Old Sun 13 March 2011, 21:35
tnarch
Just call me: Tuan
Milwaukee WI
Gerald, I tried two different pcs. We have a few different ones at the shop. I suppose I could try again with a newer pc and cable.
Old Mon 14 March 2011, 05:55
I have some questions.
Have you tried to run the motors half coil?
What kind of wire are you using? Can you give us the numbers off the wire?
Measure the resistance of the run of the wire with an ohm meter. Tell us this resistance value.
I would also shorten the hookups and make them as short as you can so as little wire as possible is sticking out of the shielding. Both ends. Also make sure only one end of the sheild wire is grounded.
This may not help, but I would also twist the motor wires so they are not laying patallel to each other.
Show us more pictures of your setup.
Also I would like to see a closupe or the color code of your set resistor on your gecko. If you relied on someone to give you the correct OHM resistor they may have given you the wrong one.
What power supply are you running for the motors? Voltage?
Old Mon 14 March 2011, 07:08
You need to turn the Gecko 'standby' on. Leaving 'standby' off can only be used when the motor's current is 2A or less. You'll eventually get excessive heating unless the stepper drivers are allowed to automatically reduce current.
Isolating electrical noise can be very hard. I would first try disconnecting the spindle and then doing air cuts. If the machine works properly with the spindle off, then further attention must be paid to the spindle and its wiring. If the machine still has problems with the spindle off, then something needs to be changed in the basic wiring of the control box, but, at least you would have an idea where to start.
Old Wed 16 March 2011, 07:34
tnarch
Just call me: Tuan
Milwaukee WI
Mike & Mike & Team Mechmate
Motor has 8 wires. I tried unipolar (half coil?). No difference. I'm usine 16 AWG cables from here. They are shielded.
I have a digital mutlimeter. I was able to measure voltage and saw -58V and 58V at the motors. Negative and positive direction I assume. How do measure resistance? Do I measure the same way with the dial on the meter turn to ohm? I tried that and all readins were 0. Not sure what that means.
I did shorten all control signal hookups. From and to BOB. From to Geckos to motors. As for the grounding of the cable shielding, I haven't done this yet. Do I ground the shielding to the same point as earth ground?
I will try twisting wires. Pictures of set to come soon.
Power supply is a Keling 6520. 65V 20A.
Geckos Standby are turned back on.
Lastly, I've been trouble shooting this whole time with the spindle off.
Thanks again everyone for the suggestions. Just have to keep trying I suppose....
Old Wed 16 March 2011, 09:58
So neither end of your cable shielding is grounded?
Old Thu 17 March 2011, 13:23
Hi Tuan, just getting back to this after some time traveling. Back in posts #59 / #60,
I was asking if you had strong motor torque _while the system is exhibiting the problem_. You indicated that you ran the machine against the stops slowly and the pinions disengaged. Did you manage to do this in the direction that the machine won't go?
What I'm after here, is trying to assess if the motor strength is dropping during the time the system is failing; you could also try turning the system on, trying to manually push the gantry in both directions (shouldn't be possible), and then trying again after the issue shows up. If it becomes possible to push it, we're looking at a power stage problem; if not, likely a control stage problem.
Another thing to try is to measure the control signals at the Geckos. You should be
able to clearly see two solid voltage levels on the direction pin (relative to ground), depending on which way you jog. And if you jog several times, you should be able
to observe the step pin stopping in either the on or off state after each jog - you can again see the voltage levels. The question is whether these change in behavior when the system is working correctly vs incorrectly. Choose the Gecko for one of your problem motors, of course.
Old Thu 17 March 2011, 13:50
Are you able to turn stepper axle easily by hand, when there is no power to them? I had problems with some steppers with miss aligned rotor, it too wanted sometimes to go in one way and not the other and would heat fast, if you cant turn it easily it must be the same problem. I solved mine with dr.Hammer knock to the axle from the back of motor, that set the rotor to right position and motor gained in torque and speed.
