#91
I’m half kidding.....
Numbers nor serial do not much matters to me, as long as a I’m / can contribute to this group that help me when I was in need !! Joe, although thanks anyway for this eye opener, as I never thought of this “prime number” thing. 55 was more a personnel thing than any numerical / number sense ! BUT must say…… 69….mmmm….got to like this one ![]() ![]() |
#92
now its time to upgrade my 3 hp router to a 3 kw spindle that´s what santa bring to me :d im planing to ad a 5th axis for full 3d (lathe) |
#93
Looking forward to your posts on the transition because that's the path I will follow in the future and your information will be very helpful
#94
I used my router to cut the mounts for my spindle from 1/2" aluminum - with lots of passes. You might be able to do the same.
#95
Hey brad :
if you have the cutting file I will apreciatte if you post it or send Red: there is a lot of information already here, but I will post all the process Merry xmas!! |
#96
Conrado: Felice Navidad y propsero ano nuevo.
#97
Gracias.. mis mejores deseos para esta comunidad
donde todos nos ayudamos a construir una gran herramienta de hobby o de trabajos Felices fiestas happy Holidays |
#98
I didn't keep the toolpaths, but I think this is the drawing that I converted.
It should at least give you an idea for designs. I recall taking off 0.05" per pass, so it was 11 passes, don't recall the feed rate. SpindleClamp5.dxf |
#99
Thank You Brad !!
#100
Today I ran a spindle test, everything works fine, there is a huge difference between the noisy router and the New Chinese 3 Kw Spindle.
Tomorrow I will rearrange cables and reconect everything in its place Next step.. 4th Axis. |
#101
Upgrading
Hello Friends :
upgrading to 4 axis is done, Installing, New echain done New rails...in progress Gas spring...done New painting.... in progress Photos..... Soon ![]() Best regards |
#102
Good to hear from you Conrado! Cant wait to see your pics.
#103
Hello :
Now my Mechmate is Red (was Blue), here some pics of little upgrades Cheers mech 01.pdf mech 02.pdf mech 03.pdf mech 04.pdf |
#104
Kiuvo,
Oye con que tornillos montaste los motores a las placas? Con tornillo con cabeza conica? Porque los estaba tratando de montar con los tornillos que venian con los motores y las cabezas topan con los carros, cierto? Saludos, Hector |
#105
Los compre aparte, son de rosca fina de los de cabeza para llave allen
#106
Otra preguntilla...como solucionaste los del amortiguador del eje Z, donde lo conseguiste? Saludos... Hector |
#107
Si, fui a un deshuesadero de carros y compre uno por 150 pesos, ahi mismo lo probe empujandolo a mano y con eso, revise, el largo del piston, y lo monte.
si los quieres nuevos, los puedes conseguir en autozone, pero fijate bien que no esten muy duros. Saludos |
#108
Necesito tu ayuda tendras un diagrama de como conectar los motores a los geckos...?
#109
Ps ya Quedo Hector, hasta ya vi tu primer corte, muy bien felicidades
#110
Conrado y todos nuestros amigos en Mexico! Felice Navidad y Prospero Ano Nuevo
#111
Que tal Conrado y Hector, me da gusto ver que mas gente de México esta fabricando la mechmate, yo soy de Cd. Victoria Tamaulipas, y me faltan algunas cosas para terminar la mia, pero voy a retomar el proyecto ahora que hay un poco de dinero y voy a empezar a subir fotos para que me den su opinión, quisiera preguntarles donde mandaron cortar el kit de piezas del gantry y todas esas piezas que van cortadas a laser y dobladas, y mas o menos en cuanto dinero les salio el trabajo, saludos!
#112
#113
Spanish site?
#114
que tal hector, de la persona que dices que vende los baleros, es el de superiorbearing.com???
#115
Yo se los compre a Joe, pero creo que ya no los vende, ahora, mike, el moderador del foro vende el kit completo,
#116
Si ese...
#117
#118
Hello everyone!
I have this problem: Two of my motors are not working properly, One of the X axis and Z axis. They randomly change direction. Disconect spindle, and every other device to eliminate any interference. I Will keep trying to solve it. Any help is Welcome. |
#119
Stepper motors that are driven by Geckodrive controllers, have two signals, step and direction. If there is noise on either line, you will have severe problems.
My first impression is that you have some electrical noise on the "step" signal. Be sure that you have properly "grounded" the machine. Check and recheck the ground connections. |
#120
Thank You Mike
I started to rewire the control box, its easier for me to do that than look for the cause of electrical noise.. I will post the Result Thanks again !! ![]() |
| It Cuts the Wood and Aluminum #76 - Guadalajara, Mexico | rceja | MechMates already cutting | 85 | Sun 17 November 2013 06:26 |
| It runs! #89 - Monterrey, Mexico | kanankeban | MechMates already cutting | 118 | Tue 17 January 2012 18:42 |
| Mechmate Parts for sale w/photos. Finally | stphnd22 | The Market Place | 14 | Wed 07 September 2011 20:25 |
| Mechmate cutting in Puebla | TimWerding | Introduce yourself and start planning | 3 | Sat 21 May 2011 08:25 |
| 3D Elk cutting (video) #13 - Hagerman, New Mexico | Greg J | MechMates already cutting | 415 | Sat 05 September 2009 20:28 |
