Old Sat 04 February 2012, 18:22
Charles,
It really is a user choice based on the orientation of your machine in the work space.
I personally have 0,0 (if looking from the sky view) on the bottom right, which means it's on the right of the short side of the machine. This is evident when you look at the spoil board because the distance from the side C channel to the spoil board is shorter here, which makes working on small parts in the small corner easier.
You will be required to define the o,o in your file generating software and the clockwise and direction of the file being built.
For instance, if your 0,0 is in the bottom right like mine, then to travel to 60x120 is actually and -60, +120 move. The software does this for you, but you can see the actual results in your g code when it call each move out by line.
Not to confuse you - but your machine set up can be manipulated any way you chose that makes sense to your workspace.
Old Sat 04 February 2012, 22:47
There might be confusion on what is "bottom", or where is the "right side when you face your machine". I think I am speaking for most of us when I say:
The job of the MechMate is to make a solid model of something that we have on our computer screen - yes, that thing in front of you at this very minute. That is the starting point. So, where do you have 0,0 on your screen when you are in a CAD program? Most of us have it bottom left. X goes across the screen to the right, Y goes up the screen to the top.
Our screens are wider than what they are tall. The natural way to lay the screen image onto the bed of the MechMate is to get the long axes parallel. So we will have the main beams at the top and bottom edges of the screen and the gantry runs vertically across our screen as we see it now.
The open end of the MM is in from the left or right sides of our screen. We tend to spend most of the time standing on the left side. If we stand there, then 0,0 is to our right, nearest to us with Y going left and X going away.
But, the basic principle stays - where is 0,0 on your screen for CAD, and then how will you lay your screen image down on your table?
Last edited by Gerald D; Sun 05 February 2012 at 04:01.. Reason: fixed X going away
Old Sun 05 February 2012, 01:30
I ageree with Gerald, and everybody that I helped in building or setting up a new machine I tell them to place the screen in the same plane as the work table. This way you know where the machine will move. Once you understand this concept, you will NEVER run into the side of the table or off the rails...hopefully.
Gerald don't you mean Y.. going away.. Z is the plunge ?
Old Sun 05 February 2012, 04:02
Thanks Kobus, I meant X going away (parallel to main beams) - have edited it now.
Old Fri 13 December 2013, 18:26
racedirector
Just call me: Bruce #122
New South Wales
Sorry to quote the whole post of an old thread but this is THE best explanation of X, Y and 0,0 I have seen anywhere, fantastic work Gerald. I think this post should be stickied somewhere for those wondering where 0,0 should be.
Bruce
Old Fri 13 December 2013, 19:32
http://www.mechmate.com/forums/showt...8&postcount=62
Best to comment and link off to the thread.
Old Fri 13 December 2013, 19:35
racedirector
New South Wales
Sorry Mike, will do that in the future.
Long Awaited Return to Build - Paragould, AR Hillbillie Construction started, but not cutting yet 25 Wed 20 July 2011 18:17
Aussie Builders - Anyone Wanting to Sell Their PK296A2A-SG7.2 rotorzoomer The Market Place 3 Sat 10 April 2010 22:01
How many motors use mechmate in the long axis albertoslayer Motors & their mountings 11 Tue 09 March 2010 10:44
Wanting to build a CNC router dkrueger Introduce yourself and start planning 5 Fri 05 March 2010 08:38
Customer wanting someone to build a MechMate to spec dneisler Archives 43 Tue 05 August 2008 15:48
