Old Thu 25 August 2011, 11:53
Thank you for the explanation and that makes sense. So I think I will go back to the 40 and might raise it to 50 just to see what happens.
Sean, I have to look at what my setting is for the Kennel.
Old Sat 10 September 2011, 11:57
JamesJ
Kansas
Gerald:
After much tuning I had arrived at an accel setting of 12 which does not totally get rid of problem but nearly does. I was beginning to think my problem lay elsewhere as 12 seems to be very low compared to the values shared in this thread. I started looking at the table itself and I started to focus on things that involve rigidity in the Y axis.
I have incorporated a hybrid table approach in that it is partially welded and partly bolt together. I wanted to be able to break it down if I needed to move it. The I beams, legs and X-axis diagonal braces are all welded. This creates two "sides" which are held together with bolt on end assemblies. The cross bearers are bolted on also.
I did more searching and came across a thread that talked about the size of the cross bearers which helped me remember that I had not used c-channel for my cross bearers. I had used 1.5" x 2" x .125" rectangular tubing. The thread leads me to think that these cross bearers are not rigid enough.
My question to Gerald is, could this be the cause, or a contributing factor, to my problem?
Old Sat 10 September 2011, 13:13
I doubt it.
A point in the right direction shern_0711 Introduce yourself and start planning 14 Thu 30 June 2011 19:28
Question about stepper drives and motor direction DTGuitars 701. Motor Drives 13 Mon 18 October 2010 09:38
Shudder along X Axis - unresolved sailfl Troubleshooting 30 Sun 28 December 2008 14:32
One motor goes wrong way - How to reverse its direction grandpi Troubleshooting 2 Sun 17 February 2008 22:03
Changing Shopbot board to G -code TBrown 70. Control Systems 15 Sun 06 January 2008 19:18
