Old Mon 19 July 2010, 03:03
myousry
Just call me: myousry
alexandria
Egypt
GOT My VFD at last
hi guys i got my VFD after being lost or forgot at aramex USA depot . what i ve got for this wasted time . we are sorry - by aramex stuff.
Also we have the 4 oriental motor lost somewhere and we are trying to find them.
guys is DHL better ?
thanks for your patience
Old Mon 19 July 2010, 06:01
qroger
Just call me: Roger
Matthews (North Carolina)
[QUOTE=qroger;43538]
Originally Posted by myousry View Post
Basic Laser Cut Parts Kit (Includes Feet) http://www.cvsupply.com/servlet/the-...t-Parts/Detail
Rail Grinding Skate http://www.cvsupply.com/servlet/the-...g-Skate/Detail
There is a redundancy in the parts listed above. You should read the descriptions at the cvsupply site before you order.
Good luck on the build!
Roger
Rail Grinding Skate
This is not needed if you bought the MechMate Basic Laser Cut Parts set above.
Old Mon 19 July 2010, 10:13
myousry
alexandria
Egypt
thanks a lot for you Roger i got your notes and took it into my consideration to remove redundant purchases
Old Fri 23 July 2010, 16:52
PEU
Just call me: Pablo
Buenos Aires
Myousry, thanks for your detailed parts list, I used it to learn whats needed for the ensto breakers, I think you missed:
ENSTO Rotary Load Break Disconnect Switch, Door Mount Kit / $9.00 / http://www.factorymation.com/s.nl/it.A/id.5831/.f it goes on the backside of the control box door. Check this datasheet for complete aasembly: http://factorymation.info/Disconnects/ensto_ksrd3.pdf
Im looking for a similar part available in the local market, but if I fail I'll go with ensto.
Old Sat 24 July 2010, 00:17
myousry
alexandria
Egypt
thanks pablo i will add them to my list although i made changes to my list thanks again
Old Fri 24 September 2010, 02:45
myousry
alexandria
Egypt
i got my heatsink and my toroidal transformer but for the stepper motors, we got our money back as oriental motors didn't send them to us. i don't know why
and now we have to buy chinese stepper
Old Fri 24 September 2010, 03:02
Johannescnc
Just call me: John
Hannover, DE
Germany
Looks like another damaged part... Is this typical for Egypt? Still, I don't think it would be too difficult to fix.
Old Fri 24 September 2010, 03:16
myousry
alexandria
Egypt
aramex is a lousy shipping company but we stuck to it for being the cheapest shipping company in EGYPT
Old Sat 25 September 2010, 12:19
myousry
alexandria
Egypt
i made today some shopping for some stuff which equivalent to that in www.factorymation.com. there still other stuff to buy i am searching for it
Old Mon 04 October 2010, 12:01
myousry
alexandria
Egypt
more shopping.... I didn't buy the solid sate relays yet and my motor connectors
i have to go to cairo to buy them they are not found in alexandria
Old Sat 09 October 2010, 04:27
myousry
alexandria
Egypt
hi guys i forgot to upload the photos of the proximity sensors here is one of them. 4x NPN NO 4mm sensitivity 12mm diameter
Old Thu 21 October 2010, 10:51
myousry
alexandria
Egypt
hi guys all what i found for the xlr connectors was the 5 pole and the solid state relays with their heatsink
Old Sat 06 November 2010, 03:25
myousry
alexandria
Egypt
NEED HELP for overvoltage monitoring relay
hi guys,
i bought this voltage monitoring relay as there is an over voltage situation in egypt happens i.e you may find a 380V in a 220V power line because of a stupid electrical engineer . the link for relay
http://www.hiquel.com/en/machine-aut...e-control.html
i have changed the 35amps contactor with a 50 amps. i going to let the relay to control the coil of the replaced contactor in case of an overvoltage or undervoltage case took place. the problem that i face is that the coil of the relay needs to have an isolated AC 220V power source .
i intend to buy a UPS for the PC that will run the machine and to power the coil of the relay.
can any UPS take the 380V without being barbecued ??? thanks a lot
Old Sat 06 November 2010, 05:28
Johannescnc
Just call me: John
Hannover, DE
Germany
Are you certain about the Engineering? Are the power lines overhead as many in the US are? Could the problem be from Voltage spikes?
