size cargo van, as I need nine sheets of 3/4" MDF, total weight over 800 lbs. Installed, the spoilboard will weigh somewhere around 650 lbs.
Old Wed 30 March 2011, 12:47
Melissa,
Are you using 4x8 or larger sheets
dust collector capacity gorantec 55. Dust Management 15 Thu 19 November 2009 19:24
Dust foot and custom clamps done #3 - Conway, AR Doug_Ford MechMates already cutting 195 Mon 13 October 2008 20:27
Dust collector foot Art 55. Dust Management 5 Sun 17 June 2007 13:09
