Old Thu 02 June 2011, 23:42
melissa
Just call me: Melissa #83
Brighton (Ontario)
Next up was the logos, finally! I didn't break a bottle of champagne on the spoilboard, but the temptation was great .
Two photos of the control box:
The port on the left side is a Neutrik USB panel connector, used for plugging in a thumb drive for loading files. There's no network enabled on this computer, and never will be. I don't check my email from the workshop, and have NO desire to do so .
Old Thu 02 June 2011, 23:48
melissa
Brighton (Ontario)
And... sawdust!
It took me a while to figure out that the roadrunner file is programmed in inches, while my machine runs in mm. There is a G code to specify inches, which resulted in motion I could see, not just hear .
The first try was with a 1/4" spiral upcut bit, which was totally the wrong bit to use . I tried again with a V-bit, and that turned out much better.
So, I think I've got the bases covered... blue paint, stickers, sawdust.
Old Thu 02 June 2011, 23:51
Good job!
You just reminded me of my long overdue button name plate for my control box...
Old Fri 03 June 2011, 01:08
Good job!
Old Fri 03 June 2011, 04:59
Great work. Nice to see another machine come online.
Happy cutting!
Old Fri 03 June 2011, 07:41
AuS MaDDoG
Just call me: Tony #71
Brisbane
Very Nice !!!
and well done on a very nice looking machine.
Tony.
Old Fri 03 June 2011, 08:01
Nicely Done!!
Old Fri 03 June 2011, 10:04
camilleg
Just call me: Camille
Urbana, Illinois
We hardly recognize you in a t-shirt after all these photos of boots and mittens. BTW, nice warning tape on the edges of the lcd monitor!
Old Fri 03 June 2011, 10:07
camilleg
Urbana, Illinois
...and you got to bed before 2 AM. Triple word score with a side of poutine. Bravo, Melissa.
Old Fri 03 June 2011, 11:25
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
One Fine looking system!
Cheers Tim
Old Fri 03 June 2011, 15:22
normand blais
Just call me: Normand
montreal
Félicitation Melissa! I think I can see your landing strip from here ...did I heard poutine?
yumyum
Old Fri 03 June 2011, 18:16
Great thread !! Congrats on number 83 !!! Who's next
Old Fri 03 June 2011, 19:28
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Great Job. Completing and getting your serial number is a wonderful feeling of success.
Old Fri 03 June 2011, 23:16
Congratulations on #83 and completing your machine.
Old Sat 04 June 2011, 14:08
camilleg
Urbana, Illinois
Cool, you got a prime number. (Wasn't your undergrad student ID number also prime?)
Old Sat 04 June 2011, 17:31
melissa
Brighton (Ontario)
Thanks for all the congratulations! I'm happy to have a working machine, although it is a large conceptual leap from "normal" machines to CNC. It's a completely different workflow, and sometimes a bit alarming, like when the gantry is doing a rapid towards x=0 and stops just shy of the hard stops. Whew.
I've already derailed the gantry once... configured X to run in reverse (so the numbers ran the correct way), forgot to do the same to the slaved A axis, slow jog with the ShuttlePro, and 30mm later, the diagonally opposite wheels were off the rails with a loud THUNK. Oops .
A quick dimension test confirmed my motor setup: I cut a 100x200mm rectangle and a 100mm diameter circle, both measured correctly.
On to dust collection, before I completely cover the workshop in sawdust!
Old Sat 04 June 2011, 21:17
Updated Builder's Log
Melissa,
May I add my congratulations on completing your MechMate and earning Serial #83.
Please review your entry and let me know any changes you want to make.
Great job!
Old Mon 06 June 2011, 03:28
234ahmed
Just call me: Ahmed #81
Damietta
Egypt
Congratulations miechle. Nice looking machine
It really feels nice with a number beside your name. I'm still trying to get used to it
Melissa with the size you have i suggest you try with a wireless keyboard. I had one and it's really making a huge different to gain fine control when locating your work piece 0,0,0. It works for a 10m range or more.
Old Mon 01 August 2011, 16:54
melissa
Brighton (Ontario)
Machine upgrades
Having built my MechMate, I was much less intimidated than otherwise, to rewire parts of the gantry.
