Old Sat 05 February 2011, 00:44
AuS MaDDoG
Just call me: Tony #71
Brisbane
Mechmate on the Move
Hi All !!
The day has come for MM's to depart
so here we go!!
Mechmate Departing !!
You have heard of the fastest Indian well now we have the Fastest MechMate !! @ 100Klm /Hour
MM arrives to its new home for the first time !!
MM being positioned and leveled on its feet in it's new home and a big thanks to tangocharlie for some help with the move !!
MM cutting !! and boy did Pauls daughter like seeing her name cut into some offcut acrylic. I think she already has lots of ideas for Paul and his new toy
Cheers & good luck with the cutting skippy !!
Tony
Old Sat 05 February 2011, 05:32
Well done.. Is that a Kangaroo Catcher on the front of the truck ?
Old Sat 05 February 2011, 10:57
zumergido
Just call me: Fernando
BS AS
aussies and their shorts... they can weld, built houses, everything with shorts and brown boots.
i lived in aussiland for 3 years. nice very nice.
Old Sat 05 February 2011, 20:14
AuS MaDDoG
Brisbane
Yep you got it Kobus !! they call them Bullbars even although they are to protect your vehicle from the Roo's
Tony.
Old Sat 05 February 2011, 22:03
And that screen on the window...is that a sieve to strain the blood and guts once the Bullbar make mince meat from one
Old Sat 05 February 2011, 22:16
Moo
Old Sat 05 February 2011, 23:39
Wow, never thought of kangaroos being a problem to vehicles. Around here we have to watch out for deer. I got one myself last fall (October) with my truck. Different ends of the world, different animals, same problems.
Old Mon 07 February 2011, 19:25
skippy
Just call me: Paul #72
Kangaroos can writeoff a car and still hop off into the bushes.
Old Mon 07 February 2011, 19:35
tangocharlie123
Just call me: Pete
Gatton Brisbane
Paul are you referring to any Aussie Rules football team or just singling out the Roos they all destroy cars, hotel rooms and pubs.
Pete
Old Mon 07 February 2011, 20:22
Paul
I didn't even know they could drive !!
Old Tue 08 February 2011, 02:55
AuS MaDDoG
Brisbane
Hi All,
Some more goodies arrived today
Tony.
Old Tue 08 February 2011, 03:11
DB9 two wire cable ??
Can you remind me where that goes in your system Tony.
Also checked my stuff and it is still there so that must be your adapter and 50mm bit. Good luck with them both.
Finally I'm still laughing at my own kangaroo joke, sad but true.
Old Wed 09 February 2011, 14:13
AuS MaDDoG
Brisbane
Hi All,
The industrial grade RS485 to USB that Ross suggested and trialled is now installed and working and appears to be totally bullet proof.
http://www.youtube.com/watch?v=PfMdLPgGKf0
Spindle control is all working under Mach3 when running some GCode few other little settings to sort out like RPM etc, but other that that we are now all good !!
http://www.youtube.com/watch?v=LtCUoT3yKFA
Tony.
Old Wed 09 February 2011, 16:52
melissa
Just call me: Melissa #83
Brighton (Ontario)
Great photos of the move!
A flatbed tow truck is exactly what I had in mind, should I ever need to relocate my MechMate . Sure beats trying to lift and carry all the parts....
Old Sat 12 February 2011, 02:23
gmcclure
Just call me: Graeme
Geelong
Great Build Guys.
Paul RE: XBOX360 Mach 3 control. Have you used this yet? Are you using wireless or Wired? If Wired, how long is the cable?
I am spending today configuring a Mach3 dedicated computer in a server case, could a long play day.
Graeme
Old Sat 12 February 2011, 03:52
AuS MaDDoG
Brisbane
Graeme,
The XBox 360 Control works just great !! we are both running wireless with no probs. Very configurable too!! we also use a docking station with re-chargeable's and is permanently connected, just pick it up and away we go
Tony.
Old Sat 12 February 2011, 13:48
decibel
Just call me: Doug
Auckland
New Zealand
Smile
Mental as Anything!
Old Fri 25 February 2011, 08:27
AuS MaDDoG
Brisbane
Hi all,
Nothing much to report, other than i am currently having a ball on holiday in Vietnam. Currently in Nah trang, what a beaut part of of the world.
Old Tue 26 April 2011, 00:41
Red_boards
Just call me: Red #91
Melbourne
I see in post #266 that you have a hole in the y-car to accomodate the proxy sensor. I assume you drilled this because my sensors are too tall to fit without a hole drilled?
Old Tue 26 April 2011, 06:41
If memory serves me right, the hole is on the laser cut drawing?
Old Tue 26 April 2011, 06:49
Check 10 30 422 P
Old Wed 27 April 2011, 05:18
Red_boards
Melbourne
Ahem
Long embarrassed pause
Moved part to other side of y-car where there is indeed a hole to accomodate the proxy sensor.
Old Wed 27 April 2011, 07:29
Note:
If your using standard 4 pin connectors m4/m12 on a 45mm body sensor or longer, you will need to enlarge that hole to about 19mm so the bonnet on the shell will screw on the proximity body. Depends on your supplier, but all 3 of my machines required a little adjustment to the hole.
Good luck!
Old Thu 05 May 2011, 03:41
AuS MaDDoG
Brisbane
Hi Guys,
Sorry for the late reply is I have been overseas a lot of late and also just had a stint in hospital.
Gerald is correct the hole is in the laser cut parts.
Sean is also correct, the hole in the Y car did not appear to be in alignment with the Y car stop so if the sensor we used was any larger in diameter or length a small adjustment to the hole would have been required in the Y car.
Tony.
Old Mon 09 May 2011, 03:49
Tony - hope you patch up quickly.
Old Wed 01 June 2011, 05:17
AuS MaDDoG
Brisbane
Hi All,
Starting to feel a bit better after a stint in hospital and a few weeks off work recovering and taking things easy from my recent diagnosis of Myopericarditis.
I felt like trying to do something today so made my first few pens using the new wood lathe that I recently purchased. Took me a few goes to get them right but got there in the end.
Hope to get onto a few MM projects soon too.
Tony.
Old Mon 06 June 2011, 06:58
Jason Marsha
Just call me: Jason
B'Town
Barbados
Tony,
I hope everything work out allright. It good to take on projects to take your mind off the other stuff.
The pens look great, what type of woods did you use? The two outer pens look similar.
Jason
Old Mon 06 June 2011, 17:46
AuS MaDDoG
Brisbane
Hi Jason,
Sure is Jason certainly helps keeping the brain occupied!!. The timber used starting with the pen at the top was Ringed Blackwood, Black Palm, and an Australian Hardwood donated by Ross (Surfcnc) I have also just finished turning my first acrylic pen I am pleased with how it turned out also.
Tony.
Old Mon 06 June 2011, 22:00
Another skill mastered there Tony.
They look great.
Old Mon 06 June 2011, 23:18
Looking nice there.. Where do you buy the pen kits (working parts) from ?
