Old Wed 23 December 2009, 00:01
Ries,
Thanks for looking over my shoulder.
Just rewired & tested the PSU.
Old Wed 23 December 2009, 09:11
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Ken, I have a PMDX-122, drivers like yours and EMC. It's a workable setup.
I can help with the basic kitchen table configuration.
http://www.mechmate.com/forums/showt...88&postcount=1
Old Thu 24 December 2009, 00:35
Thousand thanks Jeff!
Careless of me missing out your thread...
Would you care to share how you set your PMDX122 connection in EMC2?
Is my PUL/DIR interpretation correct? The non-manderin speaking world uses Step/Dir instead.
In EMC2 stepconf,
Step Time? is this the t2 in the driver manuals?
Step Space? the t3 in the driver manual?
Direction Hold? (Completely no idea)
Direction Setup? the default is 20,000ns, & now matter how much I change this. it will always go back to 20,000ns
I set the Leadscrew pitch to 9.422778, (1:1, 24teeth module 1 spur gear)
Thanks in advance
Merry X'mas
Old Thu 24 December 2009, 01:37
lumberjack_jeff
Montesano, WA
Hi Ken, and thanks for the Christmas wishes, I'll check my config tomorrow morning when I get out to the shop.
I will say that my initial "leadscrew pitch" setting came out way wrong. I eventually arrived at a setting by telling the machine to go to x=96 y=48 and measuring the actual travelled distance from x=0 y=0. I used the difference between 107.331 (the hypotenuse of a 48x96 triangle) and the actual measured result as a correction factor.
A couple of iterations of this will get you closer than any other method.
Old Thu 24 December 2009, 12:45
lumberjack_jeff
Montesano, WA
step time 2500
step space 2500
direction hold 20000
direction setup 20000
On the pmdx,
jp1 is set for +5v
jp2 is set for "always"
jp3 is set for "not estop/fault"
jp4 is set for "normal"
jp5 is set for "out"
jp6 is set for "normal"
BTW, my leadscrew pitch is .0321039 (7.5:1, 20 tooth pinion)
on the stepconfig wizard, I have the x steppers both configured as x with the checkbox marked "reverse" on one.
Old Thu 24 December 2009, 16:47
lumberjack_jeff
Montesano, WA
I've done some tweaking today trying to resolve some problems.
My step time is now 5000
step space is now 5000
dir hold is 1200
dir setup is 1200
Better, I think.
Running 5 drives off one PMDX-122 board J.R. Hatcher 70. Control Systems 40 Tue 19 December 2017 10:21
PMDX-122 vs PMDX-125? salewis 70. Control Systems 6 Fri 06 November 2009 05:16
PMDX-132 instead of the PMDX-122 SteveWellman999 70. Control Systems 23 Mon 02 November 2009 11:47
PMDX-122 power supply paul60 702. Power Supplies 1 Thu 10 September 2009 12:51
PMDX-122 relay output voltage? chopper 70. Control Systems 10 Thu 04 December 2008 07:00
