Old Mon 29 February 2016, 04:19
racedirector
Just call me: Bruce #122
New South Wales
And I'll 3rd that, lots to do on the machine, motivation at an all time low!
Old Tue 08 March 2016, 08:05
I don't feel so bad now
Old Sun 17 April 2016, 12:01
I believe I have been lazy long enough. Time to get back to it.
Old Sun 17 April 2016, 13:41
right !!!...
Old Sat 09 July 2016, 18:24
I have to say that the vac holddown using the wet/dry vac has been really helpful that I first posted here. I am almost done with my vac box design to have a standard unit that can be used in multiple applications. I don't need an entire table but I do need it from time to time.
On a side note, I am finally kicking the laziness out of me.
Old Sat 09 July 2016, 19:37
With patience....and some determination....all can be done
@_+
Old Sun 10 July 2016, 05:38
Does that mean that it will not be so quiet on here
Old Sun 10 July 2016, 09:31
It may Al
Old Sun 10 July 2016, 13:42
So I finally figured out how to turn the image representation get both grain orientations on Aspire. I figured it was an image that they were using for a texture and they are located in ProgramData Vectric folder. I just edited the image with GIMP (that is the program I use but any image manipulation software will work) by rotating the image 90° and saved the file with a name that represented the new orientation. Now I can see better how it will look after the part is carved in the grain orientation I will cutting the part.
Old Wed 13 July 2016, 14:35
Thats awesome.
Old Sat 16 July 2016, 07:14
racedirector
New South Wales
Originally Posted by pblackburn View Post
Vac: I don't need an entire table but I do need it from time to time.
I am like you Pete. I'll need some form of vac hold down for some things I plan on cutting but don't (at the moment) need the whole table. Interested in your generic vac solution.
Old Thu 20 October 2016, 17:56
I will try to post some things
P1040004 by Pete B, on Flickr
P1030860 by Pete B, on Flickr
Old Thu 20 October 2016, 19:46
racedirector
New South Wales
Nice Pete, nice. Love the owl....
Old Thu 20 October 2016, 23:03
More of a boob fan me
Old Wed 04 October 2017, 23:48
Thinking about building a separate machine for 4th axis cuthing only
Old Thu 05 October 2017, 05:46
If you have the work for it , do it.
If you want something to do , do it.
Or just do it.
Old Thu 05 October 2017, 05:58
Agreed
Old Thu 05 October 2017, 10:30
Old Fri 24 November 2017, 10:40
Here is one I did about a month ago
Griekspoor Sign by Pete B, on Flickr
Old Fri 24 November 2017, 10:50
Photo V Carve by Pete B
Old Fri 24 November 2017, 11:30
I also have a vacuum box halfway functional based loosely on the Black Box Source thread over at Shopbot forums. (Halfway because I have not bought the additional 2 motors yet) Since most of my work is small, every motor is independently controlled with ball valves on each motor to a filter box before going to a holddown jig. This way I can use only the amount of vacuum that is required. I do not use a full spoilboard holddown as some of you here are doing. I also use this inline with an old wet/dry vac bottom canister with a drywall dust bag and CV06 Mini cyclone for vacuuming up the floor. Only one motor is needed for that.
Old Fri 24 November 2017, 12:10
Thumbs_up_1.jpg....
Old Sun 25 March 2018, 12:22
Every year I say I am gonna draw up an Easter Egg holder and every year passes. Today I decided to do it. I will post or send the files if you would like them. It is designed around 0.25" material with 0.002" clearance. I added extra support as the store bought ones always seem to sag if the eggs are left on them for an extended period of time. I haven't cut it yet so there may or may not be some issues to resolve. This is the draft render from Rhino 6 so the cutout with a 1/8" bit will have a rounding effect on some parts. I have previewed it in Aspire and if I want a little more detail you can use a 1/32" bit or scroll saw for fine points.
Old Sun 25 March 2018, 13:08
Looks.....nice @_# !!
Old Wed 01 May 2019, 17:32
Just have to say this forum thread just saved me a lot of troubleshooting time. My modbus wasn't starting up my spindle. Looked back through my build history and found one setting was disabled. Don't know how it happened but saved a lot of guessing.
