Old Tue 18 November 2014, 06:34
Tokamak
Just call me: John #121
Monrovia (ca)
This is a good read. This is the thread where I got most of my info.
http://www.machsupport.com/forum/ind...c,12444.0.html
Old Tue 18 November 2014, 08:49
hevertg
Just call me: Hevert
maracaibo
Venezuela
congratulations friend
Old Tue 18 November 2014, 09:48
Fox
Just call me: Fox
Amsterdam
A lasersauer is on my to do list for more than a year, but first I need the mm to earn it's keep.
Old Tue 18 November 2014, 10:08
Tokamak
Monrovia (ca)
Fox,
Have you seen this one?
http://www.openbuilds.com/
Old Tue 18 November 2014, 11:04
Impressive.....Congrats
Old Tue 18 November 2014, 12:37
Fox
Just call me: Fox
Amsterdam
You mean the one based on the lasersauer? I must admit I have not dived into all the details, but on first glance the lasersauer looked like a well made open source plan and machine. But I might just buy a Chinese one http://www.wklaser.com/pro_195.aspx they are not bad and compared to a diy they don't cost much more. But like said, first things first. Make money with the mm, to regain costs and pay for a laser.
Old Tue 18 November 2014, 15:29
The folks at 'buildyourcnc.com' sells a 'black tooth' laser cutter -- looks a lot like the lasersaur project to me -- but one thing they do is to mount the laser on the CNC Y-axis carrier. Supposedly it manks keeps the alignment better and easier. ... Not sure if it does, but it is another method!
buildlog.net is another DIY CO2 Laser build. One thing they suggest is to NOT order the laser tube itself until right before you are ready to use it. Evidently they have a shelf life of 2 to 3 years whether in use or not. -- that may not be true, but it is my current belief from what I have seen posted.
Old Tue 18 November 2014, 16:23
The tube is charged with Co2, like all pressurized vessels, it will leak over time... for what ever reasons...
Old Mon 24 November 2014, 06:45
Tokamak
Monrovia (ca)
Cutting with a laser is sweet. Had to try the butterfly file. Reduced the size until the slots in the parts matched .015" (.38mm) card stock paper.
It was easier to cut than to assemble.
Old Mon 24 November 2014, 06:49
Tokamak
Monrovia (ca)
Then a seasonal theme.
Card stock
Free wood floor samples from HD
Glass tile, bright sunlight shows shadow
Old Mon 24 November 2014, 07:00
Tokamak
Monrovia (ca)
Chatter on edges is probably stepper motor related. . .
Old Mon 24 November 2014, 13:07
racedirector
Just call me: Bruce #122
New South Wales
That is just too cool, well done!
Old Tue 25 November 2014, 07:19
...with a part that small, I would venture to guess the part moved and the stepper did it's job. How did you hold it?
On stuff that small I would "sandwich" what I was cutting or glue it to a sacrificial part and release it after cutting.
Old Tue 25 November 2014, 10:13
Note Sean this was cut with a laser so no physical contact to cause movement?
Old Tue 25 November 2014, 10:50
laser! Didn't catch that part...okay - stepper / microstep driver issue.
Old Tue 25 November 2014, 11:11
Unless he does not have gear reduction or a low steps per revolution, those marks appear to be 0.030" apart. I do photocarve and plastic plates with a 0.005" bit and have not seen a deviation like that. That would be worth solving. Even though it is laser cut I don't see how the steps would produce the sawtooth pattern. Unless it is transmitted vibration.
Old Tue 25 November 2014, 11:31
Laser tube overhang is very severe. IMHO, the laser tube mount isn't rigid enuf.
Old Tue 25 November 2014, 12:33
Fox
Just call me: Fox
Amsterdam
That could easily be checked, run the same file ultra slow. If the marks dissapear ken's correct. I would guess it's a combination of factors ( beam focus / material flatness / mechanical backclash / huge Z is swaying ever so little etc. )
Old Tue 25 November 2014, 13:15
I don't belief a slender 4' long tube mounted on one end with 4~8" spaced mounting would stay plumb over the course of traveling. It gravity defying... don't need Sir Isaac Newton to tell me that.
BUT then again, nobody said you can't do it, just not the best possible configuration. This patch job did works to a degree of satisfaction is a winner. It cuts after all.
This sure is a very heroic thing to do... I don't have the guts to run any laser tube this way without properly covering any possible/accidental/stray rays zapping around. I still want to be around for the next 40 or so years with all limps & any bodily organs still intact.
Old Tue 25 November 2014, 19:49
Tokamak
Monrovia (ca)
I have a 3:1 belt drive but this is very small steps. What I'll do is run some diamond shapes to see how the diagonals look up close. Also try it at different speeds to see if it changes.
Ken, the beam coming out of the laser is 6mm diameter. It is then run thru a focus lens the takes it to a spot .006" in diameter 2" away. The beam converges then expands. At 4 inches from the lens has expanded back to 6mm, another 2 inches away it is 12 mm. I think that the power density is decreasing by the square of the distance. By the time the beam hits the spoil board it makes a 3/8" smoldering dot that is not cutting at all.
Old Wed 26 November 2014, 02:49
John, i'm not sure how you were scaling but I notice a change in smoothness anytime I use the '[I]scale'[I] feature in Mach, not much but some.
Old Wed 26 November 2014, 07:08
John,
I'm aware of the power density & the science of LASER utility, but it is laser after all, one flash at the eye & anything can happen... Maybe its my excuse to stay lazy
Anyway, I do enjoy your work very much.
One the cut quality, we need max acceleration but with higher acceleration come greater force tilting the tube. slowing down isn't the solution. maybe just for testing, reduce the acceleration & see if the zig-zag get better. if it does, you need to improve the mounting rigidity.
Old Wed 26 November 2014, 21:50
Tokamak
Monrovia (ca)
I'll try the different speed thing to see what I get. I run it pretty slow to keep the stress on the tube low.
I have been scaling in Aspire and recalculating the tool path. I need to check to see if that area is a sieries of short lines or a smooth curve. May make a difference.
Gotta do the holiday stuff before I can get back to the dog house.
Old Tue 09 December 2014, 12:59
Tokamak
Monrovia (ca)
A friend ask me to cut some Angels for Christmas. I could cut 10 at a time with 20 Watts.
I picked up longer high voltage cable so I can install everything thru the wraps.
The Laser is okay but I want to get back to the spindle carving.
Old Sat 13 December 2014, 08:26
Cool Stuff!!
Old Wed 23 September 2015, 07:27
Tokamak
Monrovia (ca)
I've been busy doing a bunch of other stuff but here are some of my experiments.
Old Sun 27 September 2015, 04:35
Jason Marsha
Just call me: Jason
B'Town
Barbados
Great work John.
What is the material of the plaques above?
What speed do you cut the lettering of plaques at?
Old Sun 27 September 2015, 05:07
Tokamak
Monrovia (ca)
Thanks Jason,
The plaques are marble, and I cut them at 40 in/min.
Old Sun 27 September 2015, 05:28
Love the snowflakes.
Very intricate and precise.
Mister Asshole as well. I would use a slightly different spelling, but I am from England.
Old Thu 21 April 2016, 13:21
Hi John.....
Well, since your posts on your laser.....it's been...twitching me pretty much to see how I may install one too, although not as intricate as yours, but say a more, modest low cost & lower install implication model !
Finally found one and committed to buy, it's now on "production" and should be ship to me any day soon !!
I come to you in hope you may share this "found out how to interface with Mach3 and Aspire's post processor" you've posted some time ago ( post 313, Nov.14) !
Thks
