Old Sat 16 January 2010, 10:13
Chop Chop!!
Old Sat 16 January 2010, 10:33
Castone
Just call me: Leo #41
Soddy Daisy , Tn
Alright enough testing lets see some chips fly. From your vid it looks like you are on your way. Great job on the conversion.
Old Sat 16 January 2010, 11:22
Kobus, Hennie says he wants you to turn that into a chopstick.
Old Sun 17 January 2010, 03:22
Kobus,
I recently learned that turners will cut the corners off before they start to help round off the piece. It is a faster process done on a table saw and helps reduce machine time.
Old Sun 17 January 2010, 06:32
The rounding Gadget in V-Carve Pro from Aspire takes a square piece of wood and quickly make it round...I like watching BBB working.
Here is a short video showing that with Vectric V-Carve - Pro it is really easy to do spirals and fluting...Even I managed to do it first time around.
The lathe is not fixed to the ground yet and also not levelled, but I could not wait to try it..
http://www.youtube.com/watch?v=Wmlx6Y8w0c8
Old Sun 17 January 2010, 06:43
Breg Gat ! ek hou daarvan
Old Sun 17 January 2010, 11:01
Kobus, you make the whole subject of "indexers" look so darn easy!
Old Sun 17 January 2010, 13:06
KISS I am too stupid to re-invent the wheel.
I am not hugging and kissing, just keeping it simple
Old Sun 17 January 2010, 13:47
Nicely done Kobus! I definitely want an indexer!
Old Sun 17 January 2010, 16:52
mikefoged
Just call me: Mike #27
Randers
Denmark
really nice, I want one to..
Made this for fun, just to see how it's looks in blue
Old Sun 17 January 2010, 22:41
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
I think you find the next 'Gear' Kobus. Impressive.
Old Mon 18 January 2010, 01:01
Nice Mike I like the drawing. At the moment mine is bolted to the floor.
I have the following idea... Make a new shaft for that old lathe. This one a little longer than the original....16 mm up to the end.
Fit the old 3 way pulley on the shaft and connect the electric motor again.
Put my 120 tooth Module 1 gear at the end of this shaft after the pulley.
When I make spirals etc, use the stepper to drive the machine.
When I finish the piece (sanding or small steps that I did not get right with the CNC setup) run the electric motor. This will give me the SPEED to sand and polish the piece.
Also thinking of buying a 100mm taper lock pulley that will fit on the end and bolt my module 1 ...120 tooth gear onto this pulley. This will save some money as the engineering shops are mad with the price to cut a taper into my module 1 ...120 tooth gear.
Old Mon 18 January 2010, 01:22
Kobus, have a look for "weld-on" taperlock hubs. That type works with a key in the shaft.
Old Mon 18 January 2010, 02:16
Thank's Gerald. What is the best type ofsteel to get for a shaft....must be about 25mm then I will turn it off to 16mm on that side. Will mild steel bar work ?
Old Mon 18 January 2010, 03:22
Mild steel will work. Normally I would suggest you get EN8 which is slightly more expensive. But, nobody will sell you such a small bit and certify the grade - you will have to go scrounging and find a piece of unmarked steel in a scrap bin. So you aren't going to really know if it is EN3, 6, 8 or 24. Doesn't matter, you have a big diameter now.
Old Mon 18 January 2010, 09:14
Jan de Ruyter
Just call me: Jan
Pretoria
Kobus, there is a company in Sebenza on the corner of Ingwe and Grader Rd that sells short pieces of EN grade steel. In Wadeville between Rossouw and Nagington there is a company that sells ground bar, which will be much less troublesome than mild steel.
Old Mon 18 January 2010, 12:15
Why do I do it...Because I now CAN
Thank's Jan...Wadeville is close to my work.
I wanted to do this for a long long time. Now I did it. After bolting the lathe to the floor and setting up things to be level, I made my little piece. It is 3 flutes 150mm long.
I see I have a brand new heading...about time
Old Mon 18 January 2010, 12:31
mikefoged
Randers
Denmark
kobus very nice, see that is what indexer do .
I was thinking about when you bolt the indexer to the floor it is not flexing with the Mechmate, is this a problem.
Old Mon 18 January 2010, 12:39
Kobus,
Very nice, did you laminate the wood to get the interior hollow? I like it.
Old Mon 18 January 2010, 12:51
Hi Mike, I now find out that my table is not that solid. After using it for so long cutting X and Y, I did notice the table shake somewhat, but did not worry about it. Now with the indexer on the ground I can see the oscillations. As a temp. fix I wedged a piece of wood from the side to the wall. This weekend I plan to make some struts from the sides and bolt those to the floor. It was not causing problems, but I did not like the SHIVERS that old BBB showed....was worried he is getting old like me..
Heath, that is one solid piece of oak. I use a 6.35mm straight cutter and went in deeper and deeper. Set up V-carve pro to cut in 1.5mm steps up to 16.5mm. Then 0.8 mm deep cuts until I saw it cutting through....broke the first one when I tried to cut too deep too quickly. The twists are not that strong. At the end took a 12mm ballnose cutting a 3mm to finish the groove.
Old Mon 18 January 2010, 19:35
Regnar
Just call me: Russell #69
Mobile, Alabama
Reminds me of the Legacy Wood Working Tool Demo! Looks great. If I remember correctly if you are able to move the tailstock up or down you can make tapered ornaments. I should go and check out their website before I start passing on bad info.
Old Mon 18 January 2010, 22:10
Lex
Very nice Kobus!
You make things complicated for me. There are a thousand more ideas from the wife side after she looked at your post.
Old Mon 18 January 2010, 22:35
Kobus I see it is another thing that you can cross of your bucket list.Baie mooi
Old Mon 18 January 2010, 23:12
Jan de Ruyter
Just call me: Jan
Pretoria
Ground Bar Industries
42 Stanhope Road, Malvern East, Johannesburg
Telephone: (011) 607-2000
Old Tue 19 January 2010, 01:24
Baaie baaie mooi Oom
Old Tue 19 January 2010, 01:36
The way Kobus is playing with his MM it won`t be long then he is going on retire right in front of BBB.
Old Tue 19 January 2010, 10:45
gixi
Bucharest
Kobus, now you become my model... Please, please make a video with this job !
I didn't forget what I promise but Gmail don't allow sending exe files.
I'll find a way to send you those files.
Marius
Old Tue 19 January 2010, 11:17
Ok Marius, will do sometime.
Tonight decided to try the OTHER available gadgets in the V-Carve Pro program.
Firstly...HI-TECH way of setting the Indexer on Zero... you must have noticed that extra wiring to proxies and limit switches and stop blocks are out for me.
Then did a 4 flute where I ramp in and out at the ends.
Then a single spiral LEFT and then a single spiral RIGHT
And finally. The words MECHMATE, KOBUS and ERWA on a cylinder.
MAGIC........
Old Tue 19 January 2010, 11:19
mikefoged
Randers
Denmark
gixi just rename the file to .txt after the file name and kobus only have to rename it to .exe when he receive the file. easy
Old Tue 19 January 2010, 12:29
Kobus, enough already, that just looks like too much fun!
