#331
Update on the door panels commissioning !!
The old say still rules.....never push further than....what can be done....it will inevitably....bite ya !! Her's some for those bites happened while burning some "midnight oil" trying to achieve a promise to deliver this morning !! ![]() Touch probe "glitch" !?! Gauging-todeep_2_resize_resize.jpg , Gauging-todeep_5_resize_resize.jpg Loosing a bit.....to loos Loosing-bit_resize_resize.jpg Loosing....my concentation.....colling wrong steps ( look at the 2 right gouges) 20150831_010057_resize_resize.jpg Enjoy your day... Cheers ![]() |
#332
That's the machine's way of saying, " I am clocking out for the day"
#333
#334
Thank you Robert, appreciate it!
#335
#336
How long have you been running those?
#337
Overdue for some logos and a number as well.
#338
Tom.... It's my 2nd change in 7yrs !
But yrs don't mean nothing, hrs of usage or better, length would be the way to say ![]() And that is something I have not accounted ![]() Al... I've gave up serial when many yrs ago, way back when I lost the race for #21 or 27 for not being ready in time ![]() I could of requested #100 when it came....but, since (#27 out)....I've gone with the though...why and what's the diff ??!... I'm still around, faithful and honored Gerald ( and all of those who came to help back then.....which, irony, many had / have serial, but are no longer active here) .... ( and I'll stay around till my beast...or this group.....dies !)....hopefully, not any soon ![]() Later ![]() |
#339
Robert if you have one of those chinese spindles you can get the number of hours off the VFD. That's about as close as I could get to figuring out the hours.
#340
Sorry...been using a porter 7518 since day one
....rebuilted a few times ![]() Last edited by Robert M; Sun 28 February 2016 at 07:12.. |
#341
Oh well, it was worth a shot
#342
Long time no see, if you are using Mach3, in the operator menu you can take a look maintanance hours. Bonne journée |
#343
Although, I can assure you guys this is no reflection since my last rack change, here's some "fun" numbers....
Maintenance-stats_20160307rs.jpg ![]() |
#344
Laser attachement ?!
Lurking with the thought of adding / buying a laser attachment to add this capability to my great blue beast !
Anyone has some though or better, some experience with this ? So fare, I've only found this.... (http://www.ebay.com/itm/Focusable-8W...-/231769470441 ) but, I have to say, I have not spend much time researching on the subject nor searching for various type available !! Tks ![]() |
#345
This will be interesting to watch. I just got a lazer from Darkly Labs. Works good, just a little low power. Only 4 watt.
Darren Salyer built one as well. |
#346
There is some laser discussion with links towards the end of my build thread.
#347
Where have I been? I'm missing out on all this good stuff. Where's my laser?
#348
Darren....did you ever moved forward with the laser on your machine ??
#349
No, I actually got a blacktooth laser. A standalone unit.
#350
#351
We just received out Blacktooth kit from buildyourcnc.com. We won't start building it until April but I've unpacked all the bits and was pleased at how organized things were. Would love to hear any wisdom learned from the build or since you have had it running.
#352
Darren, 40W laser !!...nice output,
![]() Out of curiosity, have you test it's maxed out wood thickness it may cut, say with some ply ?? |
#353
I've not done much, other than some test fires.
Its on my To-Do list. |
#354
Dust shoe bristle survey
Hi guys !!
Working on a design to update my dust shoe !! Wondering what you guys are using as for a "soft" bristle dust shoe "skirt" ?? These past yrs I've been using a bristle a little to hard or should say "not flexible " enough and wishing to find another alternative. I've been using this McMater Carr model #7372T12 ( cut down to +/- 1½ of bristles )and this one, occasionaly make my Z skip a few steps if it goes down on it !! In other word, it's just not soft nor flexible friendly enough for my Z ![]() Thanks for your suggestions !! |
#355
I used the full 3" brush height and it is fine.
#356
Personally I don't use brushes because I want to see what's going on. That's also why I made my shoe out of acrylic that rides at a fixed height about 1/4" above the materials, it has its +'s and -'s.
#357
It's a known factor....having shorter bristle makes them a little more stiffer !!
Since I need ( should say I want @_# ) a new one, I'm seeking / hoping to "test" ( or like !!) some of this softer bristle as some other we can see on the web ...but not divulging suppliers sources ;0( !!? |
#358
My first attempt at a shoe used bristles from a cheap broom hot glued into pockets around the perimeter of the shoe. Worked and gave me the ability to change to firmer or softer bristles. (The brooms ended up being a bit shorter
#359
I ended up using Ez-Flex flexible strip brush. Was spendy but went in without any problems. I cut grooves in my dust foot. Made the groove somewhat narrower that the brush, pressed it into the groove and finished by adding a little super glue.
http://sealeze.com/ind/ezflex2.html |
#360
Robert,
Reading the first few pages of your thread, really got me jealous of your workshop. So many machines/tools yet tidy. |
| How Much Horse Power is needed ?? | chopper | 50. Toolheads | 36 | Fri 25 February 2011 05:38 |
| New MM builder in Trois Rivières, Québec, Canada | Stepinwolf | Introduce yourself and start planning | 17 | Tue 22 December 2009 08:39 |
| hi!! from shawinigan,Québec,Canada | zenair10 | Introduce yourself and start planning | 6 | Sun 20 December 2009 05:50 |
| Bonjour de Ste-Adèle (Québec, Canada) | felix | Introduce yourself and start planning | 25 | Fri 24 July 2009 12:47 |
| Horse jump with pink butterflies | mikefoged | The Show Room | 4 | Tue 14 July 2009 05:39 |
