Old Tue 25 November 2008, 11:08
kaartman
Just call me: Koning #20
Abu Dhabi
United Arab Emirates
My control box
Need some wire and paint, all in good time
Old Tue 25 November 2008, 23:10
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Hi Koning,
Does the second pc board at the top work with your spindle?
I see that you will have to use shielded signal wire like me as well.
Looking good!
Old Wed 26 November 2008, 08:14
kaartman
Abu Dhabi
Hallo Lex
Yes the second pc board is for the spindel control, shielded is the way to go, I can only follow the advice from my friends here in the forum, they have the experience.
Old Mon 19 January 2009, 02:10
kaartman
Abu Dhabi
Hi to all
I am back at working on my MM, work kept me away for a long time, I have done most of the control wires and some of the this and that things, tomorrow will be testing day to find out if all is working or not, The steppers is connected, Andeli VFd is connected, watercooled Spindel mounted and so on, pictures will follow with the questions of "why or how do I get the motors to turn,
Old Tue 20 January 2009, 13:17
kaartman
Abu Dhabi
Progress on the stoep
The kitchen table process is in progress, 3 of the steppers is moving and Y axis gecko error, When i power the control pannel all 4 Geckos green LEDs is on, as soon as i connect the cabel and motor to the gecko the red and green led lights up, according to gecko trouble shoot this indicate a short to ground. here follow my actions of fault finding:
1)Disconnected the motor and cabel from gecko - reset power= green Led
2)Connect only stepmotor cabel to gecko = red/green Led
3)Connect cable and motor to gecko = red/green Led
3)Complete elimination of short circuit in cable and motor winding with fluke multi meter = nothing found
4)Connect cable and motor from 100% working drive = red/green Led
5)Comlete gecko swap from Y drive circuit to fully function X circuit with no motor and cable connected = green Led
6)Connect any motor and cable to this gecko = red/green Led
7)Tested and swapped current set resistor = red/green Led
Any sudgestions on how to get rid of the Red led, can it be that the Gecko is "kapoet"
I had better success with the Chinese spindel, programmed the Andeli VFD, Spindel is turning nicely without the PMDX 106, have done the connetions for the Pmdx106spindel control card, now I need to find out how to configure Mach 3.
The water system to cool the spindel is in place, for now I will use a standard water bucket with a fish tank water pump, I have soldered bigger fittings to the inlet and outlet at the spindel to be abel to use a larger diameter tubing.
Thats all friends
Old Tue 20 January 2009, 13:43
Koning,
An easy way to find out if the drive is bad and you have exhausted all the wiring options, is to swap a known good drive for the suspected bad one. Or just swap a known good motor connection to the suspected bad drive to isolate bad drive or bad motor wiring.
Old Tue 20 January 2009, 13:46
kaartman
Abu Dhabi
The proof of progress
The MechMate Logo will be on the next set of Pictures
Old Tue 20 January 2009, 13:51
kaartman
Abu Dhabi
Hi Heath
I have done that in point (4) and (5), i wonderif should open the gecko to see if there is a piece of copper wire offcut stuck in there?
Old Tue 20 January 2009, 14:26
It's not clear in (6) if this was a good gecko in the bad circuit, or the bad gecko in a good circuit.
If it's good gecko in bad circuit, then something may be funny with the mounting or power supply to this one gecko. if it's the other way, then I would suspect a bad drive.
Old Tue 20 January 2009, 17:09
There is always the possibility that you have a defective G203v, but I'm guessing that the problem is improper grounding of the heat-sink. According to Mariss, who designed the G203v, the power FETs used in the G203v are grounded to the G203v's case, but the case is insulated from the heat-sink by its hard-anodized coating. If a screw cuts through the hard-anodizing, you might have a problem - unless the heat-sink is properly grounded to the power supply ground. So, verify with a meter that the G203v's heat sink is grounded properly to the power supply's ground connection.
There is quite a bit of discussion about the insulating properties of the hard-anodizing that Gecko uses on the geckodrive forum at Yahoo.com. Several people have had similar problems over the years.
(Grounding is often misunderstood and often done incorrectly. Gerald has posted photos and diagrams showing the proper methods to use when grounding.)
Old Tue 20 January 2009, 20:03
Excellent progress!