Old Thu 17 March 2011, 19:05
Hi Tuan
It's no fun when things don't work as they should, but persistence pays off in the end.
From my reading of your thread grounding does not seem to be in place on your machine yet, so that is where I would invest my time first.
Several grounding strategies are discussed on the forum however my information is that grounding the cable shields at the machine is the typical way grounding is done in an industrial setting.
The machine itself will also need to be grounded, eg Y car to Gantry to Table Base to Earth.
Reducing complexity of the system to the bare minimum while still displaying the unwanted behaviour is really important.
1. As you have indicated you do not operate the spindle (but you have not said if the VFD is still turned on, so actually disconnect this until the issue is resolved)
2. In Mach3 turn off the resume and feedhold buttons in ports and pins, input signals.
3. Do not use any wireless devices to jog, only use the keyboard
4. Turn off or reduce micro stepping on the stepper drivers to a minimum.
5. Ensure the steps per values in Mach are correct for the stepping values you have selected using Gerald's gear speed calculator spreadsheet.
6. Actually check that the system you are using is capable of pulsing reliably enough using the application called drivertest.exe in the root directory of the Mach3 install.
7. Your Power Supply seems good from what I have read, but you might also consider disconnecting any steppers that are behaving well, as this will ensure power is not in short supply to the steppers that are problematic.
Old Sat 19 March 2011, 11:46
tnarch
Just call me: Tuan
Milwaukee WI
Some new development.
The slaved X motors started making really loud grinding noise like the bearings are broken. Lets add insult to injury. I thought.
After regaining my composure, I decided to decommission the entire line. I disconnected the power to the Gecko for this motor. Connections to the PMDX are also cut (pin 8 and 9). Something clicked!
Power supply current output is 15A at 56V. My Geckos had always been set to draw more than 4 amps up until this point. Simple math of 4 x 4 = 16 lead me to think the Geckos were over drawing current from the power supply. With the slaved X motor still down, I set all the Geckos to draw 3A. Voila!!!
I ran the roadrunner gcode program at the different feedrate of 15, 60, 100, 150, 300. I also isolated the axes and ran each independently. I also ran combination of 2 axes: XY, YYZ, & XZ before running all three axes at the same time. The spindle returned to correct referenced (0,0,0) at the end of the program everything single time
I am reluctant to rewire the slaved X as I am not 100% confident the bug is power. I have a job that needs to be out by the end of May, if this configuration continues to work, I'd rather keep it working before bringing the slave X back online.
Will the gantry get of out square with only one X? I am keeping the the slaved X engaged but not powered.
Again, thank you everyone for your advice and suggestions. Keeps me trucking on.
Old Sat 19 March 2011, 12:04
Don't know if it will work so well without both X-motors driving. Long long time ago in the world of Gecko I had a Gecko stop working on my one x-motor and the gantry was WOBBLY...or must I say shaking like a man in need of a stiff drink.
Old Sat 19 March 2011, 12:37
I'm surprised that the gantry moved cleanly with only one X motor. I expect that if you attempt a heavy cut close to the inactive motor, you may have some issues with accuracy. Why not try adding the additional motor at the lower amperage settings?
Another thing to try would be to swap motors to see if the one motor is bad.
However, given that you have a 15 A supply, and you had peak currents set for
over 23 A (you said 5.8 x 4, right?) I think you're on the right track. As mentioned above, you may want to try going to half-coil wiring instead of the parallel. This would match up nicely with your supply. Note that we often have systems with power supplies smaller than the total calculated draw, since all motors drawing at peak doesn't happen. But given a draw of 2.9 * 4 = 11.6a at idle, it's not hard to see that you might go over the top. You won't have that problem at 3A, and I'd bet, not at 4.4A either (half-coil).
I think you've probably solved your own problem here, now you just need to test it!
Old Sat 19 March 2011, 17:20
tnarch
Just call me: Tuan
Milwaukee WI
Got into the shop and did some more testing.
