#31
Me and Vishnu both have the VFD022B21 A on our Mechmate's running single phase - no problems whatsoever! so go ahead with confidence
#32
Bart, if you live in Europe, your 3-phase is about 380 Volt if measured Live to Live (Δ) and 230 Volt if measured Live to Neutral (Y). The typical VFD is for Δ connection only and allows the connection of 3 Live wires (no Neutral).
Please check with the supplier, but I believe you will not be able to use that VFD for a standard 3-phase situation in Europe. |
#33
Thanks to everyone for the info on the connection of the frequency drive. Glad to hear that Irfan and Vishnu are using this setup without problems.
![]() Gerald, You are right about the supply net in Europe. In Belgium 1 fase 230 Volt is common for domestic use and 3 fase 400 Volt for industrial use. At home I have however an old net of 3 fase 127Volt/230Volt so I have 127 volt between neutral and fase and 230 Volt between the fases. This is not very common but it still exists in some areas. Last edited by BartDeckers; Sat 26 September 2009 at 04:50.. |
| Setting up a Huanyang HY02D223B VFD | Jayson | 701. Motor Drives | 20 | Fri 02 November 2018 07:25 |
| VFD wiring - right or wrong | javeria | 60. Wiring & Cable Management | 12 | Tue 27 July 2010 20:41 |
| Lurching at Reset - interference from spindle VFD | waynec | Troubleshooting | 12 | Thu 05 February 2009 17:00 |
| Wiring the VFD and Spindle | waynec | 50. Toolheads | 4 | Thu 18 September 2008 23:09 |
