Old Sun 04 August 2013, 09:33
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Thank you for all recommendations and nice words. Still have a lot to learn. Already did some mistakes but is from mistakes you learn more... here is one of the first mistakes... I mean: cuts
Video link: http://db.tt/HzoaHUGX
Old Wed 07 August 2013, 10:06
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Don't forget www.thermwood.com ecabinet systems.
Old Fri 09 August 2013, 17:52
digger
Just call me: Milosh #113
Toronto
Tim
How you can use ecabinet with mach3?
Milosh
Old Wed 28 August 2013, 23:02
hevertg
Just call me: Hevert
maracaibo
Venezuela
As meters
Originally Posted by parrulho View Post
Got it from ebay:
http://www.ebay.com/itm/2-Cable-drag...item3a5e71bd8b
received a different cable chain but I did not complain because I liked it...
Quality is good but he asks $30 extra for shipping...
As meters of chain I need for my mechmate? is 3000 * 2200 mm
Old Sun 01 September 2013, 09:12
parrulho
willemstad
First upgrade on my machine: a new power supply. went from 48V to 73V measured. Now it can moves on max velocity without losing steps but to be honest I don't "feel" more torque. I still can move the gantry pushing it a bit hard. Well it should be normal... Have cut some complete 4x8 board, ply and MDF and small jobs and I'm very happy with the quality. still waiting to get more mill bits. In Curacao it is difficult to find and very expensive. Then I needed to stop. A LOT OF SAWDUST!!! Have installed a small shopvac and it is helping. still busy experimenting with different dust shoes. I'm using 40mm pipe and it's works for now. Will post some pics later.
Old Sun 01 September 2013, 09:25
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Hi Milosh, you export your job from ecabnets in dxf . I use aspire to convert the dxf drawings to gcode.
Cheers All!
Old Mon 02 September 2013, 19:32
timberlinemd
Just call me: Steve #66
Arizona
Cheers All!
There is no export ability to dxf in eCab???
Old Tue 03 September 2013, 17:45
parrulho
willemstad
Just to report that I have changed limit resistors on geckos from 12.8K (calculated by formula) to 20K. that way I have more holding torque. Had some problems on Z, I'm using a lighter router Kress 800W, temporary, and the gas strut is pushing it up hard, it's is 30lb, for a spindle. Sometimes when I'm changing tools I lose Z zero. During the cut, no problems. let see if the motors do not get too hot...
Old Tue 03 September 2013, 22:11
hevertg
maracaibo
Venezuela
Bits
http://www.woodmagazine.com/woodwork...t-overheating/
Want to prevent those annoying burn marks that leave your routed edges black and your face red? Keep cool by putting the following tips to work.
Keep it clean
Ideally, you should wipe your bits clean after each use. Most of us, though, just drop them back in their holders and walk away. Unfortunately, resins and dust build up that cause bits to get hotter faster, making them more likely to burn the wood. If your bits are covered with sawdust, wipe them with a dry cloth. Remove the stubborn build-up with a blade-and-bit cleaner. The benefit: Clean bits stay sharp longer because excessive heat breaks down carbide cutters.
Stay sharp
A dull bit cuts poorly and builds up heat doing so. If you can run the cutter over your fingernail without shearing off ashaving, then your bit needs sharpening.
To freshen up router bit cutting edges with diamond lapping stones, hone only the flat surfaces. Count your strokes to make sure you remove the same amount of material from each cutter to keep the bit balanced. It only takes a half-dozen or so strokes with each stone. If that doesn't restore cutting ability, have the bit sharpened by a pro or replace it.
Set speed limits
Router bits spin up to 24,000 revolutions per minute (rpm). And most bits have two cutters, so they take up to 48,000 bites every minute. Think of it that way and you see why bits and wood heat up in a hurry. To keep things cool, set your router speed according to the chart, below right. If your router doesn't have variable speed, you can get a plug-in controller for less than $25. (Check your local retailer or contact MLCS at 800/533-9298; mlcswoodworking.com.)You can keep heat in check too by controlling how fast you feed the bit into the workpiece. A slow feed rate generates more heat. Use a fast and consistent feed rate to keep the bit and wood cool.
Watch your woods
Some woods, such as oak, don't easily burn. Maple and cherry burn notoriously because of their density and the oils and extractives they contain. Among softwoods, pine can be troublesome in areas that contain pitch pockets. With these species, slow the router and increase feed rate to minimize burning.
Take it one step at a time
Powerful routers and sharp carbide-tipped bits are capable of hogging out large cuts in even the hardest of woods. But doing so stresses the bit, causes tear-out, and leads to burning. When removing more than 1/4" of material, make multiple shallow passes.
Old Fri 06 September 2013, 00:34
parrulho
willemstad
Thank you for advices and title, my machine deserves a number
Old Fri 06 September 2013, 18:57
timberlinemd
Arizona
Yes it does. Where is Metal Head?