I can say with 99% certainty the former slaved X Gecko was the culprit for all my troubles. Any motor I hook up to it will make that clicking noise (grinding as I described in #69). I also tried to run this same Gecko from different pins, other than 8&9. Same problem.
Can anyone shed some light on how a bad Gecko would put the whole system into failure?
Also, turned on VFD and spindle and everything is smooth thus far. Ran the spindle at 6000, 8300, and 11250 rpm with no noise problem.
Old Sat 19 March 2011, 17:23
tnarch
Just call me: Tuan
Milwaukee WI
By the way Brad, is half coil the same thing as unipolar? I ran unipolar and the motors got really really hot.
Old Sat 19 March 2011, 18:00
Tuan, half coil is not the same as unipolar; you would need a different driver to run unipolar (6 wires from each motor, not four). However, it's electrically very similar to unipolar; in both cases, you only energize half of each coil at a time. Unipolar does this by switching from one half to the other half; Bipolar half-coil does it by using one half, but reversing the current through it. In both cases, you would need to keep the amperage down below the 4.4A specification on the motor to prevent excessive heating; so that is probably why the motors ran hot.
Since you've indicated that your gantry runs with just one motor, I would say that it has been doing that all along; the clicking motor was effectively not being driven electrically, just dragged along by the good one. Not surprising that it wasn't 100% repeatable. There's a good chance that your early overheating made that one Gecko unhappy. The clicking is consistent with either thermal or current limiting circuitry kicking in too soon, or with a blown driver MOSFET. In any case, Geckodrive should be able to help you.
Looks like you're in the home stretch now.
Old Sat 19 March 2011, 18:05
I did not think you can wire Geckos up Unipolar?
Isn't half coil where you use half the windings that you have hooked up for Parallel. For Example Blue/Red and Brown/Black. Or Yellow/Green and Orange/White. So you only use 4 of the 8 wires and tape off the other 4 so they do not short.
This way you are only using half the motors coils.
Old Sat 19 March 2011, 19:45
PEU
Just call me: Pablo
Buenos Aires
Here is a guide of different wiring configs:
Old Sat 19 March 2011, 21:33
Hi Tuan
Well done, sometimes the amount of disassembly and reassembly to solve a problem can be intimidating - but you did it none the less.
I'm with Kobus on the gantry. I have ran both sides of my gantry with one motor only engaged and the wobble Kobos mentions is evident.
The slaved motor is not only winding up and down the rack it is also locking into a position on the rack when not moving.
This is very different from passively sitting there.
Effectively the locked motor becomes a pivot point for the gantry for any movement induced from the other axis's or any inertial movement from a change in direction or acceleration from the X axis itself.
Accuracy would be compromised and it would show up as an arc line from wherever the cutter position is with its center on the locked (or functioning) X motor.
Old Fri 25 March 2011, 16:23
tnarch
Just call me: Tuan
Milwaukee WI
Hello everyone
First off, thank you everyone for your help! I am happy to report she is live.
I hope this is the last time I'll be talking about my control woes. It turned out that in, addition to the bad Z gecko, the real error was the power supply to the BOB. All this time I did not once suspect the trouble was coming from the BOB because there was motion. After contacting tech support at PMDX, I learned 2 things:
1) I wired the regulated +5VDC into the BOB improperly. I should've taken notes and pictures from the kitchen table project so that I could have some reference after putting everything inside the box.
2) The reason why I had intermittent positive motion was that the BOB drew power from the computer.
It's quite embarrassing to learned it's been my carelessness all this time. However, I thought I would write it up as a lesson for future builders. On a positive note, I'm more confident with trouble shooting now The lesson is, like Ross said: sometimes starting over from SCRATCH is a good idea.
On an even more positive note, I'm still high on joy and excitement after a first successful run, from CAM to cut!!!
