#91
Joe, the racks Frallan is using (and I) are not top notch quality and I noticed they are a bit 'sticky', a pinion doesn't run smooth over at.
Frallan, what I did is I got a bit of liquid 'sand paper', the liquid is used to sand pistons for cars and I put it on my rack and run the machine over it some time. This will 'sand' the rack/pinion to make it run more smooth. This way it made my pinion feel less 'sticky'. When I am going to get my belt reduction I will get 32tooth pinions, i think they are better, 22 is a bit to small I am afraid (or just bad quality racks, but for the price.......). After cleaning I put a little bit of oil on the rack to make it run more smooth. After it I have been doing a MDF job without just collection (Hatchoe.......) and the racks looked just fine after it. About spindle control, I think somebody wrote that and I have seen it on the EMC2 forum/IRC channel or mailing list. Google is your friend! |
#92
Ries, that is good info, thanks for sharing, I think we share the same supplier...
#93
Bah logos taking longer time than expected =(
Guess Ill have to mark the machine in some other way until then |
#94
Frallan,
I printed the outline on a A4 sticker and then cut them out by hand. Took me less then a hour on the kitchen table to get it done. May be not as beautiful as printed, but at least it works. You cab also buy some cutting knives and mount it on the MM ![]() |
#95
Geeez! Is this video realtime!?!?! http://www.vimeo.com/10774348 What size bit was being used? Also in the dry run and figure 8 video,... what was all the grinding noise? Other than that I cant get over how cool these things sound when operated
After I build my MechMate Im goin to build a MechWarrior![]() |
#96
its realtime, 3mm tool.
The grinding noise is due to the rack and pinion not being top notch ![]() But after running some time now they sound less and less, so its just a matter of "running in". |
#97
Wow, thats awesome. I didnt think the machine could cut that fast with a bit that small.
#98
#99
HEy I read through this log and didnt see what steppers your using or is your using reduction either. Can you share? Thanks.
#100
#101
Yup, you most certainly should be getting a number. Well done!
#102
Congrats Frallan!
#103
#104
Congrats !!! I was out of pocket for a day or two and I seem to have missed a lot
. Now to get the builders log updated.... |
#105
Ahh ty
![]() Numero 57, need to make a nice little plate to attach to the machine now :P |
#106
Congratulations dude!
Well done |
#107
Builder's Log Update
Frallan,
Congratulations on completing your MechMate and Serial #57. Here is the updated Builder's Log. Please provide the dimensions of your MechMate for the Builder's Log...either a Reply in this thread or a PM to me will work. Also, please review your Builder's Log entry and provide any changes you want to make. |
#108
The size is 2750x1630, due to the fact I wanted to be able to get it inside too
![]() Not really much to add, will be adding proper dust collection and some nice way of fastening for work pieces. |
#110
#111
Frallen #57: Good job! Welcome to the club. Machine looks great and the new dust foot looks really good. Which design did you use?
Joe #53 |
#112
My own design I assume :P
Might have seen similar but afaik I did it after own ideas. But its a pretty obvious design and where to mount it ![]() |
#113
Nicely done Frallan, Enjoy it as much as I do, or should I say as much as we ALL do.
Dave #52 |
#114
Got tired of fastening the way I used to at first so I finally got my ass up and prepared for proper ways of fastering materials. Will be leveling the table tomorrow and prepare the spoilboard for the new way
![]() Meanwhile I got a nice "pendant" working via EMC2s' hal. Cheap and works very well http://vimeo.com/11559249 |
#115
That link says: "Sorry, "EMC2 gamepad pendant" was deleted at 6:00:34 Fri May 7, 2010. We have no more information about it on our mainframe or elsewhere"
#116
Try this Gerald http://vimeo.com/11555627
#117
Nice clear video! Thanks
#118
Yeah for some reason 2 uploads said failed, but suddenly worked so I removed them not thinking about this link =)
| 57 legs turned Can do orders for others | sailfl | The Market Place | 24 | Mon 10 January 2011 10:10 |
| Building a Wall mounted Slanted base - Stockholm Sweden | oopz | Construction started, but not cutting yet | 26 | Fri 12 March 2010 05:10 |
| It is cutting! Angle motor drives, pumpable gasspring #14 -Soderhamn, Sweden | hans.arnell | MechMates already cutting | 31 | Mon 05 January 2009 14:25 |
| Will be visiting Scandinavia next week . . . | Gerald D | Archives | 39 | Thu 05 June 2008 23:33 |