A voltage spike is defined as fast short duration electrical transients in voltage. All electronic and electrical devices are designed to operate within a certain voltage power supply, which is normally written on the product sheet/manual or on the device itself. Voltage spikes can damage these devices. One of the more common types of damage that can be seen is when a bulb is given a supply of power higher than its voltage rate, causing a burn out of its wire or even causing it to burst into flames if there is an over-voltage.
Voltage spikes can happen through natural causes, such as lightning strikes, solar wind and solar flares. A surge in supply within power, phone and signal lines can affect equipment over large areas. A storm that is occurring miles away can induce high voltage spikes in another location. Lightning doesn’t just cause surges when it strikes, lightning between storm clouds can also create magnetic fields that induce surges.
Man-made over-voltage is caused by electromagnetic induction when switching on or off inductive loads (like electric motors or electromagnets). Power outages, tripped circuit breakers, short circuits Electromagnetic Pulses (EMP) with its energy distributed up to 100 kHz in 1 MHz frequency range and inductive spikes. Surges in the power lines can also be generated at the switching station of a local power company. It can also be generated by electrical machinery, appliances and power company operating equipment. Common household equipment can generate 1,000 Volt spikes.
Old Sat 06 November 2010, 05:45
myousry
alexandria
Egypt
thanks a lot john for your clarification . do you know any UPS that can take the 380V overvolt in order to proctect the pc ,the monitor ,and the coil of the relay
thanks a lot
Old Sat 06 November 2010, 06:09
Johannescnc
Just call me: John
Hannover, DE
Germany
I am sure they are available. But I recommend being certain where the problem is coming from. Why spend more money than is needed? You may only need a simple surge protection device...
I lived in Florida where storms affected line voltages. An UPS was absolutely necessary because the power lines are mostly overhead and lightning strikes are common. Often the power would be off for an hour or more. But the UPS would give me time to shut down the computer systems until the lights came on again.
But for other equipment, this would not be very cost effective... IMO
That's why I had asked you about your local environment. Dry air is more susceptible to static electricity for example.
Here in Germany, winter air is dry and we need to be careful of static discharge. Most of our power lines are underground so no trouble with lightning. I have not seen a power outage as long as I have been here...
Old Mon 08 November 2010, 16:59
One note on the statics, In my location, I've never encountered static build up (EVER!!!!) until I have my dust collector...
Old Thu 11 November 2010, 11:19
myousry
alexandria
Egypt
HI guys i received the pump for the Chinese spindle and the flow tx plus in order to monitor the water coolant flow and its temperature. i bought it
from http://www.performance-pcs.com/catal...ain_page=index
Old Thu 15 September 2011, 05:33
adel_sebaey1
Just call me: adel
suez
Egypt
well myousry hope u all success
Old Thu 15 September 2011, 08:49
Looks good!
Old Sun 03 January 2016, 11:45
jayrdwein
Just call me: jayr
canberra
I have a mailbox through a forwarder in US and afterwards he forwards the package to egypt.
Southern Africa social group gathering sailfl Miscellaneous / General / Whatever / Catchall 409 Tue 23 October 2012 23:20
Moved to New Shop to Do Real Work! #81 - Damietta, Egypt 234ahmed MechMates already cutting 83 Wed 28 September 2011 12:20
Even More Inventive Use of Electronics jehayes Miscellaneous / General / Whatever / Catchall 0 Mon 11 January 2010 13:01
Electronics Order Spreadsheet jhiggins7 70. Control Systems 0 Wed 08 April 2009 07:44
Lower Cost Electronics? Aubrey 80. Computer Hardware & Software 31 Sat 21 July 2007 21:59