Old Sat 07 September 2013, 11:44
parrulho
willemstad
Still limit resistors on Geckos:
using 20 KΩ instead of 12.8 KΩ calculated by formula - Motors are always hot, cutting or idle is the same, you can let your hand over it for long time but too hot for my peace of mind... My decision is to change back resistors on drivers running X and Y to 12.8 KΩ and 18 KΩ on Z temporary...
Let's see.
Old Mon 09 September 2013, 10:29
I have been MIA for a few days.
Congrats and you get #108
Old Mon 09 September 2013, 10:43
parrulho
willemstad
Thank you Mike.
Old Mon 09 September 2013, 20:13
Great job!!!
Old Tue 10 September 2013, 03:56
Andrew_standen
Just call me: Andrew #109
Dorset
Smile
Congratulations number 108 from number 109
Old Tue 10 September 2013, 21:34
parrulho
willemstad
thanks 109 same for you. hey, I like a lot your kayak, I m thinking to build one for myself.
Old Wed 11 September 2013, 00:57
Me likey kayak.
Old Wed 11 September 2013, 02:32
Andrew_standen
Dorset
Smile
Kayak was built from plans see Redfish kayaks, "return" model.
Took about 300 hours to complete. total cost about 625 uk pounds. including cost of the plans.
Weight 22kgs length 5.8mtrs .. and it was fast on the water.
Old Wed 11 September 2013, 07:33
Updated Builder's Log
Paulo,
Congratulations on your MechMate and earning Serial Number 108.
Here's the Updated Builder's Log with your entry added.
Sorry to be tardy, but I was on a Cruise in your beautiful Caribbean.
Old Tue 17 September 2013, 23:04
parrulho
willemstad
Thank you John, did you stopped in Curacao?
Upgraded Power Supply, small dust extractor installed, first time spoil-board surfaced and more important, first paid jobs It's a good start and I'm very proud of my machine.
Dust foot works very well is from: http://solsylva.com/cnc/vacuum.shtml
Dust separator also works 100%, from: http://www.jpthien.com/cy.htm
Old Wed 18 September 2013, 00:48
Congrats on the 1st paid job! Wishing you more to come!
If you are serious about real production, do keep a few spare buckets for your Thien. I have0 2 huge barrels, each will last 4~6 hours of wood chip/dust.
Old Wed 30 October 2013, 19:32
parrulho
willemstad
3kw spindle
Time for very welcome upgrade, from 800w router to 3kw chinese spindle Still busy mounting it. VFD is a Mitsubishi FR-D720-165-NA. I plan to use Modbus on Mach3.
File Type: jpg 1426296_10200678039022598_1939055645_n_650x488.jpg (33.2 KB, 618 views)
Old Sat 02 November 2013, 19:14
Modbus is the way I did it. Was not to bad to set up. Plenty of examples here and at MachSupport forum.
Old Sun 01 December 2013, 14:40
parrulho
willemstad
I'm been busy outside of mechmate project... My new spindle is working very well, but using manual start, stop. Could not get any comms between VFD and my PC using the RS232/485 converter. Need more time testing and change different combinations of wires. Not sure about pinout at vfd or converter.
here is a video of my machine carving a maya calendar. https://www.youtube.com/watch?v=JJwxNlgnH3s
Old Sun 01 December 2013, 15:27
That's cool. What material are you cutting? looks like foam.
Old Sun 01 December 2013, 18:08
sierra347
Just call me: Armando #110
Montgomery, IL
Nice calendar Paulo, How long did it take to cut? I've been meaning to cut 36" one.
Old Sun 01 December 2013, 19:16
parrulho
willemstad
Tom, material is Moisture resistant MDF white faced, it hold details very well.
Armando, the size is 24", I leave my machine unattended and then I found it paused by itself (first time happen) I don't know how long it was paused but the cut took less than 2 Hours for sure and it could run it more fast.
Old Tue 03 December 2013, 13:11
Jbozaf
Just call me: Boza
San Jose
Costa Rica
Hi!
Hi Paolo! how much money you spend in this machine? I want to build one myself but i dont know how much money it cost.... ty for your time and congrats for that nice machine!
Old Tue 03 December 2013, 19:58
parrulho
willemstad
Thanks Boza. I can't tell you exactly the cost of my machine, I was collecting parts during 2 years and buying all my tools at same time (it was my first metal work) and never logged the expenses... As Sean indicated be prepared to expend 6 to 8 thousand USD, it depends on quality of the parts and shipping/taxes to get it imported. I was lucky enough to get most of the heavy and expensive parts from Mike, Metalhead: laser kit, motors, drives and controlbox with most of the components, all in very good quality. It saved me a lot in shipping.
It Aint Finished Yet -The Netherlands Hans Construction started, but not cutting yet 31 Thu 27 April 2017 20:34
Planning new build in The Netherlands eddies-customs Introduce yourself and start planning 5 Sun 21 October 2012 14:39
Planning a new build in Edam - The Netherlands Polder48 Introduce yourself and start planning 9 Sun 02 August 2009 05:56
TimCooijmans his CNC - Netherlands timcooijmans Construction started, but not cutting yet 8 Thu 05 June 2008 06:19
