Old Thu 06 March 2014, 20:29
1planeguy
Just call me: 1planeguy
Smiths, Al.
That's awesome...My old machine was definitely not as rigid as a Mechmate (number 1 reason I'm building one :-) )
The setup you've cut should be pretty slick...the interchangeable bottom plates gives bunches of options
Old Fri 07 March 2014, 10:08
Guip
Just call me: Guillaume
Paris
France
I built a dust shoe for a 6040 chinese CNC router some years ago. I used the brushes of a 2$ broom. You can easily pull each brush apart and simply insert it on holes in the shoe with a tiny flat screw driver.
Very cheap and you can choose the stiffness of the brush, the length, "density"...etc to match you needs.
Have a look at that video. Exactly what I have done.
Old Fri 07 March 2014, 19:32
OK, Dust shoe: magnets and alignment pins all epoxied in, I'll paint them this weekend...
Strip brushes ordered and will be here Tuesday.
(FYI, 36" brushes fit the groove length with about 2" to spare.)
I'm thinking Safety Yellow on the parts, and I'll probably paint the dust pipe black while I'm at it....
Hope to work on the SuperPID too.
Of note, I eliminated the speed controller on the old Milwaukee 5625 router, as part of the prep for the SuperPID, and it was indeed the faulty part.
NOW, I just ordered a JoeWoodworker.com project EVS vacuum press kit.
I'll probably make some gasketed Corian pucks for vacuum holddown use on the MM, as well as some vacuum clamps for seaming Corian countertops for bars I do in basement finishes.
Old Sat 08 March 2014, 21:12
1planeguy
Smiths, Al.
Please put up some pictures of the vacuum setups here...that is some interesting stuff!
Old Sun 09 March 2014, 05:31
"Man you're always having fun". I've got a vacuum pump 17 years ago for a veneer bagging (back in the day) and it can be used for clamping as well I wonder if I could set up a puck clamp with it as well, hmm. The corian would be perfect, consistant thickness (well for the most part) solid and durable. I'm certain it will work, I'll have to try it a bit later on.
Old Sun 09 March 2014, 08:25
Well, Tom, lets say just the fun stuff makes it on here.
I was spray finishing a table top yesterday that has been the bane of my existence.
Done as a favor, I'm 10 hours deep into it and still not done, and of course the spray gun spit out something on the last pass.
Prior coat fish eyed, coat before that, I sanded through the stain... all as a freebie for a friend.
Also yesterday, when doing an inlay for text for a sign, there is a BIG difference between .011 pocket allowance for the letters and .11...Brain fade.
Happy note, new dust feet are complete waiting on strip brush.
Usually the materials are here waiting on me to find time to get to them.
There is some pretty good clamping info and puck machining info as close as a Google search, and if the Corian isn't perfect thickness.....you have a machine to make it so.
Now, for my Sunday enjoyment, time to go sand a table top, respray, and remake some pocketed letters.....instead of working on a SuperPID..
Old Sun 09 March 2014, 12:04
A good turn never goes unpunished.
Old Sun 09 March 2014, 13:51
1planeguy
Smiths, Al.
And the funny thing is "friends" will never understand how much trouble you actually went through.
Next time you need to move...or a ride to the airport...or heck, change a tire...you know the first "friend" to call ;-)
Old Mon 10 March 2014, 20:33
So the JoeWoodworker kit will be here Thursday, and I've been planning the build of the vacuum setup. Lo and behold, the disposable compressor I bought for 49 dollars a few Black Fridays ago gave up the ghost today and wont build over 15 lbs. Probably a broken reed valve, but not worth tearing into.
While browsing the JoeWW site, I see these have been used by others for vacuum storage in lieu of building the suggested PVC tanks.
By a stroke of luck, the compressor died BEFORE I started instead of the day after, so I now have a headstart on the project. Convenient.
Old Tue 11 March 2014, 20:37
Never thought of bad luck as convenient but I do see your point.
Old Thu 13 March 2014, 21:18
Spent the weekend and every night after work this week working on a big project with the MM.
Finished up this evening, but I have to wait a few days for the reveal.
First project 100% toolpathed in Aspire and cut out on the MM.
Whole shop full of tools sat unused while the MM quietly turned out parts that looked like a jigsaw puzzle, using 7 full 4x8 sheets of 1/2" AZEK.
Here is a teaser pic showing letter inlays...
I'll be able to post the rest after the grand opening...
Old Fri 14 March 2014, 03:13
It looks like T + Beer = No Hangover !
Then again what do I know
Old Fri 14 March 2014, 04:10
That's a PVC product, is it not? How does it machine?
