Closed Thread
Old Mon 24 September 2007, 09:19
Hugo Carradini
Just call me: Hugo
Pto. Ordaz
Venezuela
Hello Irfan.
I bet your having a great time, no matter the doubts you can get. Keep going.
I like your solution to the limits switches. I was thinking in involving them in a very soft plastic to protect them from the powder.
  #62
Old Mon 24 September 2007, 19:20
Originally Posted by Hugo Carradini View Post
Hello Irfan.
No Hugo, I think the limit switches just need to be maintained, enclosing them in soft plastic may result in more dust accumulating within it. Any wayz if you have a proper dust evacuation system then there is no need to protect the limit switches.
RGDS
Irfan
  #63
Old Mon 24 September 2007, 20:42
Irfan & Hugo, all dust evacuation systems have a problem to work correctly at the edge of the board. When you are right on the end of a board, the cutter gets exposed.
Irfan, you have the right idea to lift a mechanical switch up, away from a flat surface where dust will collect. Also, the holes in the switch must point downwards (like you have it) so that the dust will fall out.
  #64
Old Tue 25 September 2007, 08:31
Hi Gerald and All,
I had a Q
1. for the timing pulleys which i will be using to drive the pinion can i use just the grub screws to hold the pulley's in place or is it necessary to have a key to bind it with the shaft.
2. If only grub screws can be used tehn how many, I was about to put 3 each 120 degree apart........is it OK
3. I expecting a center distance of 325mm, will that matter much?
4. I will be using a HTD 8 mm pitch belt. is it OK
Irfan
  #65
Old Wed 26 September 2007, 00:44
Hi,
Any answers to my previous questions
RGDS
Irfan
  #66
Old Wed 26 September 2007, 04:30
CNCzone
  #67
Old Wed 26 September 2007, 09:47
CNCzone
Righto Gerald,
I moved my thread to the CNC Zone, I will keep posting updates on this forum when ever there are major updates on my thread at CNC Zone,
Gerald, thanks for all the inspiration.
Next a mechmate in in my mind. I already have the vampires. So see you all guys later
at CNC Zone my address will be http://www.cnczone.com/forums/showth...147#post347147
Thanks for all the help!
RGDS
Irfan
  #68
Old Mon 01 October 2007, 12:11
http://www.cnczone.com/forums/showth...138#post349138
Updated with Pics and ideas
Closed Thread
