Old Thu 22 April 2010, 23:18
Originally Posted by fredkehler View Post
... the mechmate is turning out to be a workhorse... doing what we ask it without complaining...
Are you telling us that you are cutting with your MM already? Then it is time for us to move the thread and you to show some pics!
Old Fri 23 April 2010, 09:23
fredkehler
Just call me: fred
Abbotsfrod (BC)
cutting already..
Yes, we've been cutting since the end of february... lots of test cuts, as we discovered a problem with the Z axis losing steps ( always in the same direction), turned out my attempt to use a Gecko 210 ( new from a previous project) backfired as there apparently is a problem with the logic when they are used in the 10ustep mode... on very small direction changes (as in doing 3D carving) the driver can lose a few steps... problem solved by replacing it with a 203V ( which my other 3 drivers were already.... Gecko has offered to repair the problem, even though the drive was purchased several years ago... very impressed with their service....
Now that we finally have that resolved we are moving ahead with some 'real' work, a complex sign project out of UHD and surfacing some maple slabs...
will post some pix...
cheers
Old Fri 23 April 2010, 09:58
Travish
Just call me: Travis #75
Wa
Hi Fred, Glad to hear you guys are up and cutting for the most part. Yes, I have a build going here on the forum as well. http://www.mechmate.com/forums/showt...3899#post33899
Looking forward to seeing the upcoming pictures.
Cheers,
Travis
Laser Cut Parts from Ontario, Canada domino11 Profiled (laser cut) & bent steel plate 90 Sat 28 April 2012 21:26
Sealing cut edges of wood, MDF Alan_c General - MM Operating 4 Mon 31 August 2009 22:56
Happy Holidays sailfl Archives 18 Thu 25 December 2008 16:37
M110110M Angle iron rails for X and Y axes Gerald_D Rails & Rollers 69 Sat 15 September 2007 17:17