Old Fri 14 March 2014, 04:51
1planeguy
Smiths, Al.
Originally Posted by darren salyer View Post
...While browsing the JoeWW site, I see these have been used by others for vacuum storage in lieu of building the suggested PVC tanks.
If you can find suction gauges to match the diameter of the old pressure gauges, you already have your "instrument panel":-)
Old Fri 14 March 2014, 14:20
Tom, it is indeed a PVC product.
I glue it with clear medium PVC cement. 3-4 minutes and you cant move it, much like gluing PVC pipe.
It machines very well using a faster feed rate and slower RPM than wood.
Depending on the bit, you have to try a few samples to make sure you are making chips and not melting the product back onto itself.
Old Fri 14 March 2014, 15:30
I'll have to try some out, is it expensive?
Old Fri 14 March 2014, 17:00
Around here, a 4x8x1/2" sheet is 100 bucks. You can buy dimensional lumber sizes cheaper, just to try a small project on.
Old Fri 14 March 2014, 17:16
They make it 1.25 in thick for milling, not sure of the cost
Old Fri 14 March 2014, 19:55
Interesting...
I'll call my lumberyard rep on Monday and get a price.
Old Fri 14 March 2014, 20:35
Yeah check out their website under trim, no it's called rtm-ready to mill
Old Fri 14 March 2014, 21:01
Already did before my last post. Have a project it would be good for.
Old Sat 15 March 2014, 06:32
Mojo
Just call me: SolarImages
Bisbee, AZ
Cool factor!
Thats what's its all about sometimes!
Old Sun 23 March 2014, 17:42
Well guys, sitting here on a quiet Sunday afternoon thinking about my basement and the bar I'd like to build for myself.....
I ran across this image online, and I'd like to do a ceiling similar to what is shown.
I'm thinking either MDF or EPS foam carved to look like an old stamped tin ceiling would be WAYYYYYYY cool.
The flat panels would be easy, I could even use some of Vectrics premade models.
My thoughts are coming up with a way to do the crown molding, especially the curved part is where I'll struggle.
This would be painted off white, so joints could be caulked/filled...
Before I jump in with both feet...
Anybody have any ideas or insight into something like this?
Oh yeah, since its my own project, expect a snail like pace.... I'm thinking I'll have all spring/summer/fall to get the panels and trims carved, for next winters project.
Old Sun 23 March 2014, 18:03
I wish I could offer something more. MDF is heavy and in a basement setting. Even with a control humidity level, it will want to draw moisture unless you take extreme care to make sure it is sealed. I think the EPS would be the better option in that environment.
Old Sun 23 March 2014, 18:13
If you are using aspire you should be able to do the curved crown molding with little problem. Use the two rail sweep feature. Of course you are limited to your table size and how you can lay it out best. You most likely will have to do in several sections. If your panels are flat with no profiles then best to use bendy board and veneer much quicker and adjustable. Otherwise, if raised panels, you are limited to the shaper head (or router) profile limitations, jig set up, etc, if the depth of the panel is not too great than you may be able to do them on the MM. Unless you want to do it old school by hand. If applied moldings around the panels, then sometimes you must employ steam bending methods.
Old Sun 23 March 2014, 18:14
I've done several panel/beam type ceilings in basements with MDF without problems, and almost all the paint grade door and trim packages have been MDF... some going on 10 years.
I think if there is enough humidity to cause problems, something is wrong..
It was brought to my attention that that mush EPS in a fire situation would be more hazardous with regards to fumes than the MDF, which I hadn't considered.
Old Sun 23 March 2014, 18:17
Tom, how would one do the curved crown profile with all the carved elements using a two rail sweep?
I've not done a lot of complex 3D work with Aspire (yet)..
Old Sun 23 March 2014, 18:19
What is the ceiling made of that you are attaching this to? Is it paneled or just open joists? Will this be fastened or glued? Steam bending is the only way I know to get true bends however you could draw the entire ceiling area in a program like Solidworks if you have it and separate it into the size of your table with each sheet interlocking into the next.
Old Sun 23 March 2014, 18:20
Which version of Aspire to you have. With 4 the extrude and weave is an awesome feature.
Old Sun 23 March 2014, 18:22
Check out the file here http://forum.vectric.com/viewtopic.php?f=27&t=12375
University Of Missouri Saint Louis Theater ganderson Introduce yourself and start planning 8 Fri 31 October 2014 17:53
Starting my MM Build - St Louis MO USA inventek2000 Construction started, but not cutting yet 38 Sun 25 September 2011 17:51
my machine cnc marcoscnc29 Archives 1 Sat 24 April 2010 17:58
