Old Sun 05 April 2009, 13:07
Hennie, nice doors.
To echo Heath's request - yes please on the door and draw info - I need to steal with my eyes...
When you said above that you would still use the spindle method, would that be making them as traditional doors with rails stiles and loose panel and then have them wrapped?
Old Sun 05 April 2009, 13:42
If I do a five piece door I won`t wrap them.We only wrap 16-18 mm doors where If I made traditional doors the rails and stiles are 21-22 mm thick.
Sometimes with the wrap doors the foil doesn`t go into all the patterns.( a drawback and some rejects )will make some samples and cut up to show what it looks like once it has been foiled.
Old Sun 05 April 2009, 23:44
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Hennie,
Did jou use only one v-shape bit on dot the door or other shapes as well?
Eish, lyk mooi!
My wife really likes your doors and kitchen designs. She is getting more and more exited by the day. There was a time..looong again when she felt like that about me!
Old Mon 06 April 2009, 02:28
I take it then that these are solid wooden doors ? I want to achieve the "square" inside corner on one piece MDF on the MM (remember it will be a painted finish - I don't have the luxury of a foiling machine )
Old Mon 06 April 2009, 02:56
Alan, you must learn to turn "failures" into "features"
failure: square corners impossible with rotating bit, but . . .
feature: slightly rounded corners do not give germs places to hide in your kitchen!
Old Mon 06 April 2009, 06:09
And to clean why do you think we paint the doors?
I might be wrong but Thermwood have a thing called e-cabinet systems with cutting files to do that type of door.
Old Mon 06 April 2009, 06:15
"Sharp" corners are fairly easy to do with a V-cutter, especially when the raised panel has 90-degree corners. Just insert a command that lifts the Z-axis as the cutter moves at a 45-degree angle to the cut. (Arched top doors require a little math to get the angles right.) In the doors program that I wrote for the Shopbot community, I changed from absolute mode to relative mode while I made those corner cuts. The actual "sharpness" depends on how "pointed" the cutter really is.
Old Mon 06 April 2009, 07:35
IN-WondeR
Just call me: Kim
Randers
Denmark
What kind of foil press are you using... I mean brand name, or perhaps a link.
Old Mon 06 April 2009, 08:07
I didn't have time earlier to give a G-code example of making a sharp corner. Right now I'm at a computer site, so I can't test the code, but if I remember correctly, this is basically how it works (assuming inch mode, 90-degree V-cutter)
% sharp_corners.tap
% set absolute mode
G90
G00 Z1.00
G00 X1.00 Y1.00
% start the cut
G01 Z-0.25 F30
G01 X10.0 F240
% select incremental or relative mode
G91
% sharpen a corner
G01 X0.25 Y-0.25 Z0.25 F30
G01 X-0.25 Y0.25 Y-0.25
% select absolute mode
G90
% make next cut
G01 Y10.0 F240
G00 Z1.00
% end of example
M30
Old Mon 06 April 2009, 09:07
Neat Stuff. Typo:
% sharpen a corner
% sharpen a corner
G01 X-0.25 Y0.25 Z-0.25
Old Mon 06 April 2009, 09:26
This method of sharpening a corner only works if two conditions are met:
- the cutter must have a sharp tip
- the cutter must have flat (straight) flanks.
Does not work for ogee bits
Old Mon 06 April 2009, 12:10
Johan I use the v groove cutter only to do v cuts.I will take pics tomorrow of my cutters.
On the side of having sharp corners I still prefer the five piece door there is no substitute.It gives more depth and it has a more solid feel to it.It does take longer to make but that is my way of doing it.
I will put pic`s up when we make those doors step by step.
We are making std doors tomorrow with the spindle will start my door thread with them
Old Mon 06 April 2009, 12:26
Hennie,
Will look forward to it!
Old Mon 06 April 2009, 12:28
Kim I did put picks of the machine and the process somewhere so if someone knows where it is help.
Alan the luxury is about the same value of a house,to think you pay your house of in twenty years and that luxury in four years I wish I bought another house.
How many doors would you make to pay for a house?
Old Mon 06 April 2009, 21:09
Brad,
Thanks for catching that error. I could have used you today. For more than eight hours I searched the Internet for a reason that my PHP scripts were showing plain text instead of running PHP scripts. It turned out to be a typo in the httpd.conf file, a typo that I must have looked at more than one hundred times - without seeing it.
I think that most of us would agree that MDF doors will never match the beauty and durability of solid doors, but, with the right painter who knows how to glaze, the MDF doors "appear" to have more value than traditional doors.
Old Tue 07 April 2009, 07:12
Louvre For Kobus
Kobus her are pic`s of the louvres before installed and what it looks like installed
Old Tue 07 April 2009, 09:10
Hennie,
Very nice looking . Are they used for privacy or for wind / shade protection?
Old Tue 07 April 2009, 10:22
Heath I think it is for privacy
Old Tue 07 April 2009, 11:50
Nothing beats REAL wood...nice stuff Hennie
Old Thu 09 April 2009, 12:27
Had to make these this morning
Old Thu 09 April 2009, 12:50
That's a nice simplified version of broekie lace!
Now you need to do lengths of those PVC fascia boards . I was thinking of a MM built like a thicknesser (ala carvewright) for these long narrow boards.
Old Thu 09 April 2009, 13:07
The only big problem is to get pvc in town,remember I stay in a holiday village.The 2750 length MM should do fascia boards as that might be the std length supplied ( 1220X2800 )I would like to work with some plastics as there is a lot of pro`s down at the coast for it.
Old Thu 09 April 2009, 13:17
Hennie, these are the suppliers with good service:
http://www.ppplastics.co.za/contact.asp
Old Thu 09 April 2009, 13:24
Here is the other company that I know of:
http://www.southernprofiles.co.za/
Old Thu 16 April 2009, 15:16
Barman
Just call me: Bart #36
antwerpen
Belgium
Hennie , nice work.
I look forward to create my own cabinet doors.
Old Tue 16 June 2009, 03:26
Some things that I was doing recently for the kids school and a project that I am busy with.First letters that I cut on my MM
Old Tue 16 June 2009, 11:39
Hennie - looks neat and great!
I am new to all this - still trying to learn to get that finish
Old Tue 16 June 2009, 14:06
BEAUTIFUL work!!!
Old Sat 08 August 2009, 00:18
I was switching my MM on yesterday morning and when I set the z-axis hight there was nothing ,no movement.The x and y axis worked no problem when I joged.On the computer screen it shows that there is movement up and down but there was no movement on the machine.I checked the wires from the motors to the control box all fine gecko`s looked like they were fine lights burning,bob looked fine.
Something tells me that there is no signal going to the bob from the computer?I switched everything off, fiddiled with the wires going to the computer swithced it on and it worked all fine for the whole day.I had to do a delivery at 2 o`clock so I swithced the machine off as I came back the same thing happened no movement on the z-axis. I need some advice please?
Old Sat 08 August 2009, 06:24
Roes my maat Roes...gooi bietjie brandewyn op die drade... Double check all the screws that connect wires....maybe one is not making contact as it should.
