Old Tue 05 February 2008, 18:51
caprail vs. MM steel rail ? Pro's and Con's
Robert,
I for one, actually made a mock-up of the cap rail and alum angle prior to deciding to use the MM rail system. I like both options for the right reasons. The next machine I build, and it will be soon, will be of the alum rail section for proof-of-concept. Plus, I like a challenge
Caprail:
Pro's
- easy to buy - but cost's more than just steel
- easy to drill
- alum ARCHITECTURAL angle easy to cut down to right height - but is an upcharge for alum
- alum ARCHITECTURAL angle has nice geometric shoulder for cap rail to register to with minimum inside fillet to deal with.
- saves oodles of time grinding and cutting down steel.
Con's
- assembled rail is still flexible in x and y direction like steel and requires you to mount it to the main C channel frame for rigidity.
Steel MM option:
Pro's
- steel angle iron easily and readily available
- fairly easy to cut down to required height, but takes time.
- fairly easy to grind profile, but takes time
- skate method is VERY EASY to use and is now included in the laser cut steel package. A luxury I didn't have, but love knowing it's available now. *thanks to JR, Greg, Gerald for helping me work out the kinks*
- many machines on this great planet use it and is a tried and proven method.
Con's
If you notice, both rail sections require the machine frame to dictate the rigidity of the rail profile....not it's metallurgy. Good design, many choices.
Good luck - choose wisely.
Old Tue 05 February 2008, 23:07
I copied the rail discussion to another place and replied there.
