Old Mon 20 June 2016, 09:20
I would recommend allowing for the tail stock to be movable (like slide)
I used Unistrut welded open channel up and bolted the tail stock down to move to accommodate different part lengths.
Old Mon 20 June 2016, 13:41
silverdog
Just call me: Sergio #70
Rome
Italy
Sean,
Yes absolutely ! the tailstock will slide and have a rapid block lever (still to be designed).
The tailstock support will be the blue part in the picture ( inside the orange box you can see the part which will be welded /bolted together ) it's made of four 80x60x4mm rectangular tube. The part will slide on and inside the two Y C channels (UPN80 ... 80x45mm).
The Chuck support, made the same way, will be fixed in his position.
All the indexer structure will be bolted to the main X beams and will be removable.
Old Mon 20 June 2016, 19:29
That's a better picture. looks like you have it all sorted!
Good luck.
Old Tue 21 June 2016, 12:10
silverdog
Rome
Italy
Well you never know untill you've done :-)
Old Wed 14 December 2016, 06:29
silverdog
Rome
Italy
An Hotel Room Console
an interesting work ...
Old Tue 20 December 2016, 02:27
vallie4
Just call me: towanda
Londo
Wow really like that one. Did you made that yourself?
Old Wed 21 December 2016, 00:13
silverdog
Rome
Italy
No I just cutted with the Mechmate ... The designer is architect Marco Tonci Ottieri... The same of the Anathemic chaise longue.
Old Sun 23 April 2017, 14:39
silverdog
Rome
Italy
A work made by Antonio Iaccarino of Equilibrarte (on his Machmate) on a reproduction of Emperor Augusto fro Musei Capitolini ....
Old Sun 23 April 2017, 14:46
silverdog
Rome
Italy
the whole set of pictures: https://www.facebook.com/photo.php?f...type=3&theater
Old Mon 24 April 2017, 04:06
Impressive.
Old Wed 26 April 2017, 22:02
IamDave
Just call me: Davey
Ball Ground, GA
Inspirational
Bought the MechMate Plans - Time to get Started bkgoddard Introduce yourself and start planning 5 Tue 08 November 2011 06:32
A lazy start ... in Rome, Italy silverdog Construction started, but not cutting yet 12 Fri 29 October 2010 02:41
Free Cad and Cam HeekCNC Windows & Linux Regnar CAM 0 Thu 16 September 2010 19:24
Mechmate for guitar making? rhoads56 General - MM Build 7 Tue 19 February 2008 12:03