I ordered a larger junction box for the gantry, which made the wiring much simpler. Having a pushbutton box and a junction box made for a very full junction box, and many more wires.
I also wired in the proxies at the same time. No photos of that part yet.
Old Mon 01 August 2011, 17:02
melissa
Brighton (Ontario)
Dust Shoe
Next up was making a dust shoe. I purchased some "8020" aluminum profile to bolt the assembly to the y-car. My dust shoe is manually positioned, so it doesn't lift with the router. I may revise that later, but this works fine for now.
The brush is taken from a shop-vac nozzle from the hardware store. Bending it into the new shape was not pretty, but it works .
The piping is standard 4" PVC pipe. I found a "sewer adapter" which happens to fit dust-collection hose perfectly . I still need to take some photos of the hose support on the ceiling -- which uses a slide to accommodate the length of the table .
With the dust collection now functional, I could set about surfacing the table. I was astounded at the amount of dust collected. 1.5mm from the table filled the dust collector bag more than halfway .
Old Mon 01 August 2011, 18:05
melissa
Brighton (Ontario)
MDF clamps
There have been some DXF's of MDF clamps posted on the site -- this is one of them. I manually nested the parts (fairly easy when they're the same shape).
The middle section is pocketed, to allow for a bolt to pass through, with a knob above the table. My plan is to drill 1/4" holes through the spoilboard in a regular pattern, and then use 1/4" threaded rod with knobs above and below for clamping.
The clamps are cut in two sections, and then glued together:
My solution for inexpensive knobs: cut them from MDF, and insert "T-nuts", which cost about 10c each. Sure beats $1+ for the fancy ones!
Old Mon 01 August 2011, 18:14
melissa
Brighton (Ontario)
Dust Collection: Thien Baffle
I thought that the dust quantity would be a problem, and surfacing the table confirmed it for me . Next up: building a Thien Baffle to separate the dust ahead of the dust collector.
I built a smaller version for my shop vac, which works astoundingly well. It was much easier to build this one, not needing to cut the circles with a jigsaw anymore .
I made the lid from two layers of 1/2" plywood, glued together with PL Premium adhesive. This is a polyurethane construction adhesive, which expands to fill gaps, and is very strong. The workpiece does need to be well clamped while curing, though:
Hose parts are for 4" PVC sewer plumbing. Ideally, the elbow should be flush with the plywood. I'll see how this does, and may opt to add a "false lid" later, if it doesn't work as effectively as it should.
Old Mon 01 August 2011, 18:15
Hey those look just like mine clamps and the knobs too
I have to check my shop for missing ones !
good work, and they will serve you well, just a note, when doing something slippy like plastic or acrylic wrap the tip of the clamp with thin rubber, it helps.
Old Mon 01 August 2011, 18:28
Rusty Nuts
Just call me: Gary #86
Valley Grande, AL
Hi Melissa,
Really nice build. Post some more photos of the clamps in use when you have completed them. When you glued the second spoil board down over the first, how did you clamp it to get even pressure across the boards? I'm thinking of routing dadoos down my spoil board and install "T" track for the clamp hold downs. I saw in an earlier post you installed your computer into the control box. How is this workin out and do you have to open the door to turn the computer on?
Gary
Old Mon 01 August 2011, 18:30
melissa
Brighton (Ontario)
Thanks for jogging my memory... I had an "oops" while cutting parts for the dust shoe.
I was cutting 2mm Lexan for the top surface of the dust shoe. Two holes (40mm and 107mm), and then the outer profile. I figured there wouldn't be THAT much force on it, so I taped around the edges with high-tack masking tape.
About halfway around the outer profile, the workpiece lifted off the table. I hit the yellow feedhold button on the car, which stopped the motion, but not the router . Next was the e-stop, now that the part was ruined anyways.
I will say it took a huge amount of self-discipline to NOT reach in and try to "save" the part. Lexan is cheap, compared to surgery and physiotherapy!
I'm making it a habit to not even lean on the MechMate, even when it's turned off. Much better to always treat the machine with respect, so that when things go wrong, the automatic reaction is to step back. With the proxies and the hard stops, there's little the machine could do to damage itself now. So all I need to do is make sure it doesn't damage me.
