Old Thu 01 May 2014, 17:33
The glue will fail for sure at some point
design an enclosure around the whole motor with some went holes at angle that water won't penetrate, in this scenario motor will rust for sure if sprayed with water (paint will hold it off but all of them have some scratch and they will rust eventually on that point), screws that hold the parts of motor will too, and the sticker protecting the back hole could peel off.
I can't say for the gearbox but I think that its not watertight, some who have opened them can say for sure if its or not.
Old Fri 02 May 2014, 17:54
Guillermo
Just call me: Guillermo
Puerto Ordaz
Venezuela
Danilo.
Good point. Rust is a factor that I had not considered.
A motor inside a enclosure will be fine whenever we ensure it does not overheat.
That's something for what I will have enough time to review. For now I need to focus
on the kitchen table project.
Regarding to the PS wiring. 25V+25V parallel = 25 VAC x 1.4 = 35 VDC that is the
power needed. Could you or anyone else confirm if the diagram with red indications
is the one corresponding to this configuration.
Thanks.
Guillermo
The baby beast is cutting away - Peurto Ordaz, Venezuela Hugo Carradini MechMates already cutting 176 Sun 15 April 2012 06:47
MM Amazonas/Venezuela alexguan Introduce yourself and start planning 0 Wed 19 May 2010 06:50
CNC para Venezuela suzuki039 Introduce yourself and start planning 4 Thu 04 February 2010 19:26
Project? n-ghadimi Introduce yourself and start planning 1 Tue 03 November 2009 05:03
Alternatives to Laser Cutting - Waterjet, Plasma, Oxy-fuel? Rob Smith Profiled (laser cut) & bent steel plate 26 Sun 25 January 2009 10:30
