Old Fri 22 June 2012, 07:55
Ground loop.
Old Fri 22 June 2012, 18:53
David Bryant
Just call me: David #99
Western Australia
In Australia we have a connection at the meter box that is the MEN. The Main Earth Neutral Link. This is the only place on a house that the Neutral is connected to the Earth.
If the (AC) neutral is connected to a DC ground, earth of a machine in Australia the Safety switch (Earth leakage breaker, Residual current detector are other names) would switch the power off.
This leads us to use dual pole switching often to isolate the AC line and Neutral. The Earth wire is used to ground the machine.
This has advantages in isolation and allows our machines to have a single earth point to as ken says eliminate earth, ground loops. These are currents that flow in the earth wires if they are joind in loops. (Like a single turn of wire added to the transformer above.)
This makes our eacth wires go out from a single point like a star.
Why not use an adjustable, regulated power supply? Bob Cole 702. Power Supplies 19 Thu 25 August 2011 09:33
Choosing my motors & power supply Rusty Nuts Motors & their mountings 2 Sun 31 July 2011 14:39
Strange movements - bad power supply to BOB tnarch Troubleshooting 26 Fri 25 March 2011 19:37
Need Help with Power Supply Selection F2DVasek 702. Power Supplies 2 Wed 19 May 2010 03:25