Your Gecko does sound suspicious. No harm in removing its cover and checking inside.
Old Wed 21 January 2009, 07:50
kaartman
Abu Dhabi
Hi Mike and Gerald, Thank you for the advice, Grounding:I removed the anodizing,at the point where I screwed it to the alu plate, ran a direct ground from Eleck supply to that point with a continued ground dicect to the motor = same effect
1) Removed step/Dir/Comm from PMDX 122 = red/green led replace these again
2) I removed one leg of phase B= red/green Led replace phase B leg
3) Removed one leg of phase A = GREEN LED
I think that gecko need to be replaced
Old Wed 21 January 2009, 08:25
Suggest you phone Geckdrive and discuss it with them. Be ready to answer the questions on their form:
https://www.geckodrive.com/upload/STEPPER%20RETURN.pdf
Old Wed 11 February 2009, 10:58
kaartman
Abu Dhabi
First cut
Hi one and all
I have received a new Gecko, the red LED is something of the past, my MechMmate is smooth as a clock (for someone inexperienced as myself), I am sure there will be some setting and adjusting to be done in the next week. I made the first cut today, nothing much only a circle. I control the spindle manually on the VFD, I still need to learn how to start/stop via Mach3
Old Wed 11 February 2009, 11:06
Koning,
Looks like all you need now is some labels and your good for a serial number! Looking great!
Old Wed 11 February 2009, 11:46
Well done Koning!
Old Wed 11 February 2009, 13:04
Koning,
Congratulations...!!
Old Wed 11 February 2009, 13:14
YRD
Just call me: Yuri #17
Brasilia - DF
Brazil
Koning,
Congratulations, smooth cutting
Old Wed 11 February 2009, 18:43
Koning - congrats
is that earth wire running thru the motor?
Old Wed 11 February 2009, 21:41
Pragtig ! Glad to see it nearly finished.
Old Wed 11 February 2009, 22:22
Koning, there was something unusual about your last picture, and it took me a while to figure what it was . . . .
The dust is so neatly stacked next to the cut.....there is no air stream from the router/spindle. It is now obvious that a water-cooled spindle will leave you with a cleaner workshop.
Old Wed 11 February 2009, 22:25
Lex
Goed gedaan! Well done. Koning
Old Wed 11 February 2009, 23:05
kaartman
Abu Dhabi
Vacuum
Thank you, it’s a nice feeling to see it cut,
Irfan, yes that is earth direct from the 220V main power supply, the blue wire is for the Z zero
Gerald
It is nice and clean, that cut was made with no suction on, what bother me is the little nick opposite the cutter, at that point the circle goes wider, will play today and see if it repeat itself.
I have made a swing arm that follow the Z axis, used 4" straight connectors to suspend the hose, fishing swivels between the hose and bracket to allow the hose more flexibility, it works for me, just add blue paint and it will be perfect.
Old Thu 12 February 2009, 02:22
and yes i see the water bucket - does it have a fish pump in it
Old Thu 12 February 2009, 02:42
Originally Posted by kaartman View Post
. . .what bother me is the little nick opposite the cutter, at that point the circle goes wider . . . .
Have a slow read through this thread: Circles are not cut round
Old Thu 12 February 2009, 03:11
kaartman
Abu Dhabi
Hi Irfan
An ordinary submersable water fountain pump, a fish tank waterpump does not deliver at pumphight (head) of 2meter
Old Thu 12 February 2009, 06:44
Thanks Koning - thats exactly what I was thinking
RGDS
IRfan
Old Sun 15 February 2009, 10:22
kaartman
Abu Dhabi
My Mechmate is official
I have been playing today with the MechMate, did my first cut today that I designed in TurboCad, Then we had the naming ceremony tonight...... nice isn`t it
Old Sun 15 February 2009, 10:31
gmessler
Just call me: Greg #15
Chicago IL
Great job Koning!
Congrats on #20
Old Sun 15 February 2009, 10:32
That is a proud man!
Indexer for me new toy to be Mojo General - MM Build 11 Sun 17 July 2011 13:49
Cheap wrapper for indexer normand blais CAM 0 Sun 24 January 2010 13:14
Indexer software Art Archives 6 Tue 15 July 2008 08:43
