Old Tue 01 December 2009, 00:50
buibui
Just call me: John #34
Seattle
Thank you, J.R. A laser would probably help...I haven't read enough about this yet to figure out where to get one, how to hook it up, and use it. For this project, I had used a pointy stick chucked in the router
Regarding the pegs, I bought them from craftparts.com. Mine are the 5/8" dia. size.
John
Old Wed 02 December 2009, 08:32
dragonfinder1
Just call me: Dave #49
Astoria, Oregon
John
I find the center of my project and use a very sharp pencil, make a small line. The use a laser pointed v-bit, center it on the pencil line, then go to the MDI page of Mach and move half the width of my project, then zero the DRO. It's fast and you can get very close to the center of your project.
Given the width of the lines I've seen with lasers, you can get as close with my method. For sure not as fast, but you never have to worry about the lasers being knocked out of align.
Dave
Old Wed 02 December 2009, 08:57
Castone
Just call me: Leo #41
Soddy Daisy , Tn
edge
Most people just touch off the sides of there parts with the tool they are using in Y and X, zero your tool and then you can move exactly were you want to. Or make your self a referance jig to locate your parts the same after you set up the first one. It is the same practice machinest use. Send me a PM if you want to try it and I can explain it a little more.
Old Thu 03 December 2009, 09:38
dragonfinder1
Astoria, Oregon
Castone
How do you set up when you want the file that your cutting to be in the center of a pattern in your material that might not be or is not centered in the base material?
Old Thu 03 December 2009, 10:07
Castone
Soddy Daisy , Tn
edge
If you start as I was talking about before by finding your 0Y 0X . You can measure the board you are cutting, then you can just jog to what is the center of the board by looking at your computer. Or you can go MDI Type G0 X10 Y5 F20 and hit enter and it will jog to that location for you. Most parts do not require it to be this close but when it does this will always work.
Old Sat 02 January 2010, 23:07
ikeike
Just call me: isaac
bozeman
John,
I'm so impressed with your design for the bolt together table. Do you mind sharing the dimensions of the I-beam stock you used for the X-axis and legs? Great work!
Old Sun 03 January 2010, 22:41
buibui
Seattle
Thank you Isaac. The I-beam for the main beam is 8" x 4" (I think they're called "long flange"?), and the legs are 4" x 4".
John
Old Sun 03 January 2010, 22:48
buibui
Seattle
Dave and Leo, thank you for the advice. I've been away from the machine for a few weeks and haven't had a chance, but will give it a try.
John
Old Fri 21 January 2011, 01:20
buibui
Seattle
Update on #34
Hi Everyone!
I can't believe it's been a year since I've last posted...time FLIES when you have a MechMate in the garage, especially when you're trying to learn how to use the thing! Anyways, here are a few projects that I've done since I finished my machine. Nothing too complicated, but a learning experience nonetheless.
John
Old Fri 21 January 2011, 03:45
John, you shouldn’t expose those, some will become jealous of your talent !
I know I am
VERY nice & thankful of you to share these !
Congrats, Robert
Old Fri 21 January 2011, 05:27
Great stuff. Can you share what you used to make these. I mean wood type (I reread the thread), method you used to paint them, bit etc. This is some nice work !!
What software did you draw these in?
Old Fri 21 January 2011, 07:48
Beautiful John, Beautiful!
Old Fri 21 January 2011, 21:50
I like it..very well done and thank's for sharing
Old Fri 21 January 2011, 22:47
buibui
Seattle
Thanks for the compliments, guys.
Mike, for the v-carved stuff, I've been experimenting with HDU foam (top two pictures) and hardwoods like poplar and maple (fourth & fifth picture). I've used various bits, but narrowed down my favorites to Whiteside 90 and 60 degree bits for carving, and 1/4 straight flute and Onsrud Super O for the profile. I'm all over the place with feeds and speeds, but I normally cut b/n 100-200 ipm...maybe a little on the slow side.
I'm still trying different techniques for finishing, but I'm getting the best results so far with painting first, masking, and then v-carving through the mask. Long process, but i like the crisp edges.
Old Sat 22 January 2011, 13:14
fanefane
Just call me: Stefan #73
Baia Mare
Beautiful work, congratulations!
Old Wed 02 February 2011, 03:16
Sergio-k
Just call me: Sergio #61
Athens
Greece
Isn't paint "melting" when you carve, or you paint the final layer afterwards ?
BTW your work is stunning, congrats.
Old Thu 03 February 2011, 07:58
liaoh75
Just call me: David
Taibao
Taiwan
Beautiful Work Sergio!
