Old Fri 19 December 2008, 09:20
Nils - that means post a pic! Now please
Old Fri 19 December 2008, 09:24
Gerald and Sean,
Check my thread.........
Old Fri 19 December 2008, 10:31
John,
My table size is 49" X 97" if you want to add that info to the spreadsheet. No special comments that I can think of.
Old Fri 19 December 2008, 11:00
John,
When you update the spreadsheet for my number #12...... Please add that I am one of the first to build with preground rails.
Thanks for maintaining the Serial Numbers.
Old Fri 19 December 2008, 12:01
John, thanks for keeping the record.
My table #11 size - 2750 x 1830mm
Old Fri 19 December 2008, 13:04
Gerald, Doug, Nils and Alan.
Thanks for the input. Doug, I switched the dimensions to X x Y like Gerald's and Alan's.
Nils, congratulations again on achieving Serial #12.
Updates are here.
Regards,
John
Old Fri 19 December 2008, 13:26
Table #10 is 100" x 50", and I use a gecko 540.
Old Fri 19 December 2008, 14:53
Thanks Brad,
Update is here
Regards,
John
Old Fri 19 December 2008, 19:56
Thanks for the list John:
Old Sat 20 December 2008, 09:06
Just for the record...my MM can cut a sheet 2.44 x 1.22 m. I think I am the first brave one to use Chinese steppers ( Motion King ) ungeared. Total cost +/- R 22 000.00 [US$ 2 200]. Using old 202 Gecko's and an old Makita router. Thanks
Old Sat 20 December 2008, 09:19
Kobus, I think yours can cut wider than 1.22m [48"]. With luck, (maybe accident, maybe design) you can probably cut 1.375 [54"] wide. That is a half sheet of MDF split lengthwise - a very desirable gantry length in SA.
Old Sat 20 December 2008, 19:44
For table size, each builder should state the final X and Y usable cutting capacity, since a builder might have rounded up, here and there, and thereby ended up with more X and Y cutting capacity. Does that seem reasonable? So, Kobus, do you want to revise your table size?
Also, Kobus' entry update raises an important question. Do we want to add a column indicating the "cost to build" each MechMate? I've noticed some builders stating their cost in response to a question. I'm sure some builders have not tracked their cost. Also, since most of these are a "labour of love," there is no quantified labour cost. What do you think?
As for the mechanics of adding additioinal columns, it is no problem in Google Docs. But as Gerald's reproduction of the Google Spreadsheet, above, illustrates, there could be truncation issues as the spreadsheet gets wider.
Regards,
John
Old Sat 20 December 2008, 22:17
When it comes to troubleshooting, the most useful data for me is:
Motor type number
Pinion size
Motor wiring
PS voltage
Motor tuning settings
Mach3 or something else
PMDX-122 or something else
DP20, module 1 rack, or something else
RAM in the PC and its speed
etc
etc
. . . . which becomes a monstrous database by itself! (could be added to a user's profile for the forum.....)
John, suggest you keep it simple before this thing escalates way off the screen.
Old Sun 21 December 2008, 00:59
Hi John, OK I measured it and my Y will cut up to 1560 mm. That is pushing the Y-Car right to the end on the gantry. My X stay the same 2440 mm max.
So change it on the spreadsheet please. Thank's Kobus
Old Sun 21 December 2008, 07:06
Okay, Gerald. I have made adjustments to the spreadsheet to reduce the width. We'll keep it simple.
Kobus, I have made the updates here.
Regards,
John
Old Sat 27 December 2008, 04:44
Please update page one.
Old Sat 27 December 2008, 04:46
Page 1 of what?
Old Sun 04 January 2009, 07:22
The spreadsheet has been updated with Serial #14 and is available here.
Regards,
John
Old Sun 04 January 2009, 07:33
Thanks John (Sweeden needs a spelling correction)
Also, we learnt that Chuck's 20' machine has been cutting for some months: http://www.mechmate.com/forums/showthread.php?t=752
Old Sun 04 January 2009, 19:25
Added Chuck's machine and corrected spelling error here.
Regards,
John
Old Mon 19 January 2009, 07:14
Our latest addition has been added. Mike's machine comes in at Serial #16 with a build time of 1.6 months. Updated Builder's Log is here.
Regards,
John
Old Sun 25 January 2009, 06:57
Yuri's machine, Serial #17 has been added to the MechMate Builder's Log, here.
That's the 4th Serial Number awarded so far THIS MONTH!
Regards,
John
Old Sat 31 January 2009, 07:39
Serial #18 has been AWARDED to Jayson, of Horsham, Australia. It was a VERY FAST BUILD, and the First Serial Numbered MechMate in Australia. The updated Builder's Log is here.
That makes 5 machines being awarded Serial Numbers in the month of January. WOW, can we keep up this pace?
Regards,
John
Old Sat 31 January 2009, 11:18
Thanks for all the secretarial work John. This machine also needs to be listed as cutting.
Old Sun 01 February 2009, 07:01
Happy to help...a little bit.
The updated Builder's Log is here with Jayson's and Vladimir's latest information.
Regards,
John
Old Fri 06 February 2009, 07:46
Serial # 19 has been awarded to Greg in Smiths Falls, Ontario, Canada. (This is not a mistake...Greg sent me an PM with details. Thanks Greg)
It's an impressive machine sporting 14" of Z Travel using a Linear Slide. The updated Builder's Log is here.
Regards,
John
Old Fri 06 February 2009, 14:39
I think you need to add another requirement to getting a serial number for the machine. Besides having it cut, painted Blue (in most cases) and the MechMate logo must be on the machine, I think you should require that a Mug shot must appear on the mug page.
Old Fri 06 February 2009, 14:46
Hey that sounds reasonable! Greg, need your mugshot!
Old Fri 06 February 2009, 15:22
bradyaero
Just call me: Greg #19
damn! but I'm ugly!
Old Fri 06 February 2009, 17:16
Greg B,
If you are uglier then the guy that had Blue MM paint all over his face then I will buy you a beer. I know cause that was me. I am handsome in my own way.
Post a picture....!!