Old Mon 01 August 2011, 21:53
melissa
Brighton (Ontario)
Originally Posted by Rusty Nuts View Post
Hi Melissa,
Gary
Hi Gary,
I drilled holes and used "particleboard screws" to clamp the second layer in place, as well as C-clamps around the edges. The screws have a very coarse wood thread, and a pan head. Once the glue was dry, I just removed them.
For the T-track, you need to consider what depth to install it at, and whether you're willing to cut into your spoilboard. You certainly don't want to hit the track. This is why I'm going with through-bolts.
The computer in the control box is working out great. I have its power supply switched from the big rotary ("Ensto") switch, so the computer stays on if I trigger an E-stop. For on/off and reset, I installed two momentary key switches on the control box. These trigger the contacts on the motherboard, the same way the little pushbuttons on a "normal" computer case do. I used key switches on purpose, so I can't accidentally turn off the computer by bumping a switch on the control box.
Melissa
Old Tue 02 August 2011, 16:20
Rusty Nuts
Valley Grande, AL
Thanks Melissa,
I have a spare computer and now I think I'll disassemble and see if I can wire a momentary switch to it and if so I will strip it down. Did you mount a disc drive in the box or just did away with it? Do they make a USB adapter which can be mounted throught the contro box? Would like to transfer cutting files this way.
On my other cnc router I use "T" track and placed a scrap piece of luan under anything I cut completely through. This way I don't cut into my table. On your set up are you planning to pre drill equally spaced holes or just drill as needed for your through bolts?
I ordered my rack and pinions and also the tool steel plate for the Z slide today, so I should be getting close to all my mechanical build. The electrics will be a new challenge. I can't decide if I will install limit switches at this time of the build or wait. I have been reading up on this and have a question. If I have limits swithes at home position, is there an override to enable the gantry to bump the hard stops to square the gantry when first starting up the MM.
Gary
Old Tue 02 August 2011, 17:05
melissa
Brighton (Ontario)
I used a 2.5" laptop hard drive for the computer, also mounted in the control box. Rather than build a mounting bracket for the drive, I just used 11-gauge solid wire, twisted around the motherboard and hard-drive screws. Good enough for a 50-gram drive .
For the clamp holes, I've drilled on approx. 200mm centers. We'll see how that goes. I made a DXF with intermediate holes as well, so I can add those later if needed.
I ran my machine without limit switches at first. It was easier to get the electronics wired and behaving without them, I found. Adding them was fairly simple, having completed the control box already (which was way more complicated). I opted for the relay solution (instead of the circuit board, posted elsewhere around here). Four relays mounted in a junction box on the y-car. Two of the proxies are already on the y-car. The other two are on the gantry, and just need a short extension to reach the y-car.
I haven't figured out the bit about squaring the gantry yet. I do know the proxies trigger before my gantry hits the stops. Hopefully someone else will chime in on how to do that .
Hope this helps,
Melissa
Old Wed 03 August 2011, 11:11
melissa
Brighton (Ontario)
Forgot to mention: I used a Neutrik USB panel-mount connector. This way, I just have a short USB cable from the motherboard to the connector. Outside the box, I can plug in a thumb drive to load the GCODE.
The MechMate computer is not connected to the network at all. This means I can do away with all kinds of things in the operating system, most notably antivirus software.
My total "boot time" from power-on until mach3 is ready to cut, is about 90 seconds.
Old Wed 03 August 2011, 19:35
Rusty Nuts
Valley Grande, AL
Thanks Melissa, I'll have to find me a USB panel mount. I'll go ahead without the limit switches at first like you did. I have never had any on my other router but would like to install them on the MM. Lets hope some one chimes in on squaring the granty. My pinions arrived today and I'm hoping the track will arrive by Friday, that way I can install and true my rails. How are you liking your steppers with the gearboxes?
Post some pics when you use the new clamps.
Gary
dust collector capacity gorantec 55. Dust Management 15 Thu 19 November 2009 19:24
Dust foot and custom clamps done #3 - Conway, AR Doug_Ford MechMates already cutting 195 Mon 13 October 2008 20:27
Dust collector foot Art 55. Dust Management 5 Sun 17 June 2007 13:09