Old Fri 25 March 2011, 16:30
Doh! I was on that trail back when I was asking if the BOB power supply was getting warm. It probably was, but it was inside the computer so none of us saw it! We'll remember to ask the question the next time somebody is having problems, so thanks for sharing the resolution with us.
Very glad to hear you are up and running, hope you have lots of fun and profit with your MM!
Old Fri 25 March 2011, 19:37
Congratulations Tuan
My guess is you are going to appreciate your machine just that little bit more now after such a rocky start.
When I bought my toroidal power supply, it had additional taps for 5 volt and 12 volt so that was what I used as power to the BOB.
Probably a wise lesson for other builders to distrust the PC power supply, not so much as it is a PC power supply but because of the great variability in their build quality.
$10 - $200 last time I looked. I'm sure you could weld with the $200 PSU but not with the $10 one !!
Your test run looks quite artistic, It looks very much like some of the sixties graphics.
Pump out the work and show us a few pics to keep us interested.
If you can match Kobus for speed and variability of your projects, you achieve instant legend status
Old Fri 25 March 2011, 22:44
tnarch
Just call me: Tuan
Milwaukee WI
Ross, thanks for the compliment on the design.
I should clarify. I wasn't using power from PC. I had a 5vdc regulated source from my control box power supply. I just wired it incorrectly to BOB.
Brad, I hope you are right about profits I'm crossing my fingers for a really BIG job we just bid on. The machine came online just at the right time.
Check out the video.
- 1/4" Solid Carbide Spiral
- 60IPM
- 0.1" to 0.45" Z depth in one pass
Old Sat 26 March 2011, 18:39
tnarch
Just call me: Tuan
Milwaukee WI
more testing
1/2" plywood
1/2" Carbide
20 ipm
1/8" Z steps
The striation is the result of the Z axis not plumbed.
Old Sun 27 March 2011, 02:11
IN-WondeR
Just call me: Kim
Randers
Denmark
I'm using a USB cable from the PC to power the BOB I have, it works like a charm...
Old Sun 27 March 2011, 05:38
Sweet!! I see paint and dust. How bout a logo? Great job on finding your problem !!!
Old Wed 21 September 2011, 16:10
tnarch
Just call me: Tuan
Milwaukee WI
it's been a while
Been making cold calls to cabinet makers looking for work -no luck yet. Did this little piece to keep me motivated. Current size is 15" x 22". Will cut a bigger one to be used as a mirror frame.
Old Sat 24 September 2011, 02:46
Tuan,
Take pictures of your work and when you make your cold calls, show the photos. It helps.
Old Tue 27 September 2011, 21:39
tnarch
Just call me: Tuan
Milwaukee WI
Nils, thanks for the tip. We do have a small portfolio of sample and professional work we've cut. I think I haven't found the right sales pitch yet.
How do you convince someone to give you work that he knows it can be done in house? The time saving doesn't seem to have as much weight as I thought or can explain/pitch to people. I think my rate is competitive, even on the low side being $75-90/hr depending on the job.
I would gladly take any advice anyone can give in approaching and getting new clients.
T
Old Tue 27 September 2011, 22:05
Maybe try to focus on the things that he cannot do in house. Show him how you can add value to the things he does in house.
Old Tue 27 September 2011, 23:20
$75-90/hr doesn't sound like the low side, particularly if you don't have orders. I think you will have to start out much lower than that.
Collets for the milwaukee 5625 router dragonfinder1 50. Toolheads 5 Thu 06 May 2010 08:47
Milwaukee 5625, how fast do you turn it. dragonfinder1 50. Toolheads 5 Tue 16 March 2010 10:33
Cutting speed becomes irregular - computer not matched properly martin77pl Troubleshooting 5 Wed 02 September 2009 11:55
Motors do not turn properly - poor quality wiring used for testing martin77pl Troubleshooting 8 Tue 31 March 2009 11:36
One of the four motors not running properly - faulty Geckodrive 203V cncb Troubleshooting 8 Sat 08 November 2008 07:46