Old Thu 03 February 2011, 19:35
buibui
Seattle
Hi Sergio, no the paint doesn't melt, it just cuts away. Only the lettering gets paint after carving.
John
Old Sun 06 February 2011, 08:48
liaoh75
Just call me: David
Taibao
Taiwan
John, can you tell us what you use for the "mask"? Is it transfer tape the sign industry use to transfer vinyl lettering to it's final location? I've tried this technique before, but found some problems with my masking "tape" peeling away the original paint in patches. If you've not had this problem before, the question may seem confusing but if you've had similar problems, then you know exactly what I'm talking about. Also, what type of paint are you using? Water based or oil? How long was the dry time before applying the mask. After you carve, how long do you wait before removing the mask? Sorry about asking so many questions in one go, but I've just about given up on the masking--> carving-->peeling mask strategy. Then I saw your beautiful work and felt inspired to try again
Old Sun 06 February 2011, 21:59
buibui
Seattle
Hi David,
Yes, I had a lot of problems with lifting, but after a lot of trial and error, I'm now getting pretty consistent results. I use Oracal 813 for the masking, it cuts very cleanly, and a little less tacky than masking tape. It can still lift off paint, though, so I have to be gentle removing it.
I use both oil and waterbased paints, and let them dry for at least 24 hours before applying the mask...more if possible. I've found that certain brands work better than others. Here in the states, Sherwin Williams work great for me, but cheaper brands like Valspar tend to peel away.
John
Old Mon 07 February 2011, 00:32
A liitle tip I picked up on a forum.....only paint/coat wood while it is cooling.
Wood is porous and full of air. While it is heating up, it breathes out..while cooling, it sucks in. You get the worst adhesion (and finish) if you paint in the shade and then put in the sun to dry. First put in the sun, then take inside to paint, and leave inside until touch dry, then maybe risk heating a little to speed drying.
Old Mon 07 February 2011, 06:58
cmd1991
Just call me: Collin
New Haven, IN
Those are some Great looking signs!
Maybe one of these days we can "invest" in some v-carving software.
Old Mon 07 February 2011, 07:53
ChiknNutz
Just call me: Chris
Advance, NC
Being an ex-sign maker (lost our business to the crappy economy), I love this type of stuff! Excellent work. If you want true sign-grade paint with lots of pigment, look for One-Shot (oil-based) or Ronan (typically water-based).
Old Tue 08 February 2011, 10:13
isladelobos
Just call me: Ros
Canary Islands
Spain
Hi John.
Very nice machine.
Im not see in the photos were is the method you use for fit perfect the racks in the main beams under the main rails, is possible you cut your main beam 0.6" ?
Old Wed 06 April 2011, 10:13
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Thanks for posting all your projects, keep the rest of us motivated!
Tim
Old Tue 25 September 2012, 13:04
slobato
Just call me: Leandro
Lauro de Freitas
Brazil
Smile Save topic
Save this topic as favorite in my profile it´s possible? how to do? it´s for easily more find. Thanks
John your MM it´s amazing!! CONGRATULATIONS
Old Tue 25 September 2012, 13:58
slobato
Lauro de Freitas
Brazil
Unhappy Pics
Didn't get as much done this weekend as I wanted. Picked up angles at the steel yard for the rails on Saturday morning, and spent the rest of the afternoon trying to figure out how to cut them down.
Finally setup and cut on on the bandsaw Sunday. It not easy pushing a 45lb, 11 foot piece of angle through a bandsaw! Each one took about half an hour of constant pressure, and I ended up snapping the blade with 4 inches left on the last one. I ended up having to use the grinder to finish it off. Though this is all I accomplished this week, I'm sure glad it's done!
Guess what I'll be doing next weekend!
Bandsaw setup with piece of square tube for fence:
Setup beam on a bench to catch the angle:
Cutting...very long, boring, tiring...zzz...
Yay!
Smoothing the cut edge:
Hi John
Where´s pics? Your hosting pics have a error:
Http/1.1 Service Unavailable
Where do i buy spindels and stuff in scandinavia? hm zinni Introduce yourself and start planning 1 Sat 12 June 2010 07:31
Free Software and other cool stuff seaboardironworks Graphics & CAD 0 Sun 25 April 2010 07:29
Need help with paint code alfred_j_kwak Miscellaneous / General / Whatever / Catchall 2 Tue 16 February 2010 13:42
New Pacific NW (Seattle) builder Mike9126 Introduce yourself and start planning 3 Thu 24 September 2009 06:44
Logo & Paint color code for the MechMate Marc Shlaes Archives 21 Sat 21 June 2008 07:27
